10-31-2017, 01:12 PM | #1 |
Rep 45
Fbo + meth + pure stage 1
Hey guys,
I recently bought the bms meth kit and stage 1 from pureturbo. I was just wondering more or less how many whp and torque could I get from adding meth and the stage 1? With fbo (catless dp, cp, intercooler, intake, dv, mpe and jb4 map 5) my numbers were 373whp and 400wtq on 98oct. Also, what map should I run with meth and stage 1? Would I be able to keep up with a stock m4? |
10-31-2017, 05:41 PM | #2 |
Rep 1,117
Drives: 2015 BMW M235i
Almost positive the n55 is not capable of running against a s55 without a turbo upgrade. I'm FBO with BM3 tune and got absolutely walked from a roll against a stock m4. I'm pushing 370/420 to the wheels and got rekt 3 times consecutively. The longer the race, the bigger the difference. The s55 is on another level. You might be able to keep pace for a while if you have awd and the m4 can't catch grip.
10-31-2017, 08:03 PM | #3 | |
Rep 716
Drives: F90 M5
Just putting it out there that i raced my buddies comp pack f80 and he didnt get any more than a car out on me from 40-120. we did 3 rolls and every time was almost exactly the same. so that scenario above im giving it to driver error lmao. so out of my experience i can see you staying with or maybe even pulling slightly on a stock s55 car just my 0.02
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct Hmu on Ig: @n55_shayan |
FSociety3810.00 |
10-31-2017, 09:07 PM | #4 | |
Rep 1,117
Here's an m2 with tune getting slaughtered by the s55 for your viewing delight. Last edited by amw896; 10-31-2017 at 09:13 PM.. |
10-31-2017, 09:09 PM | #5 | ||
Rep 716
Drives: F90 M5
10-31-2017, 09:28 PM | #6 |
Rep 2,577
Last Friday, me and my friends did street drag race. Mine is M2 with FBO (no meth) and STG1 Turbo on BM3 custom tune, but on stock tire PSS 50% left.
My friend - M4 ZCP stock, on Cup2 new tire. We just floored it from stand still without launch control, because DCT do not allow repeated LC. M4 ZCP is half a car length ahead off the line and I kept up until on 4th gear (170kph or so) when we have to brake. We did this like 6 or 7 times, same outcome as video below shows. Cup2 tire really completes M4 ZCP. It is so planted, putting down 400+rwhp. M2 is supposed to have better traction stock for stock, but his cup2 is just like cheating...no spin at all and I had traction issue even with PSS heated up to 100F. We believe upgrading to Cup2, I can at least tie the game or even have a slight edge.
Lemania 2320
amw896582.50 |
10-31-2017, 09:47 PM | #7 | |
Rep 1,117
11-01-2017, 10:32 AM | #8 | |
Rep 2,214
That said, I do have a new set of Cup2's in 235/40 that I was going to run on my 18x9's for the track, maybe I'll just run them on the street instead
11-01-2017, 01:20 PM | #9 | |
IG @bmwF9xG80
3810
Rep 7,594
I agree with f22_shayan might have to do with Driver I myself can testify stock ZCP F80 on MPSS against my Boat from 30-100 (i was fender ahead), now with Toyo R888 E30 still stock we were even until 110 where his aerodynamics took the win. M2, M235 Tuned stock turbo can't keep up with Tuned F80, Stock yes and should beat it. SeanWRT pretty sure your car can beat stock ZCP all day long
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 11-01-2017 at 02:02 PM.. |
SeanWRT3179.00 Mr Carrots766.50 |
11-01-2017, 02:52 PM | #10 |
Rep 780
Yeah idk running jb4 with 3 gals of e85 I wasn’t getting wimped on too badly by a buddies M4. I mean he was pulling but not by too much
11-01-2017, 07:48 PM | #11 |
Rep 716
Drives: F90 M5
yea pretty much what happened with me, except for the e85 lol, he got me by about 1/2 - 1 car on each run
11-02-2017, 12:17 AM | #12 | |
Rep 45
11-02-2017, 12:21 AM | #13 | |
Rep 45
11-02-2017, 10:05 AM | #15 |
Rep 1,541
I've ran quite a few stock m3/4 from a roll ranging from ~50-140mph and was next to them the whole time. A tuned m3/4 will walk you in a heart beat though.
I'm FBO/e33/JB4 map 6 On a side note I had the same result with the new Q60 400 red sport the other day. Things will be a beast with a tune.
FSociety3810.00 |
11-03-2017, 08:36 AM | #16 |
Rep 415
My old m135i (hatch version of the m235i) on basically every bolt on minus a turbo upgrade pulled a few cars on oem m3 CP's. This was including fuel-it's TBI, stage 2 LPFP and jb4 duty bias tuning, oem flash.
My vbox figures also confirmed this with mine running 7.8-8.0s 62-124mph/100-200kph where as stock M3 CP's are doing anything from 8.6-9.0s over the same distance. I'll be going down the same route with my DCT M2 but most likely run meth instead of high ethanol mixes and also a flash from bm3 or mhd. It will be good to see how the 2 platforms compare. |
FSociety3810.00 |
11-03-2017, 09:31 AM | #17 |
Rep 2,577
I speaking from a lot of testing. There is absolutely no way stock n55 turbo do below 8s. Stock comp m4 doesn't do below 9 either.
Generally your time is 0.5s quicker. You will want to check road inclination. V box don't do that.
Lemania 2320
amw896582.50 |
11-03-2017, 10:32 AM | #18 | |
Rep 415
I believe we have had this conversation before and I also come from a lot of testing. Just because your m2 can't achieve the same times doesn't mean it's impossible. I have several different sources from vboxing my friends m3 CP to results from the uk HCP and bm3 tuner with m3/4 in the mid to high 8s. Some also do low 9s. If you believe vbox does not show inclination then you really have no clue. Vbox verify will show the inclination of the run and whether it is valid or not. My car has done 8.0 on a 0.2% incline and 7.8 on a -0.4% decline. If you chose not to believe this, it is not my problem but yours . Edit:can email vbox data if so. Last edited by Daleb; 11-03-2017 at 10:57 AM.. |
FSociety3810.00 |
11-03-2017, 11:09 AM | #19 | |
Rep 45
11-03-2017, 11:10 AM | #20 |
Rep 716
Drives: F90 M5
Lol bottom line man with pure stage 1 fbo and meth. Your going to beat a stock m3/4. But a bolt on/tuned s55 car will gap the n55 car
FSociety3810.00 terryd5150507.00 |
11-05-2017, 12:14 AM | #21 |
Rep 1,184
11-05-2017, 12:43 AM | #22 |
Rep 716
Drives: F90 M5
Yea that hahahaha
