2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Catted downpipe... tune required?
      08-08-2017, 05:18 PM   #1
Dr Se7en
Drives: Red
Hey all,
Just planning ahead to get a little extra power out of my M235i. I have been considering a high flow catted downpipe. Will I still throw a CEL if I don't have a tune or piggyback like a JB4.
I do plan to add the JB4 later, just curious if I take the JB4 off for service if the car will throw a CEL while at the dealer.
Only mods to car will be High flow Catted DP and JB4. Mainly doing the DP for sound and a bump in power. I do not want to change the axleback etc.
      08-08-2017, 06:15 PM   #2
lootman1221
Drives: 2015 m235i
have you looked into any of fabspeeds work? they have a dp that doesnt throw any codes and dyno numbers listed as well- tune isnt required, the ecu will adjust accordinly. as far as removing the jb4 before taking it in for dealer service im not sure
      08-08-2017, 07:12 PM   #3
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
with a flash tune, no cel with cattless dp. Jb4 will no longer reset codes as of right now, so yes you will get a code, and will have to put ur oem cat back on for inspections depending on the state you live in.
Make sure who ever does the job resets all the condition tests.
Also, read through the folder as this has been covered a bunch of times.
www.nybmwcca.org
Current Cars:
      08-08-2017, 07:21 PM   #4
pz619
Drives: F87 M2C 6MT, Tesla 3
I have a catted downpipe (fabspeed), MPE, and no tune. Works great! As you, I did it mainly for sound.
My commute home yesterday. 1 Mile, 22 minutes. I don't exactly need the extra power.
      08-08-2017, 10:15 PM   #5
Realdread1
Drives: 16 235i
What condition test do you speak of
      08-08-2017, 11:13 PM   #6
bryan_G01
bryan_G01's Avatar
1165
inspection tests.
flash tune by enzo passes emission tests.
www.nybmwcca.org
Current Cars:
      08-09-2017, 11:02 AM   #7
Dr Se7en
Drives: Red
Thanks guys really appreciate it. Is Fabspeed the only known Catted DP to not throw a code?
      08-09-2017, 12:42 PM   #8
bryan_G01
bryan_G01's Avatar
1165
wagner is a solid catted dp, didn't throw any codes.
important to note, the catted DP's will throw a code eventually. Could be in 2 months, could be 2 years, could be 20 years, but eventually you will get one.
www.nybmwcca.org
Current Cars:
      08-11-2017, 12:16 PM   #9
Fabspeed Motorsport
Fabspeed Motorsport's Avatar
Drives: BMW M235i
I personally have been running my Sport Cat on my M235i for 2 years now and I haven't had a single issue. I also have gotten countless people setup with on and have not had one person throw a CEL. It is the best modification you can do to your M235i/335i/435i/M2.
Check your PMs - I'd love to chat more!
      08-11-2017, 12:48 PM   #10
aaaaah
Drives: Nuggets
There's also the HJS 300cel available from Fabspeed if you want a little bit more scrubbing than their 200cel.
      08-11-2017, 03:15 PM   #11
Fabspeed Motorsport
Drives: BMW M235i
We do have the HJS Euro 6 downpipe but we found the 200-cell HJS cat core accomplishes the same goals, makes more power, and is cheaper!
      08-12-2017, 01:58 PM   #12
B_Rice
B_Rice's Avatar
Drives: 6spd Estoril Blue M235i
My fabspeed is giving me a CEL, so nothing is guaranteed
Estoril Blue 6spd M235i LSD Sunroof delete AWE touring exhaust Fabspeed sport cat
      08-12-2017, 02:29 PM   #13
walnuttea
Drives: 2016 BMW M235i, Alpine White
How many miles did it take you to get there?
      08-14-2017, 08:53 AM   #14
Fabspeed Motorsport
Drives: BMW M235i
Sending you a PM now.
      08-14-2017, 09:22 PM   #15
Benandluna
Drives: 2018 x3 m40i
Did u call fabspeed. My sport cat is awesome and never has had issues.
2016 BSM M235i: Fully loaded.
Dinan Stage II Tune, Dinan CAI, Fabspeed Sport Cat, Fabspeed Muffler Delete.
      08-15-2017, 09:46 AM   #16
Fabspeed Motorsport
Drives: BMW M235i
I reached out to him via PM. I have probably sold over 250 of these downpipes and I've had 4 incidences where a customer got a CEL. Each time was due to either an installation error, gasket failure, clamp failure, etc. Once they fixed it, they were good to go and haven't had an issue since. I think something may have worked itself loose in this case - I'm sure something minor. Regardless, we'll get him taken care of!
WolfGTI716.00
      08-16-2017, 04:22 PM   #17
Downpipe catless or catted do not require a tune. We advise to get a tune with DP for all the additional power that can be gained.
Our best cattted downpipe seller is Wagner and Fabspeed.
Phone number 702-494-9435
      10-29-2017, 08:25 AM   #18
FastTimesInNC
Drives: 2015 M235i
Helpful tip - Unplugging the O2 sensor, like I've experienced in other cars, can be like solving a puzzle. I'm not the brightest crayon in the box, but getting these unplugged without breaking them was the biggest challenge on this install.
As expected, the solution was easy.
The small gray notch on the back pops up, then you can simply push down on that notch and it releases the connector.
      10-29-2017, 10:58 PM   #19
Tcmcec
Drives: '16 Mineral Gray M235i
Can anybody tell me the difference and pros/cons between the catted Wagner and catted Fabspeed, Im interested in either/or. Does one drone more or less than the other? Does one add more HP and torque? Also how long does install take if you are mechanically inclined, may take off for warranty and service work while on warranty. I notice the Fabspeed is much more expensive.
Im more looking to add performance over extra sound, quieter the better. Also I dont plan on upgrading exhaust as I like the sound of the factory setup.
Also any issues with running downpipe and BMS stage 1 tuner?
      10-30-2017, 11:45 AM   #20
Fabspeed Motorsport
Drives: BMW M235i
Our Sport Cat utilizes a 200-cell, HJS, tri-metallic cat core. This is hands down the best care core on the market. It flows 85-90% of a straight pipe, so you will get 85-90% of the sound and power of a catless setup, but guarantees no CEL issues.
      10-30-2017, 11:51 AM   #21
Tcmcec
Does the Fabspeed use a higher quality catt over the Wagner, that will last longer? Does the Fabspeed guarantee no code where the Wagner has a better chance of a code? Does the Fabspeed fit and install better? Just want to fully understand why Fabspeed is double the price before proceeding. Can anyone from Wagner chime in also? Appreciate all the help and sorry for jacking the thread with all these questions.
      10-30-2017, 02:01 PM   #22
Fabspeed Motorsport
Drives: BMW M235i
I am going to shoot you a PM now!
Search this Thread:
