05-04-2017, 09:46 AM | #23 |
Rep 3,947
Much better. The rear tires hook up a lot better and so much better when coming out of a turn.
05-04-2017, 11:59 AM | #24 | |
Rep 5,369
If you do auto-x or road racing, a true LSD should be a priority. For a street-only car, you may want to try DSC Off first. |
05-04-2017, 12:19 PM | #25 | |
Rep 1,700
Dylan861330.00 |
05-04-2017, 04:03 PM | #26 |
1L
156
Rep 336
First reaction with my LSD was the similar impression. Once broken in, all turns smooths out and have a glide feel to it. You'll adapt and driveability will improve over time.
2015 Glacier Silver M235i/6MT
MP Front Splitter//MP CF Short Shifter//MP CF E-brake//MP LSD//Cold Weather package//Driver Assistance package//Oyster Dakota leather//Aluminum Hexagon trim//ECS Tuning Wheel Spacers//AutoPlus Rear Diffuser//HUD//Rexing DashCam//AutoID M Mirror Caps |
22821.50 |
05-04-2017, 05:51 PM | #27 |
Rep 2,214
Problem with eLSD is that it interrupts the balance of the car while it decides which wheel to slow down, otherwise the system does what it is intended to, to a degree. Have it on our GTI and it does work, but unless it's proper torque vectoring like the M2/3/4 or PP GTI I wouldn't call it a "solution" to replace a limited slip arrangement. Just my $.02
05-11-2017, 07:13 AM | #28 |
M-OCD
17
Rep 38
I'm still on the E-Diff. Are 0 - 62 times improved with the M Performance LSD? Fastest I got on my car (0 - 100km/h) was 4,35s measured with VBOX Sport. This was with DSC completely off.
2015 F22 M235i N55 EWG | M Performance | 18" VMR710 | Pure Stage 2 Turbo | Pure High Flow Inlet | MHD Tune | XHP Tune | GFB DV+ T9356 | NGK SILZKBR8D8S 0,5mm | Wagner DownP | Wagner EVO2 Performance Intercooler | VRSF Chargepipe | M Performance Exhaust |
05-14-2017, 11:31 AM | #29 | |
Rep 3,947
However, they are significantly improved if you're talking about accelerating out of a corner. |
05-14-2017, 11:45 AM | #30 |
Rep 442
This seems to be the case. Its smoother into the corners now, still not as it was with the stock, open, diff, but getting better all the time. I'm considering having the local BMW performance shop replace the diff fluid now that I'm past 1200 miles on it. I'm not sure if its worth the expense though.
05-15-2017, 09:51 AM | #31 |
1L
156
Rep 336
I'd wait till 30k miles to get your money's worth. That's when I plan to do mine. A rule of thumb for me is to replace it when my rear tires need to be replaced. I've got roughly 22k miles right now.
10-23-2017, 08:13 PM | #32 |
Rep 442
Following up on this. I just had to diff fluid changed. I'm at 15k miles now which means the LSD has about 8k on it. The rear end is much, much improved. It's very smooth now. Cost was about $150 at the local, independent BMW shop.
WillOs7.00 |
12-19-2017, 10:16 PM | #33 |
Supreme Allied Commander
3842
Rep 54,352
Drives: F80 M3
With a clutch type LSD it is a good idea to do a break-in service at 2-3000 miles and every 30K thereafter. If you track the car, every 15K or sooner.
Anthony235715.00 |
