07-01-2014, 09:28 AM | #133 |
Rep 1,254
Whats funny now that I finally got my car. I was looking through the idrive settings and wanted to see how the check level of oil worked. I had been driving for at least 10 min now. I clicked check oil level. It counted up to about 95% then said level can't be calculated need to warm/drive more (something to that effect. don't remember exact verbiage). But just a thought you can use that to gauge when the car is ready to be pushed or oil is warmed up to operating temp.
07-01-2014, 11:52 AM | #134 | |
Rep 4,341
The crank was replaced by better technology, a starter. What has the temp gauge been replaced with? Zilch. It's a net loss for those of us that care about our cars. |
07-01-2014, 04:01 PM | #135 |
Rep 195
So hilariously wrong. A temp gauge has been replaced by numerous sensors that working in conjunction with the DME to: retard/advance timing, limit revs, constantly monitor individual cylinder temperatures, automatically turn on fans, etc. The list goes on. Instead of requiring the driver to look at a gauge that may or may not be calibrated correctly, now the car does it for you. So stop, please.
07-02-2014, 10:06 AM | #136 | |
Rep 139
And we have access to "hidden menu" with a digital temp read out, which displays not only Oil, but coolant temp as well, which is perfectly passable for a track day situation. And if you want an all the time gauge? There is nothing stopping you from adding a Defi or like oil temp or oil pressure gauge that will provide truely accurate information. |
07-16-2014, 10:56 AM | #137 | |
Rep 4,341
The real issues are these: 1. There is no reason a sports type car like the M235i to get rid of it. 2. It furthers the decline, lack of car-guyness of BMW cars and continues the softening of the brand. 3. BMW cooling systems are awful long term with plastic radiators, expansion tanks, thermostat housings, hose connections and electric water pumps that fail at high mileage. Radiators and expansion tanks burst and electric pumps fail and what little warning you might get from temp gauge is gone. 4. Why should I buy a 50K car with 16 M badges but no temp gauge? Then have to pay extra with some silly bluetooth option. How about they let you choose between logo and temp gauge? The fuel-and-go crowd can pick the logo and the rest of us can opt for the temp gauge. Obviously, they invested money in adding badges and logo on the cluster and took away the gauge. That shows a sickening shift in priorities from functional to fluff and that is the worse part of it. I can't believe anyone even defends this. I'm shocked, shocked how everyone is OK adding fluff in place of something useful. Last edited by nachob; 07-16-2014 at 11:20 AM.. |
07-16-2014, 11:19 AM | #138 |
Rep 195
Dude, get over yourself. They didn't "add fluff" over everything else. BMW put a ton of R&D into the chassis, equipped it with PSS from the factory, gave it a factory tune, and made it cheap. It is hands down the most performance you can get for the money which you would know if you drove the damn thing. In the end, just don't buy the effing car. Spend 20k more to get a Porsche so you can have a temp gauge.
Oh, and BTW, your argument about the cooling misses one HUGE factor. Before you can react to a damped gauge, the car is way ahead of you. As soon as that temp starts to rise the car will go into limp mode so you CANT HURT THE MOTOR. Isn't that what this is all about? Dunno about you, but if I'm going 130 I'm not looking at my temp gauge to make sure it is staying within a good range. |
07-16-2014, 11:25 AM | #139 |
***** noob
1369
Rep 10,479
Enough with this...get yourself some ricer gauages and call it a day
2006 325xi (Sold)
07-16-2014, 11:50 AM | #140 |
Rep 4,341
Here are the CR Reliability Ratings for 1, 3, and 5 series. Notice after about 6 years cooling systems fail. They are notorious. Plastic tanks fail as do the water pumps. They didn't change a thing on this generation and dropped the gauge!
I don't want a ricer pack! If they had switched the cooling system to an aluminum, more reliable system then dropped the gauge, maybe your arguments for dropping real for fluff might hold some water, but it is the same plastic crap. I have been willing to pay for the extra maintenance and uncertainty because I enjoy the dynamics for rear drive and MT but they are just making things worse. |
07-16-2014, 11:51 AM | #141 | |
Rep 1,459
Ditto for the dip stick. In no way is anyone's life easier without one, but I'm sure someone here could find a reason to justify it. The people justifying this could probably also justify not needed a tachometer. I mean who needs one when you can just hear the engine? Plus it stops you from over revving with a limiter. |
07-16-2014, 12:07 PM | #142 | |
Rep 139
I've driven several turbocharged sports cars that don't have oil temp gauges, or even Oil coolers. I've never had one of them overheat. Maybe that's why I'm not so concerned about the lack of the gauge in my 235. I never once sat in my STi and thought, gee this isn't a car guy type of car because it didn't have an oil temp gauge, and I certainly don't think that of my 235. And we get it, the M logo, and specifically the number of them bothers you. I'm not one to badge whore, so I could care less. And as to the future, I will say this again, with BMW's move to mandatory Idrive in all cars I wouldn't be surprised to see, particularly in the proper M cars, a suite of auxilory gauges in a "sports" display mode, replacing the need for in cluster gauges and allowing the driver even more information than what is currently available. But of course, you're anti screens too. |
07-16-2014, 12:11 PM | #143 | ||
Rep 139
07-16-2014, 01:05 PM | #144 |
Rep 2,010
This thread brings something to mind:
When I bought my new Mazda RX-7 in 1985, the salesman's parting words were, "This is a sports car and meant to be driven hard, so go enjoy it." When I bought my new RX-8 in 2004, the salesman said essentially the same thing. Neither car ever gave a hint of overheating, even when pushed hard. I'd surprised if BMW couldn't do that good with their cars. Not worried (but I am going to try holding down the trip odometer reset button during the next start up to see what comes up on the display)
07-16-2014, 01:35 PM | #145 |
TIM YOYO
1504
Rep 3,283
Drives: 2013 M3
I had one on mine (2011 135i) as well. Maybe you should look in to some glasses Maybe it was only on the 135i? Did you have a 128i? I specifically remember mine because my brother-in-law had a 3-series, and he remarked about the lack of a real-time fuel economy gauge like the one he had in his car. My reply was that I'd prefer the oil temp gauge. No way that conversation would have happened if it wasn't there.
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech Past: 2013 ///M3 - Interlagos Blue Black M-DCT Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport |
07-16-2014, 01:39 PM | #146 | |
Rep 139
07-16-2014, 01:47 PM | #147 |
TIM YOYO
1504
Rep 3,283
Drives: 2013 M3
Found a photo: http://www.caranddriver.com/photos-0...n-photo-193769
07-16-2014, 01:47 PM | #148 | |
TIM YOYO
1504
Rep 3,283
Drives: 2013 M3
Brb while I get some glasses
07-16-2014, 01:52 PM | #149 |
Rep 139
07-16-2014, 01:55 PM | #150 | |
TIM YOYO
1504
Rep 3,283
Drives: 2013 M3
07-16-2014, 02:10 PM | #151 | |
Rep 197
