05-23-2020, 06:47 PM | #1 |
Rep 85
Left Brake Lamp Malfunction message, extended warranty
I had the stop light error message. Talked to my service manager and showed them the extended warranty which just barely covered my 2015 M235i vert from date of in service.
They fixed it, and supposedly did both sides. During which they said that the rear electronic control unit was also bad and replaced. During this visit they also nuked my main head unit while coding the rear unit. Replaced this also. Charged my about $100 as they said problem was rear electronic unit. Now several months later I'm getting the Left Stop Light error again. Brake light works. Will check that they did add the extra wire on the warranty fix. Only going back if that doesn't work. I don't plan on having them doing my service. Will DIY. Plan on flushing my brake fluid tomorrow. Speaking of which; Do you reset the brake fluid service on the trip computer like older BMWs? I have the Autophix 7910, so will check that also. Is there anyway of registering DIY services so they show up on CarFax like dealer service does? |
05-24-2020, 08:20 PM | #2 | |
Rep 745
I have no idea about being able to register services; I just keep receipts and enter dates/mileage in my log.
05-24-2020, 09:46 PM | #3 | |
3639
Rep 3,602
05-24-2020, 10:26 PM | #4 |
Rep 2,874
And you need ISTA (or similar software) to cycle the ABS and get the fluid out of it. Not as crucial if you are not changing the type of fluid, and don't track the car.
05-24-2020, 11:57 PM | #5 |
Rep 85
Reset!
Ok...figured out how to reset the brake fluid. Saw several videos stating press the set/reset button. I was pressing the scroll button on the trip computer. Didn't even know that button on the lower left display existed.
Ignition on/engine off, press and hold newfound button, see reset available, press hold, press hold, it resets the service interval. |
05-27-2020, 10:07 AM | #6 |
Rep 30
Regarding your original issue, any parts and labor from repairs using OEM parts are usually covered for 12K miles and/or 1 year. Look on your receipt for terms.
2016 M235i (mine) 2017 X3 M-Sport (hers)
