07-21-2017, 07:17 PM | #1 |
Rep 233
Does your M235 idle smoothly (Dinan)
I have a '15 M235 with the Dinan S1 package. Car runs fantastic but at idle it has a bit of a stumble. Not bad but not perfect either. I need to turn the tune off to see if that is the problem but does anyone else notice this?
07-21-2017, 07:42 PM | #2 |
Rep 8,942
Just on startup mine can be a bit sketchy for maybe 30 seconds.
07-21-2017, 11:05 PM | #3 |
Rep 68
Mine stage 2 (same as s1 pack) right at start up is a tinny bit rough, not much but just enough to notice, and usually gone right away after couple second when idle drops abit.
Then again I'm not running dinan exhaust and intake tho. |
07-22-2017, 09:09 AM | #4 |
Rep 1,117
Drives: 2015 BMW M235i
check spark plugs...what is your mileage?
07-22-2017, 11:09 AM | #6 |
Bright Sky
1164
Rep 922
Drives: BMW M235i (8AT)
Same here. After it goes through the cold-start process all is good and well.
I recently had my spark plugs replaced at 40,000 miles and it has improved behavior up to the point where it felt I had just bought the car new again. No complaints here.
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive. |
07-23-2017, 04:07 AM | #8 |
Rep 80
Dinana S3 and only time there is an idle difference is with AC running. Seems as if the Dinana does not jive with the AC being operational...when shifting gears I really notice a severe drop in RPM.
P.s. Had the Dinan software updated and still having the same issue. |
07-25-2017, 02:24 PM | #9 |
Rep 190,777
Probably one of the spark plugs going bad
