07-05-2017, 09:28 AM | #1 |
Rep 5,538
Quick question about MPE
Can anyone tell me exactly how far does the exhaust pipe extend from the muffler? I am doing some cutting and want to make a cut in the exact place as OEM MPE. Thanks
07-05-2017, 09:49 AM | #3 |
Rep 8,942
Also leave the pipe on the long side. MUCH easier to trim more after you do a test fit than put some back.
07-05-2017, 11:08 AM | #4 | |
Rep 5,538
07-05-2017, 11:59 AM | #5 |
Rep 8,942
Just have the shop that's doing the work look at it then. What you are talking about is stupid easy for a pro.
07-05-2017, 01:06 PM | #6 |
Rep 5,538
07-05-2017, 01:24 PM | #7 |
Rep 8,942
Believe so but not 100%. Know the 240 setup is different. Someone did the swap already and modified the diffuser to accommodate, I am sure if you search you can come up with it.
07-05-2017, 02:52 PM | #8 |
Rep 5,369
See post #12.
http://www.2addicts.com/forums/showt...&highlight=cut I strongly suggest not welding and going with a band clamp arrangement like they use on the MPE. It will give you FAR more flexibility with aligning everything and removing later on. There's NO WAY you'll be able to get it perfect otherwise. |
07-05-2017, 03:31 PM | #9 | |
Rep 5,538
07-05-2017, 04:20 PM | #11 |
Rep 8,942
I have it off with my MPE. The stereo sounds much better and the MPE is as loud as I would want it to be. I take work calls in the car all the time and I'm right at the limit of what I can deal with for that.
