06-13-2017, 04:27 AM | #1 |
Rep 221
Overfilled my oil
Hey Guys,
If i have over filled my oil will i get an engine light? Or will it just die? I had a oil low warning and it was at the MIN level, I proceeded to put 5ltrs in, I then realized i was only ment to put in a few ltrs and not 5. I have driven maybe 50-80kms already but after hearing some nightmare stories I have stopped driving it. Nothing bad has happened yet, but should I see a warning to High? I did a test level and its sitting at MAX but no further. Im worried it could cause some serious damage. |
06-13-2017, 04:55 AM | #2 |
Rep 1,303
Drives: 2021 C8 Corvette 1LT
It could increase crank pressure which MAY blow a seal. Most likely though it will vent into the intake and burn off. I don't think it's too excessive, but then again the 235-240 only requires 6ish ltrs to begin with so who knows.
Safe bet would be to use a clean oil pan and drain the oil and re-add to the appropriate level. |
06-13-2017, 07:28 AM | #4 | |
Rep 5,577
Anyone know - can you hydrolock an engine by putting in too much oil ? Would the oil have to be filled up into the cylinder bore? 4 or 5 extra liters (quarts) seems like a lot of extra oil, how high to or above the crank centerline do you think that amount extra is ? Last edited by overcoil; 06-13-2017 at 02:12 PM.. |
MLJR235116.50 |
06-13-2017, 01:31 PM | #5 |
Rep 5,369
You need to stop driving the car immediately and empty some oil. That's the simple answer. Yes, serious damage can occur from significant overfilling of oil. The oil could be so high that the entire crank is under oil, worse, oil could be into the cylinder bores. None of this is good at all.
06-13-2017, 02:04 PM | #6 | |
Rep 1,700
Are liquids compressible? Damage will depend on how much you over filled..... If you over filled to a point where oil is coming over the top of a piston then bad things will happen even for one stroke of the piston Google "Slugging" an engine/compressor |
06-13-2017, 05:12 PM | #7 |
Rep 221
when I realised I could cause damage I had the car towed. so I'm not driving it till I drop the oil. I do have a feeling tho Ive prob filled it to the Max level as I'm sure if a problem was going to happened it should have done so by now.
thanks for the feedback about the oil flap! |
06-13-2017, 05:17 PM | #8 |
Rep 628
All of this could have been avoided If Bmw didn't get rid of the dipstick.
Jelly_Belly43.50 |
06-13-2017, 05:20 PM | #9 |
Rep 221
lol. yea 100% agree. also could have been avoided if BMW service did an oil change at the first service instead of telling me the oil change doesn't happen till 30 000 or 2 years.
I even asked them to do an oil change and they wouldn't. |
06-13-2017, 06:27 PM | #10 | |
Rep 5,262
5L extra is about double what the engine takes |
06-13-2017, 06:52 PM | #11 |
Rep 1,117
Drives: 2015 BMW M235i
Something doesn't add up, there's an oil light that pops up when you hit minimum which indicates you need 1L of additional oil which brings you back to max. Putting in 5L when ur already at around 5L of the max 6.5 means you're at like 10L which is incredibly dangerous. Personally, I would bring into a shop for an oil service and to check if permanent damage hasn't been done already.
06-13-2017, 08:25 PM | #12 |
Rep 221
Alright so i drained 5ltrs bringing me to just above MIN. Hoping no permanent damage has been caused. I did get bmw roadside to come out and asses it last night so if something bad happens Im sure BMW will now know and wont warrant any damage... unless roadside is separate from Service?
how stupid of me in the first place to put a full 5er in oh man... What would a service center check if I were to take it in? how would they determine if permanent damage has been caused? |
06-13-2017, 09:17 PM | #13 | |
Rep 5,262
Also I would and just "one" extra liter to bring it to the max mark. You really don't want to drive with oil at min |
06-13-2017, 09:19 PM | #14 | ||
Rep 5,262
06-14-2017, 04:22 AM | #15 | |
Rep 5,577
Windage is another issue from oil foaming, the foam acts as a resistance to moving parts or causes vacuum vortex's near small lubication channels around piston bearings - but I think again that is all issues when racing, and not even sure I know what I'm talking |
06-14-2017, 05:09 AM | #16 |
Rep 221
It would be nice to know what MIN/MAX actually equals.
If MIN = 1ltrs and MAX = 6ltrs that would make sense. then if you get a warning @ MIN you can put a full 5ltrs in as thats what they sell... I dont understand why MIN would equal anything less then what the name means - Minimum. It would be strange if MIN = anything above 1 right?? |
06-14-2017, 04:05 PM | #17 | |
Rep 5,262
06-14-2017, 05:04 PM | #18 |
Rep 221
Sigh,
Thats not MIN then is it lol, thats basically full. And there is no dipstick to check it either. Im not going to ever put more then 1ltr in without running the check after. Lesson learned! |
06-14-2017, 06:35 PM | #19 | |
Rep 5,262
If MIN where to mean when it's empty your engine is already blown.... Message is pretty clear... |
06-15-2017, 09:50 AM | #20 |
Rep 1,541
5 Ltrs?! stop driving the car immediately.
06-15-2017, 04:14 PM | #22 | |
Rep 221
