2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Fabspeed's M235i Muffler Bypass Exhaust System Review
      06-19-2016, 02:14 PM   #23
N55guy
N55guy's Avatar
214
Drives: 2014 m235i
2014 BMW m235i  [0.00]
Originally Posted by BentZero
Is there cutting involved when you install this?
Yes but it was very easy with a tool I rented from autozone... 20min to install including the cutting w/ an unpowered hand tool
      06-20-2016, 08:32 AM   #24
Fabspeed Motorsport
Fabspeed Motorsport's Avatar
Drives: BMW M235i
Originally Posted by Beef Supreme View Post
This sounds great. Are there any power gains with this system alone?
Thank you! To be honest, there are really no power gains to brag about. 1-3 gains at certain points.
Originally Posted by ginge235 View Post
Looks and sounds great.Can you pm me a price and delivery charge to Australia please
Sure can!
Yes, you cut your stock exhaust at a factory break point. You can easily return back to stock by using the included Torca clamp to reattach it.
John S | Performance Specialist
john@Fabspeed.com
P: 267-742-3045 | F: 215-646-9828
155 Commerce Drive | Fort Washington, PA 19034 | USA
www.fabspeed.com
      07-07-2017, 02:51 AM   #25
Twilson25
I've been around
Twilson25's Avatar
Drives: 2020 M2 Competition
midpipe or no?
Would you recommend just the bypass or adding the mid pipe as well?
Also I am considering their cat sport DP.
      07-07-2017, 08:32 AM   #26
BEM-S4
BEM-S4's Avatar
Not sure where I saw it but somewhere somebody installed a Y fitting with a switch so you could go muffler or not depending on how stealth or obnoxious you wanted to be. So that's another option if you don't want to lose the muffler entirely.
      07-07-2017, 11:17 AM   #27
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
I would just do the exhaust dump. The amount of money you save by doing this and getting the same results in sound.
Yes you loose some weight if you remove the muffler, but If i had to do it again, i would keep the muffler and use the dump. This way i can be quiet when I need to be, at the house, with the wife, or at sound reduced tracks.
Its much cheaper.
www.nybmwcca.org
Current Cars:
      07-07-2017, 04:01 PM   #28
Fabspeed Motorsport
Drives: BMW M235i
It really depends on what your goals are for the car. If you plan on doing the Sport Cat and the Muffler Bypass, adding our Resonator Bypass Midpipe isn't going to make a world of a difference in sound - it will refine it a little more.
I run our Sport Cat and Muffler Bypass and I absolutely love it. Cruising around town at low RPMs it's super quite but when I want to make some noise, I switch it into Sport/Sport+ and I go have some fun!
Check your PMs - I'd love to chat more!
      01-03-2018, 03:09 PM   #29
Bmw.Fan
Drives: m235i
Is anyone able to tell me the difference of the fabspeed muffler delete between the m performance and non m performance model?
I think I may have gotten the wrong part because it seems it's too short for my m performance diffuser.
      01-03-2018, 03:40 PM   #30
mikeyymonster
mikeyymonster's Avatar
Drives: 2021 M2C
Yes the difference in length is for the diffuser. You should be getting the one for the m performance diffuser if you have either the m performance diffuser or any aftermarket diffuser.
2021 M2C
2014 M235i
Instagram: @mikeyymonster
      01-03-2018, 05:18 PM   #31
Bmw.Fan
Drives: m235i
Do you happen to know the dimensions of the muffler for either version? Trying to figure out which one I was sent. Part numbers show m performance but something is off.
      01-03-2018, 10:05 PM   #32
mikeyymonster
Drives: 2021 M2C
I don't, but did you adjust your tips?
2021 M2C
2014 M235i
      01-04-2018, 04:27 AM   #33
Bmw.Fan
Drives: m235i
I've pulled the tips out as far as they will go and it won't poke out of the diffuser. It's pretty much flush but slightly inside of it so that when you look down from the trunk, it looks like there aren't any tips.
