10-09-2015, 09:54 AM | #1 |
Rep 54
Drivetrain Malfunction with Dinan Stage 2
In the past two months I've gotten the "Drivetrain Malfunction" message in my M235, but when I turn off the car and turn it back on it goes away. I have it at the dealer for some other issues and asked them to see if they can find anything (I took a picture of the message on the iDrive screen incase they didn't believe me).
Has anyone else heard of this happening to our cars? Thanks |
10-09-2015, 10:07 AM | #2 | |
Rep 225
2015 ///M235i | Alpine White | 8AT | RW Carbon Front & Rear Lips | Autotecknic Paddles | MP Side Decals | AWE Axelback | Shifteck DP | MHD Stage 2+ | BMS Intake | FTP Charge Pipe | VRSF FMIC
10-09-2015, 11:05 AM | #3 | |
Rep 893
2019 SG M5C
10-09-2015, 12:47 PM | #4 |
Rep 221
Same here, I get it occasionally with my JB4. Just happened to me last night. I was in manual mode, 8th gear, started out at about 2,000 rpm and was enjoying the nice torquey pull these cars have when suddenly Drivetrain Malfunction popped up. Pulled over, turned car off and back on and the error went away.
10-09-2015, 01:00 PM | #5 | |
Rep 3,126
10-09-2015, 04:46 PM | #6 |
Rep 5,102
I had a similar error generated (Stage 1) and Dinan, my dealer and BMW Canada worked through the codes and turned out to be nothing. Error never returned. Error was chocked up to adaptation. Hopefully your dealer will be of similar help.
Still a happy Dinan customer. Will be moving to Stage 2 in November.
10-09-2015, 05:12 PM | #7 |
Rep 23
Was driving my friends JB4 335 just last week and his brought up the same code doing a 3rd gear pull . He says that means the tune read overboost and resets the car to stock until it is turned off and restarted. It was a cold night and apparently the tune hadn't adjusted yet for the air temp change. Isn't a problem with the car, just the tune protecting the vehicle. He then asked if I had shut my 235 off at 80 mph before, the look on my face was great I imagine.
///2015 M235i Alpine with Coral 6-Speed, ZCW, ZPP, ZDA, ZTP, HK, MPE, MP LSD, MP CF Full Interior, MP CF Mirror Caps, MP Front Splitter, Shifteck Catless DP, aFe Magnum Force, BMS JB4
Instagram @F22AW_M235i |
10-09-2015, 06:53 PM | #8 |
Rep 54
Dealer called me this evening, they said it was a bad electrical actuator for the turbo. I'll see if the paperwork lists anymore details or codes when I get it tomorrow.
10-09-2015, 07:25 PM | #9 |
Rep 5,102
Good news!
10-10-2015, 12:23 AM | #10 |
Rep 225
Interestingly enough, I have only ever gotten it on startup, never when cruising /wot. Next time I get it I'll scan the code on my phone and report back what it says.
10-10-2015, 09:45 AM | #11 |
Car Enthusiast
282
Rep 501
I have seen a few of these come in to our dealership(work as a tech for bmw)
What i have found that works in the past for the problem u are describing is to have the dealer un-plug your Dinan or Jb4 which ever ur using. perform a battery reset for at least 1 hour and 20 mins. Then Have them perform and complete programing/encoding to bring the cars Ilv up to the latest software. Once that is done, Plug back in the tune. Haven't had a car come back yet....Knock on wood. If your car has Warranty and you are using a Dinan Tune... You may be able to get away with them doing this on warranty for you but dont quote that on me... Every dealership is different. If it actually fixes the problem tho after the programming, they should be able to claim it under warranty. |
10-10-2015, 01:43 PM | #12 |
Rep 54
I got the car back today. This is what the report said: 123511 code waist hate flap sluggish. Replaced waist gate electrical actuator drive. Diag code d1165_00000000_28_001.
It drives fine now, I'm just not sure if the Dinan upgrades caused this or if was just coincidence. |
10-10-2015, 02:03 PM | #13 |
Rep 5
Drives: 2013 335i Xdrive
Today while I was out I got a drivetrain malfunction. I am also running dinantronics stage 2 but in a 2013 335. I scanned the code and got pending code P112F. Anyone know what this code is? I am running a ER Catless down pipe but I use the first gen BMS can flap module to auto clear the cel for that.
10-11-2015, 10:03 AM | #14 | |
Rep 859
Drives: 2017 Alfa Giulia Quadrifoglio
Sorry, couldn't resist. Just teasing based on the line of BS Dinan is feeding in another thread about being the best engineered software solution and therefore charging a premium for said empty promises. |
10-30-2015, 01:47 PM | #15 | |
Rep 1,931
P112F - Manifold Absolute Pressure to Throttle Angle - Too High (Bank 1) The fault is recognized when the relationship between the indicated intake manifold pressure and the mass airflow calculated based on throttle-valve angle is not correct" Check mass airflow sensor...
www.nybmwcca.org
10-30-2015, 04:32 PM | #16 | ||
IG @bmwF9xG80
3812
Rep 7,593
Any updates?
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
10-30-2015, 05:50 PM | #17 | ||
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
I'll stick to my flash tune. Absolutely zero issues with my Enzo flash best $ I ever spent on this car.
FBO-PS1 and stuff
11-01-2015, 03:39 AM | #18 |
Rep 3,523
M235i and DINAN stage 2???
Wait a minute, DINAN Stage 2 in a M235i???
I just talked to the DINAN tech at my dealership. He said all I can do is a DINAN Stage1 on my M235i DINAN's Web site advised the same thing. Can anyone clear this up for me? Thanks |
11-01-2015, 06:31 AM | #20 | |
Rep 292
2015 M235i BSM / 2011 X5D AW
11-01-2015, 10:46 AM | #21 | |
Rep 278
11-01-2015, 10:59 PM | #22 |
Rep 69
QUOTE] I heard someone with m135 jb4 after running for a year the message become permanent. He couldn't remove it. He went back to the dealer and they voided his warranty after checking the car. anyone else have this problem ? please share. thanks
