10-01-2015, 12:11 PM | #1 |
Rep 1,184
Methanol injection
Hi guys,
I was always opposed to adding meth injection to my system because it was something Inever really looked up. I just assumed it would be a big hassle and most likely harmful to my car. However, I did a little research and found out that if done properly it can be a great, reliable, safe mod. So now I have a few questions for those of you who are familiar -is meth a good/bad idea for spirited street use? At first I thought it would be another thing to worry about filling all of the time, but then I read somewhere that it is not constantly used. It is usually used only in periods of higher boost. Is that correct? -Is there a monitor system to tell you when the tank is low? I've read some guys use windshield washer tanks, and they get a low fluid light when they are low, I'd rather keep my washer fluid though. -What size tanks do you guys use? 2L? 1gallon? Where do you store the tank? I do not have a spare tire will the tank fit in the little area next to the battery? Is that a bad idea? -What's the deal with meth/water mixtures? More meth is more power and more water is more cooling, which allows you to run higher boost without knock? -What is the 'whole mixing" fuel about? Is mixing e85 and pump the same goal as pump with meth injection? Raising octane? I know the power density of ethanol is lower therefore it takes more of it which can stain the stock fuel pump right? Does meth injection avoid this issue because it uses a separate pump? Do you need a programmable tune (jb4) to run meth so you can tell it when to come on ? If you are running higher boost it is a good idea to upgrade the charge pipe. When I do that should I gt one with a meth bung, because that is where it hooks into right? How is this for dealer visits? Do you just unplug the hose from the cp and tae the tank out of the trunk? Is it easily traceable? Where do you guys get the stuff? I read some people just get it at he depot. Is that stuff high quality enough to use? Sorry if these are some noob questions, but the thought of this mod is pretty new to me Thanks Last edited by jmwilson125; 03-08-2017 at 07:47 AM.. |
10-01-2015, 12:20 PM | #2 | |
Rep 957
I use it mostly for cooling, and there is a power gain but that is not my primary goal. I had to do quite a bit of map tuning to get a smooth power delivery, and I think it would quench in stop and go, but on the track there is no issues. Bottom line, meth is not for people who don't like tinkering, and you can cause a lot of damage if not set up right. If that's not you, than I would skip. I would suggest heading over to n54tech, and doing some searches and seeing if that is what you want to get involved in, or at a minimum get yourself educated. |
10-01-2015, 06:47 PM | #3 |
Rep 2,357
jmwilson125
You have already done a lot of research and know most of the answers I can tell. I dont use it daily. I have my map6 that I run daily and map3 (JB4) I use for fun. For dealer visits you can remove the whole kit in 2 hours I would guess. As Pparana is writing its a system that requires some attention - not just like filling up from the pump. You will have to check logs on a regular basis to check if its operating properly... For me it mean I can run 20psi max instead of 16psi max + the added benefit of lower IAT's. With the JB4 the system is fully integrated only giving you full boost if flow is perfect. Just like you I also did not want to run meth in the beginning - a frankenstein add-on in my eyes, but it really is a brilliant system. Fill up with normal 95/98 RON and have 100 on demand Where to get it...I get it in 20 liter cans (99%) from a whole sale company and add water myself.
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
10-01-2015, 09:59 PM | #4 |
Car Enthusiast
282
Rep 501
If used Properly it can be very beneficial. Not really much else to say.
on a side Note... BMW will be using Meth injection on some of our new engines coming out. Snow performance is going to be the supplier. Its going to help carbon build up ont he valves. |
10-02-2015, 03:16 PM | #5 | |
Rep 171
They already are using water injection, not meth injection. I am sure people will put meth in there. How do you know they will be using snow kits? Makes no sense to me. Last edited by boost82; 10-02-2015 at 03:37 PM.. |
10-02-2015, 03:33 PM | #6 | |
Rep 171
[IMG][/IMG] [IMG][/IMG] Last edited by boost82; 10-02-2015 at 03:41 PM.. |
10-02-2015, 04:07 PM | #7 | ||
Car Enthusiast
282
Rep 501
2016 M235 - Melbourne Red
10-02-2015, 04:22 PM | #8 |
Rep 171
Yeah cause I know the M4 motox safety car has water injection integrated which is really cool. Seems to me they would only need pumps, they would use the dme to control everything which is awesome.
10-02-2015, 07:16 PM | #9 |
Rep 2,357
boost82
You are using the Aquamist for added fuel volume?
(A Dane in China) |
10-02-2015, 10:42 PM | #10 |
Rep 171
10-03-2015, 02:30 PM | #11 | |
Rep 1,184
Thanks that was a huge help. You can only learn so much from Google. It's nice to hear from people in the community. |
10-04-2015, 09:18 AM | #12 |
Rep 957
That's a nice setup, what size nozzles ar you using?
10-05-2015, 07:22 PM | #13 |
Rep 171
10-07-2015, 08:37 AM | #14 |
Rep 1,252
anyone here ran 100% Water injection only on N55 or N54, if so what nozzles and how many do you recommend, i need water injection to cool down my crazy IATs.
Docrace 6266
10-07-2015, 10:21 PM | #15 |
Rep 2,357
While testing my setup I just used pure water with a CM10 nozzle - that is definitely too much haha My engine died on 1-2 cylinders and would not run normally until restarted. I assume you already have an uprated IC?
(A Dane in China) |
10-08-2015, 04:13 AM | #17 | |
Rep 1,252
Docrace 6266
10-08-2015, 12:13 PM | #18 | ||
Rep 1,349
Drives: BMW F80 M3
10-08-2015, 03:35 PM | #19 |
Rep 171
10-08-2015, 03:53 PM | #20 |
Rep 171
If you want to cool IAT's you should use meth. That is a big misconception.... Water will cool the cylinder better than meth, not IAT's though. 100% water will def cool IAT's but a 50/50 mix will work better. Do some testing when you get up and running and you will see
10-12-2015, 12:42 PM | #21 | |
Rep 1,252
cm3 250-300cc/m , 2cm3 = 500-600cc/m cm5 280-340cc/m , 2cm5 = 560-680cc/m only 12%+ flow versus less atomization.
Docrace 6266
10-12-2015, 01:01 PM | #22 |
Rep 1,349
Drives: BMW F80 M3
Hmm looks like the small nozzles still flow a bit. From CM7 and up the flow size increase is more. You should be good with 2x CM3. Or go 3 nozzles and put a custom one pre FMIC
