09-10-2015, 03:11 PM | #1 |
Rep 225
m6 paddles on m235i?
I've heard a few members convert their F30 paddles to m6 ones, and was wondering if it could be the same for our cars? I personally like the m paddles better than the stubby ones ours comes with.
2015 ///M235i | Alpine White | 8AT | RW Carbon Front & Rear Lips | Autotecknic Paddles | MP Side Decals | AWE Axelback | Shifteck DP | MHD Stage 2+ | BMS Intake | FTP Charge Pipe | VRSF FMIC
09-10-2015, 06:49 PM | #3 |
Rep 225
How hard was it to do? I'm assuming the whole steering wheel had to come off?
09-10-2015, 08:13 PM | #4 | |
Rep 869
09-11-2015, 02:41 AM | #5 |
Rep 4,516
I had old style m sport wheel so upgraded to new m sport wheel when I changed my paddles and also fitted M4 trim to the steering wheel
http://www.babybmw.net/viewtopic.php...addles#p831179 Mines the blue car in the thread in the post above. Process is easy enough 1. Remove earth lead from the battery 2. Remove airbag - very easy on new style wheel but a PITA on the older style wheel 3. Remove steering wheel 4. Remove trim - easy - to access bolts holding paddles in place 5. Disconnect paddles from loom - easy 6. Remove 1st paddle and replace with new M3/M4 paddles [direct swap] or if using M5/M6 paddles you have swap over the M paddles onto your existing paddle body - means remove paddle hinge pin swapping paddles and putting pin back in 7. Repeat #6 above for the second paddle 8. Connect both paddles to loom 9. Put trim back into place 10. Re-install wheel 11. Refit airbag 12. Reconnect battery Go have fun with new paddles !!! BP
Current '22 X3M LCI.. |
BodegaBay27.00 |
09-11-2015, 10:35 AM | #6 |
Rep 225
Does this mean that we could get away with just buying the paddles and not the full body?
09-12-2015, 10:56 AM | #8 |
Rep 449
Yes, but the paddle kit is about $500!
'17 F80 (RET)
'14 F22 M235i (RET) '11 E90 335i (RET) '07 E92 335i (RET) '89 E30 M3 (RET) |
09-14-2015, 07:17 AM | #9 |
Rep 4,516
Maybe if you buy new from dealer but lots of oem options $200-$300 via online auction sites.
Seek and ye shall find !!!!
09-14-2015, 09:43 AM | #10 |
Rep 869
Part number or what to search just for the pedals?
09-14-2015, 10:03 AM | #11 |
Rep 4,516
Best source of reference for part numbers is Realoem. For example here's what I found for M6 paddles item 5.
http://www.realoem.com/bmw/enUS/show...diagId=61_3013 By clicking on actual part number it will also tell you what other vehicles use same parts - confirming M5/M6 paddles are the same. http://www.realoem.com/bmw/enUS/part...&q=61317847210
09-14-2015, 10:53 AM | #12 |
Rep 869
M4 ones the same part number? 61317847210
As it seems like the m4 ones are easier and cheaper to switch over... As it's the same steering wheel
09-14-2015, 08:53 PM | #15 |
Rep 869
So basically the same procedure for both just different part numbers?
09-15-2015, 03:34 AM | #16 |
Rep 4,516
No M4 paddles are easier as they are a straight swap
09-15-2015, 04:39 AM | #17 |
Rep 1,215
it`s a difference of 5 minutes labour. so if there is a chance to get m5/m6 paddles cheaper, then go for them!
MANHART MH2 400 Partout FS: MANHART MHtronik Tuning Box http://www.2addicts.com/forums/showt...5#post18819345 |
09-15-2015, 05:01 AM | #18 |
Rep 4,516
+1 on the above ^^^^
09-15-2015, 10:08 AM | #19 |
Rep 869
All seem to be the same price... Can't find any 2nd hand ones
09-16-2015, 05:22 AM | #20 |
Rep 4,516
Patience and German ebay are essential for used oem upgrade parts at sensible prices.........
09-16-2015, 04:46 PM | #21 |
Rep 225
Good advice! Just ordered a set for ~100 USD!
