07-27-2020, 02:01 PM | #1 |
Middy2000
50
Rep 150
Wheel Spacers
I know its been discussed before but I'd like to gauge opinion on wheels spacers.
From previous reading it seems 12mm front and 15mm rear seems to be fairly well received. For whatever reason that doesn't seem to be a combo that is readily available here in the UK. 12/20 however is. What's the thoughts on 20mm on the rear. For a start does that actually fit? I'm running stock 18's and tyres. Am I prone for it rubbing or will it look just plain stupid? Also how about 15/20? Last edited by Middy2000; 07-27-2020 at 02:10 PM.. |
07-27-2020, 02:47 PM | #2 |
Rep 1,276
Interesting. Can someone actually post a photo running on 20mm spacers? If possible
*** TAX SALE *** Get Cashback When You Order This Month! ** Check Out Our Sale Section!
Phone 725-221-5267 || website www.x-ph.com |
08-05-2020, 07:52 AM | #4 |
Rep 44
ML Performance are selling 12 and 15mm H&R spacers.
Haven't heard anyone run 20mm in the rear. |
BetweenTheWheels81.00 |
08-05-2020, 08:35 PM | #6 | |
Rep 1,290
08-06-2020, 07:02 AM | #8 |
Rep 31
Hi iv-128i,
I am interested in spacers for the look but am concerned about handling. Do you experienced changes in handling after mounting spacers ? Any poke in the rear with 15 mm ? Udayan |
10-17-2020, 07:01 PM | #13 |
Rep 251
10-19-2020, 03:45 PM | #14 |
Middy2000
50
Rep 150
I'll take some pics soon.
I fitted longer bolts that came as part of a kit. Got to take them all off again as when I went to fit them I couldn't find my copper grease. I used some motorbike chain wax as a temp measure. About an hour later I found the copper grease! |
10-19-2020, 05:57 PM | #15 | |
3708
Rep 3,621
As you may already know (so I will be preaching to the choir if that is the case), the bolt threads need to be clean and dry to be torqued to the correct value, lubrication or anti seize will cause them to be over torqued by a variable amount due to the different properties of various lubricants, but it could be anywhere from 30 to 60% with oil typically at the low end of over torquing, grease in the middle and graphite at the high end. |
10-19-2020, 07:30 PM | #16 |
Rep 43
Here's 12mm up front with Apex 90mm stud kit. I fitted 15mm up front too and rubbed slightly on full compression (Dinan springs). With light/moderate camber I don't think it would be much of an issue, but I'm also running the upper limit (225/45) tire on a 7" wheel. I agree with others 15mm rear is the max/best choice.
Current - '15 228i
PDM5150.00 |
10-20-2020, 01:30 AM | #17 |
Middy2000
50
Rep 150
The bolts went in clean yes. Good info reference over torquing though.
When I remove them I'll check to make sure there is no seepage onto the bolts. If so I'll clean them. Out of interest what's the recommended torque? |
10-20-2020, 10:02 AM | #18 | |
3708
Rep 3,621
An interesting article on wheel failures from a forensic accident investigator, indicating that over torquing is the main cause of wheel loss from a vehicle, and of that set lubrication or use of anti seize on the studs or bolts is a leading cause of over torquing: http://www.crashforensics.com/wheelandhubfailures.cfm |
10-27-2020, 07:39 PM | #19 |
Driver - Autocross
75
Rep 178
Fwiw I run 15 in the rear and 5mm up front. The rear does put out of the fender.
16 M235xi 8ZF Black on Red FBO: Xhp trans tune -BMS Intake - VRSF Catless DownPipe - VRSF CP - VRSF Muffler delete/resonator - n22 plugs - MHD stage 2+ 95map - Wagner EVO II Preformace IC - Rear seat delete - weight reduction/stripping -FTP 18.5in rims - Hawk HPS front pads - StopTech STR 660 fluid
