2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning JB4 map 2 17lbs of boost...?
      05-30-2016, 09:40 PM   #1
Drpoomanchu
Drpoomanchu's Avatar
Drives: AW M235i Man FBO
Just wondering if it is normal to hit 15lbs of boost on Map1 and 17lbs on map2. I posted today on N54tech awaiting some answers. My mods are, Dinan intake ER catless DP. Armytrix exhaust. JB4 OBD2 w/ rev 3 bluetooth. FF wires connected 93octane gas and EWG wires not connected. Waiting for FMIC to connect. I have been on map 1 for the majority because TBH I thought i was on map 2 this whole time. After checking my first few logs it was showing hitting 14.6 lbs or so and thought that seemed right for map 2. Throw me ur 2 cents. Thnx
Here is the link to N54tech for a few .csv files, 4th gear pulls http://www.n54tech.com/forums/showth...379#post473379
      05-30-2016, 10:51 PM   #2
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Yes its fine
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      05-31-2016, 11:33 AM   #3
BentZero
BentZero's Avatar
Dang, that's almost double stock boost. I'm guessing that the N55 can handle it. It just seems a bit intimidating to neophytes such as myself.
Build thread
      05-31-2016, 04:46 PM   #4
Drpoomanchu
should i be running partial E85 blend for Map2 then if its hitting 17psi. do these EWG's creep or is it consistently adding boost through the powerband as appropriate purposely ? I was under the impression that 93 alone was not enough to properly support this much boost.
      05-31-2016, 05:03 PM   #5
Luminous
Luminous's Avatar
743
Drives: 2019 M5 Competition
You should be posting this in the n54tech.com forum, post some logs in the support section and BMS should chime in.
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      05-31-2016, 05:15 PM   #6
allthatisntnow
allthatisntnow's Avatar
United Kingdom
377
Drives: BMW M2C, 991 C2
The logs will show you boost against rpm. Its a progressive ramp up. Logs need to be 2000 rpm to redline then a few hundred rpm in the next gear with dsc off. Use 3rd into 4th if you only have quiet public highway at your disposal to keep things semi legal. 4th has you over 120mph at redline. Plus ensure 100% throttle is applied straight from 2k rpm and hold it there till red line and don't lift. Your logs aren't hitting wot for long enough if at all (pedal is at 100 but throttle isn't for long) to get true boost readings. I had this issue with my first logs too as its too tempting to want to lift asap.
Edit: You need to connect your ewg wires. Log in map 5 too to find out what the car is comfortable with. The guys at n54 tech will sort you out though don't worry. Great support there.
      05-31-2016, 07:49 PM   #7
Drpoomanchu
thanks for the help. much appreciated. i will do that asap.
      05-31-2016, 08:13 PM   #8
pimp4cheddar
El Capitán
pimp4cheddar's Avatar
Drives: BSM X3M
Damn...didn't realize the tune is pumping that much boost.
Is that a recommended safe map (map 2) to run everyday?
      05-31-2016, 08:46 PM   #9
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
+1
n54tech.com/forums/usercp.php
It's not a lot of boost for some, map2 is recommended for those with downpipes, or 93+ octane better and blends of E85
IG: @bmwF9XG80
      05-31-2016, 09:35 PM   #10
pimp4cheddar
El Capitán
Drives: BSM X3M
Originally Posted by ROBNYC View Post
+1
I guess I need to bite the bullet and start reading around that forum...thanks man.
      06-04-2016, 08:46 PM   #11
Drpoomanchu
thanks guys, I appreciate the guidance. I got the EWG tied in today and as soon as I get good weather plus time I will do a few pulls and post to N54tech. If I implement 2 gallons of E85 with 93 should I step my plugs down 1 heat range or go with the stockers for now?
      06-05-2016, 10:06 AM   #12
Drpoomanchu
Ok... So i got a few today to get a few pulls in on map5 straight 93... I tried my best with car sport+ 2000-6300 RPM. These should be much better logs than my previous thanks to ALLTHATISNTNOW. Im just curious why the car in pedal is 100% but throttle isnt..? Looks like boost was tapered back and drops off at points not sure why. AFR looks good but i cannot read the timing which i hear is more important. I will repost on N54tech and see if someone replys. Thanks again guys and if anyone wants to chime in feel free
      06-05-2016, 08:43 PM   #13
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Make sure you're on latest firmware which us currently 7 for EWG.
Do 2 logs on map2 and 2 for map5
Post it on jb4 forum
IG: @bmwF9XG80
      06-05-2016, 08:44 PM   #14
Drpoomanchu
Thnx, i just posted 2 pulls in map5 and no response... Not sure why they wont reply... I guess im not posting something properly :
      06-08-2016, 11:30 AM   #15
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
N54 guys run nearly 2.5X stock boost.
17 is no big deal for the N55.
If you aren't posting your logs on a datazap.me nobody is going to bother opening up the files and doing the dirty work.
Upload to datazap.me it's not only easier for you to read but for everyone else too.
      06-08-2016, 01:40 PM   #16
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
Actually there prefer you attach .csv files directly to your post. They do not want you to use datazap or other file hosting sites.
      06-08-2016, 03:21 PM   #17
They as in who, BMS? Cause nobody else here prefers it attached.
      06-08-2016, 03:37 PM   #18
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
BMS and most on n54tech. I thought that was what we were all referencing here. In fact BMS will not even look at your logs if it's not attached as a .csv
2addicts doesn't allow .csv attachments.
      06-08-2016, 08:17 PM   #19
Drpoomanchu
Steve replied to my logs and said all looked normal but could use some octane. I added 2gal of E85 to roughly 11.5 gal of 93 and tried some 3rd gear pulls today...looks like its targeting around 15-16 psi. Feels smooth and power comes in nicely. I will post them soon on N54tech. Next fuel up ill try closer to 2.5 gal of E85 to 11-11.5 gal 93 and see how she likes it..
      06-09-2016, 09:32 AM   #20
BentZero
BentZero's Avatar
Sorry for the n00b question, but where do you get E85?
Build thread
      06-09-2016, 10:21 AM   #21
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
I get mine at various gas stations in my area from the pump.
Google "E85 locator".
      06-09-2016, 10:23 AM   #22
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
If can post a link to your log on n54. I would like to look at it to further my learning of JB4
Edit: Nevermind...see you posted it in the first post now. I saw your logs over there the other day.
