06-12-2016, 09:36 AM | #23 | |
Gettin It Figured Out
1820
Rep 2,669
my apologies, I misread your post....I thought you were referring to the newly released Dinan LPFP. You're correct, Fuel-It is THE go to in LPFP's for the N55 .
06-12-2016, 09:54 AM | #24 | |
Rep 2,363
Follow my builds:
06-12-2016, 05:07 PM | #25 | |
Rep 4,515
http://www.realoem.com/bmw/enUS/part...231&series=F22 Might be worth replacing your broken Oem HPFP with this new Oem type....
Current '22 X3M LCI.. |
06-12-2016, 11:03 PM | #26 | |
Rep 2,363
Follow my builds:
06-12-2016, 11:11 PM | #27 | |
Rep 2,363
Follow my builds:
06-13-2016, 02:55 AM | #29 |
Rep 40
Drives: Alpine white, Coral red M235i
interesting..... does anyone have more information about new HPFP's if they are rated better than the one it replaced... a data sheet or something?
2014 M235i AW 8AT,
ER: FMIC & DP & CP , BMS: JB4 EWG(OBDII) |
06-13-2016, 11:31 AM | #30 | |
Rep 4,515
No datasheet or product info only that the part nr I quoted above is whats used in M2 so should be capable of working at higher boost/torque. If BMW M2 HPFP are failing then no doubt BMW will have an OEM fix as a QEP or similar recall that should also be retrofittable on Mx35i's and F3x N55's....
06-13-2016, 12:38 PM | #31 |
Rep 1,084
I tried to get them from a Bosch distributor, but he told me the specs are held confidential between BMW and Bosch.
06-14-2016, 02:00 AM | #32 |
Rep 40
The struggle continues
2014 M235i AW 8AT,
06-14-2016, 02:03 AM | #33 | |
Rep 40
2014 M235i AW 8AT,
06-14-2016, 03:18 AM | #34 |
Rep 4,515
Suppose the idea of mounting M3/4 twin vacuum pump c/w 2 x HPFP's, HPF rail and ancilliary plumbing to connect lines from HPFP's to HPF rail has been ruled out ????
06-14-2016, 10:47 AM | #35 | |
Rep 1,541
Now if there was a drop in OEM style solution I wouldn't mind spending a little more $$ for that. |
06-14-2016, 01:00 PM | #36 |
Rep 1,084
Yes, because you also have to put together the electronics to regulate the 2nd pump.
06-14-2016, 02:00 PM | #37 | |
Rep 1,349
Drives: BMW F80 M3
06-15-2016, 01:50 AM | #38 |
Rep 4,515
Looking at how the m3/4 vacuum pump is configured it's similar to n55 unit but with 2 HPFP "ports" as opposed to one.
Plug in connection into vacuum body is the same part between S55 and n55 so not sure what electronics are needed to control a 2nd pump when they are driven off same drive shaft within vacuum pump body. Both HPFP then tie into the same fuel rail so HPF sensor and regulator sees and controls rail pressure in the same way surely ?
06-15-2016, 10:56 AM | #39 |
Rep 1,084
a picture is worth a thousand words:
http://www.atasoyotomotiv.net/image/...OR-800x680.jpg the shot above illustrates that the pump has an electrical connection for regulation on the S55, the pumps are regulated separately, and one is secondary, engaged sequentially by the DME more pics: https://www.google.com/imghp?hl=en&q=bosch+hdp+5
06-16-2016, 02:44 AM | #40 |
Rep 4,515
RW,
Good info, Thanks. Sounds like it could be a right royal PITA to do any upgrade using OEM parts. BP
06-17-2016, 02:02 PM | #41 | |
Rep 40
You see for me and i'm sure for alot of guys we dont have access to ethanol or bio fuel at all. So we NEED THIS SO BAAD lol |
06-17-2016, 02:05 PM | #42 | |
Rep 1,084
it's the same reason we'll never see tuners build something to let us run the S55 fuel pumps on the N55: they're flogging PI systems
01-04-2018, 08:11 AM | #43 | |
Rep 4,515
http://www.xtreme-di.com/index_files/HPFP35.htm
01-04-2018, 11:33 AM | #44 |
Rep 190
The HPFP on my previous car was also cam driven (aka CDFP; I don't know if there are any non-cam driven fuel pumps). If you were mechanically inclined, you could easily swap out the OEM internals of the pump for upgraded internals (<$500, iirc) allowing higher sustained flow/pressures.
It's too bad such an option doesn't seem readily available for us. |
