2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Amplified Chime!
      04-15-2024, 12:05 PM   #1
owenscj21
owenscj21's Avatar
53
Drives: 2016 BMW 228i M Sport
Amplified Chime!
So, I just had the following installed:
TechnicPNP 2/4 harness
JL VXi700/5
JL10W3V3-2
Audio Control LC5i
I already had already replaced the door and deck speakers with Focals.
I thought I had the true Base Audio (Canada), it turns out I actually did have the Hi-Fi system. We had to go with the LC5 as the voltage at the harness under the seats was 20V. The VXi amp could only receive 16V.
Install was done, checked over the system with the installer and left. ASD was there loud and clear. Ouch. Okay... so I coded it out. One problem down.
Now... somehow, I've got to deal with the amplified chime at start up. In idrive, chime volume is set to minimum. In Bimmercode, I see I can change the chime tone, not volume.
I've searched through the forums and haven't seen a solution. Does anyone know if there is one? Can it be coded off in expert mode?
Edit: SIGH. Nevermind...gains set too high
2016 228i M-Sport 6M RWD- CTS Intake, CTS FMIC, VRSF charge pipe, CTS catted downpipe, FTS Stage 2 ECU
