10-26-2016, 07:34 AM | #1 |
Rep 682
2 series jack
Dose anyone knows a "good jack" for m235? I'm trying to find something to be able to exchange my winter wheels by myself by I'm not able to find one
10-26-2016, 07:42 AM | #2 |
Rep 269
Jack:
http://www.harborfreight.com/3-ton-a...ump-62248.html Jack adapter puck: https://www.ecstuning.com/Search/Sit...pter/ES251251/ Mine is lowered on H&R and I can still get under the factory jack points without a problem. |
Maynard3848.00 |
10-26-2016, 08:28 AM | #3 |
Rep 5,577
I'd like to invest in one of these - but a little too extravagant
http://pitstopusa.com/i-5063762-brun...-jack-red.html |
10-26-2016, 12:29 PM | #5 | |
Rep 580
10-26-2016, 01:59 PM | #6 |
Rep 426
I've used this one for the last two years. Think it was on sale for $20 less when I bought it. It's always safe...just don't go under the car unless it's supported by jack stands. It's so compact, I never leave home without it.
http://www.harborfreight.com/15-ton-...ump-62160.html |
10-27-2016, 01:18 PM | #7 |
Rep 77
10-27-2016, 01:37 PM | #8 | |
Rep 5,372
If you're looking for a quality-cheap floor jack, look no further than the low profile 3 ton Harbor Freight for $175 plus the commonly available 25% coupon code. Plus a $15 jack pad from ECS or others. |
Tpeterson156.50 |
11-10-2016, 09:05 PM | #9 | |
Rep 119
11-11-2016, 11:29 AM | #10 |
Rep 100
I keep one of these in my trunk. http://www.ebay.com/itm/like/1319770..._noapp=trueE46 e46 jack. Works perfectly. Good for emergencies. For working under the car i use my Harbor Freight 1.5 ton jack and some good jackstands.
11-11-2016, 09:15 PM | #11 | |
Rep 393
(Insert don't ever work under a lifted car that isn't supported by jack stands here..) https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I also modeled a quick jack pad mount from some online specs, bought a 4 pack of hockey pucks and gave it to our CNC guy to quickly machine into perfect little jack pads... Only use it rarely and no need to spend a crapload on something you lose once a year until you find it. |
11-13-2016, 08:36 PM | #12 |
Rep 148
Look into QuickJack 5000 SXL. I bought one a year ago and use it a lot. (It fits under a lowered C7 ZO6). This is my first post on this forum since my wife swapped her 135i for an M235 last week.
2016 M235i convertible
2016 Mercedes AMG GTS 1966 Corvette roadster |
11-14-2016, 08:03 AM | #13 | |
Rep 1,247
The fact that it's compact doesn't mean it's only for emergencies... |
11-14-2016, 10:04 AM | #14 |
Rep 580
I'm contemplating buying one of these next Spring,when I take my car out of Winter storage. I glad to here from somebody who recommends it.
11-14-2016, 10:45 AM | #16 |
Rep 2,873
That quickjack looks like a very nice option, most of the functionality of a lift, w/o the massive expense. I'm going to be thinking about that quite a bit this winter - thanks for sharing the link. Does it lay low enough you can just stow it under the car (push them inside the wheel-track and drive over it)?
11-14-2016, 12:37 PM | #17 |
Rep 269
Yes, that's how several of the people I've seen in videos use it, actually. They push them inside the wheel tracks, drive over, pull out to the jack points and lift. I think it's got a minimum height of 3", so that's plenty low for most.
11-14-2016, 02:40 PM | #18 | |
Rep 5,372
Floor jacks on the other hand are designed for repeated use, are much much much stronger, and are far easier to lift a car. Most importantly, they are FAR safer at lifting a car. I have seen many instances of scissor jacks collapsing and/or falling over because they were either setup incorrectly, the e-brake not set (i.e. the car rolls slightly backwards), or weren't used on a perfectly flat and level surface. Emergency scissor jacks are great for emergencies. I keep one in my M235 at all times as well as a tire plug kit. It really doesn't make any sense to buy a $20 scissor jack for swapping wheels when you can buy a fairly decent 1.5-2.0 ton floor jack for $30-40. I have a $120 Harbor Freight low-profile jack and three $30-40 1.5 ton jacks. A 1.5 ton jack is small and lightweight. I'd suggest buying two floor jacks and a set of jack stands for wheel swaps and having a scissor jack in the car if you're experienced with installing temporary tire plugs. |
11-14-2016, 03:04 PM | #19 | |
Rep 1,247
http://www.harborfreight.com/15-ton-...ump-62160.html Scissor jack not found. |
11-14-2016, 04:41 PM | #20 |
Rep 148
I 'm seeing a bunch of interest in QuickJack. If you buy one, use 2x6s to fill the cavities in the lift platform and it becomes so much easier to use. (Especially on a BMW with the integral jacking blocks under it) Our car can be lifted to max height in about one minute after the engine is shut off.
