01-02-2017, 02:17 PM | #1 |
Rep 716
Drives: F90 M5
BMS intake CEL
hey guys so like the title says, i reinstalled my BMS intake and got a CEL i ran the code and it pretty much said that the MAF was reading too much air. Do any of you guys have suggestions or advice on how I can use my intake or why its causing a CEL?
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct Hmu on Ig: @n55_shayan |
01-02-2017, 03:18 PM | #2 |
Rep 780
Interested as well. Really want an intake but CEL kills me.
01-02-2017, 03:19 PM | #3 |
Rep 716
Drives: F90 M5
Yea i had the BMS on for a while with no problems at all then my motor seized from an oil pump issue and now i got the new motor and reinstalled the intake and got a CEL
01-02-2017, 03:26 PM | #4 |
Rep 780
Hmm that's strange- I guess the computers have personalities?
01-02-2017, 04:10 PM | #6 |
Rep 716
Drives: F90 M5
01-02-2017, 04:17 PM | #7 |
Rep 780
01-02-2017, 07:04 PM | #8 |
Rep 716
Drives: F90 M5
Well the intake shouldn't give a CEL anyway
01-02-2017, 09:43 PM | #9 |
Rep 1,303
Drives: 2021 C8 Corvette 1LT
Only suggestion I would have is removing the cone and making sure the area is clean where it meets the adapter and also from the adapter to the intake piping. Maybe something isn't completely tight so it's pulling in extra air from somewhere.
01-02-2017, 09:44 PM | #10 |
Rep 716
Drives: F90 M5
Okay ill try that. Thanks man
01-02-2017, 09:45 PM | #11 |
Rep 1,303
Np. Hope it works out for you. Really odd that it would be fine originally and now it's not. A motor swap doesn't change the ecu so it's not a difference if a computer
01-02-2017, 09:46 PM | #12 |
Rep 716
Drives: F90 M5
Yea thats why i was very confused
01-05-2017, 09:45 AM | #13 |
1006
Rep 1,653
It seems that the BMS intakes are hit or miss. I know people who have installed them, never touched it again and it worked fine. Other people have installed it and have gotten a CEL almost right away.
I have the BMS intake on my M235i and got the same CEL reading as you did. I noticed that there was a rubber grommet over the nipple right before the MAF sensor that was a little loose. I took a small zip tie, tightened it onto the nipple and I haven't had a problem since. Now I don't know if doing that is what solved the issue or it just ironically happened at the same time, but it is something you can try! |
01-05-2017, 02:37 PM | #14 | |
Rep 716
Drives: F90 M5
01-05-2017, 07:36 PM | #15 | |
Rep 191,093
Fabspeed Motorsport1005.50 |
01-05-2017, 11:47 PM | #16 | ||
Rep 716
Drives: F90 M5
01-06-2017, 12:26 AM | #17 |
Rep 1,303
Each engine is its own air pump. Not all motors are created equal so maybe this one pulls ever so slightly more air and that's why it's triggering? I'm not a scientist 😁
01-06-2017, 12:33 AM | #18 |
Rep 716
Drives: F90 M5
Idk honestly man
01-12-2017, 11:18 PM | #19 |
Rep 716
Drives: F90 M5
update: so i put intake back on again after the break-in period and put about 40-50 miles on it and so for havent gotten a CEL fingers crossed that it doesnt pop up anytime soon
01-13-2017, 01:55 AM | #20 |
Rep 1,303
01-13-2017, 03:52 AM | #21 | |
Rep 716
Drives: F90 M5
01-13-2017, 07:08 AM | #22 |
Rep 1,184
I had the same issue with my injen intake and got a jb4 which cleared the code. Then I unplugged my maf to run it maf less whichakes it run much more smoothly.
