2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Wagner intercooler options (Performance vs Competition)
      10-23-2014, 12:30 PM   #1
AlexGT
AlexGT's Avatar
Guatemala
420
Drives: G05 X5 MSport
Hey my friends, I've been reading about intercooler options from Wagner, there are two versions and the only difference I see between the "perfomance" and the "competition" is the weight (19.40lbs vs 14.55lbs) , the rest is the same (size, pressure drop, charge air volume) and its connection claims to be OEM plug and play.
So, if you were to buy this product, which one would you choose between these two?
In addition, does someone know what materials Wagner use on the "competition" version? I ask since both intercoolers have the same size so I'm concluding that the competition version is made from some lightweight material.
Thanks for the feedback guys
      10-23-2014, 02:05 PM   #2
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
2017 BMW F80 M3  [0.00]
Where are you from?
The competition fmic is tube and fin design, the performance is bar and plate. The tube and fin is lighter, it cools the iat a bit less however it cools better on the long run. The other one has more initial resistance to heat but once heated up it takes longer to cool down.
I have the competition fmic on the car.
      10-23-2014, 02:42 PM   #3
AlexGT
AlexGT's Avatar
Guatemala
420
Originally Posted by Darkhold View Post
Where are you from?
I appreciate your response Darkhold, I'm from Guatemala (Central America). Nice description of both intercoolers, it is very helpful, now I think I know I need to go with the Performance not the Competition, since we don't have many long roads in my country to justify to get the Competition and I won't be running the car long at high speeds, right?
      10-23-2014, 03:11 PM   #4
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
If you mostly do short pulls on public roads i guess the performance version is the one you want!
      10-23-2014, 03:34 PM   #5
AlexGT
AlexGT's Avatar
Guatemala
420
Cheers Dark, many thanks!!
      10-24-2014, 02:45 AM   #6
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
You are welcome! Enjoy the FMIC when you get it installed!
      10-24-2014, 10:47 AM   #7
AlexGT
AlexGT's Avatar
Guatemala
420
I will, once it finally gets in stock 'cause Wagner USA is on back order right now, sadly
