02-24-2014, 09:35 AM | #1 |
Rep 219
Has anyone driven a 6spd yet?
Wondering if anyone has driven a 6spd yet? I have one on order and was curious as to how the box felt, and how power delivery was through the gears.
2013 M3 Coupe Lemans Blue / 2014 X5 X-Line BSP/Terra / 2014 Ducati Monster 1200S
02-24-2014, 11:45 AM | #2 |
Rep 250
02-24-2014, 11:50 AM | #3 |
Rep 269
The 228i I have on order is 6spd, but it's a different transmission from the M235i and won't be here until early April.
But, according to ETK, the gearboxes for the 2 cars are as follows: M235i: GS6-45BZ-THY8(same as 335i) 228i GS6-17BG-TAU0(same as 328i and 528i) |
02-24-2014, 12:06 PM | #4 | |
4972
Rep 10,200
Drives: 2024 Golf R / 2022 718 Spyder
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
02-24-2014, 12:57 PM | #6 | |
Rep 269
**edit** Actually... same transmission, maybe same gear ratios, just different bellhousing? The last 4 digits are gear ratio and bellhousing, but what order? Last edited by Uridian; 02-24-2014 at 01:26 PM.. |
02-24-2014, 01:36 PM | #7 |
Rep 779
The above contradicts this quote from official BMW 2-series pdf:
Transmission A new 6-speed manual transmission will be standard equipment on both the 228i and M235i. The transmission has been borrowed from the upcoming M3/M4 and offers shorter throws and more precise shifting than the outgoing 1 Series 6-speed transmission |
02-24-2014, 01:43 PM | #8 |
Rep 269
That's true. I'm just pulling info from etk.cc, which could be wrong:
228i Manual transmission M235i Manual transmission Who knows. |
02-24-2014, 01:46 PM | #9 |
Rep 779
On the other hand maybe there is no contradiction, maybe the new M3/M4 unit is the same pedestrian one found in 335i, how disappointing.
The new WRX STI looks even more enticing now with its rod-actuated rifle-bolt MT. I hope I can get past the interior.. |
02-24-2014, 01:47 PM | #10 | |
Computer Janitor
Rep 272
Actually what would be hilarious is if both were true. It'd mean the folks buying manual F80 M3s are getting the same tranny from the F30 335i! As if the butthurt over the S55 being too closely related to the N55 wasn't enough!
2012 328i Sport Line 6MT (Turned In)
2015 Ford Mustang GT Premium (Current) |
02-24-2014, 01:47 PM | #11 |
Computer Janitor
Rep 272
I type too slowly.
02-24-2014, 01:53 PM | #12 |
Rep 179
Just test drove the M235 with 6 speed. I drive a 135i 6-speed currently and compared to that, the shifts feel shorter, there's slightly less resistance, there is a nice notchy click when you shift in, esp. into 1st. Its a noticeable improvement on what is already good. Felt like I could shift faster in the 2er.
02-24-2014, 02:08 PM | #13 | |
Geboren zu Fahren!
Rep 376
Drives: F25 X3
Now the question is, will there be any CDV "delay" in feel….. And if so, can it be removed like the "E" models.
2011 F25 X3 2.8 (in service)
2009 E90 328i (retired) 2007 E92 335i (retired) 2005 R53 MINI Cooper S (retired) 2002 E53 X5 3.0 (retired), 1999 E46 328i (retired) |
02-24-2014, 02:16 PM | #15 |
Rep 524
Sorry to get off-topic, but was the last STI tranny cable operated? I would think the shift lever would extend right into the gearbox (needing neither a cable nor rod), since it's right below the shifter, no?
1973 Porsche Carrera RS 2.7 Carbon Fiber (240hp & 1,890 lbs)
02-24-2014, 02:25 PM | #16 |
Rep 779
Keep your pants on. You fell victim (like myself and others) to BMW marketing's half-truth. Yes the transmission in M235i may be the same as in M3/M4 but what BMW didn't tell you is that it is the same transmission found in run-of-the-mill 335i/435i which is described as precise but rubbery.
02-24-2014, 02:28 PM | #17 |
Rep 779
The new WRX STI tranny is variously described as going straight into the gearbox or using rods. I don't know which is true but in either case it is still better than cables.
02-24-2014, 02:37 PM | #18 | |
4972
Rep 10,200
That is encouraging...my 6MT always felt nice in my first E82...if this feels better, that's a great thing.
02-24-2014, 02:47 PM | #19 | |
Geboren zu Fahren!
Rep 376
Drives: F25 X3
Hasn't that always been the truth about BMW manuals (precise YET rubbery!), but compared to other makes, I'll take it. I just want to make sure the clutch engagement improves. The CDV delete in my E92 made everything feel good. But nothing will compare to a Tremec TKO600 for shifting "feel".
02-24-2014, 05:25 PM | #20 |
Rep 219
I just hope it isn't like what i've felt in the f30/f32. They just felt exceptionally sloppy, especially the 328, the 435 was a bit better.
