07-27-2015, 12:49 PM | #1 |
Rep 187
Winter Wheel Setup Question
I am new to driving in the northeast. Just got my 228i and didn't opt for xdrive so I will be needing a winter wheel setup. What do most people do for their setup? New wheels AND tires? Just new tires?
Thanks in advance! |
07-27-2015, 12:56 PM | #2 |
Rep 6,026
Yes. Narrow 215/50-17 on low cost wheels, mounted, balanced, and shipped from tire rack.com is a great and easy way to go. Twice a year "pit stop" for a quick change. Suggest Blizzak WS80 for most capability on snow/ice or Michelin XIce-xi3 for almost as much but better dry road handling.
07-27-2015, 01:02 PM | #3 |
Rep 3,331
Get new wheels and tires. It is not cost effective or safe to be constantly switching tires. For the amount you would spend on mounting/remounting every spring/fall you can get some cheap beater wheels off Tirerack that will take the salt and potholes.
In my case, I am going to run the factory 18's (my car came with the square wheel all season setup) and put dedicated winter tires on them until the end of the lease. Swapping wheels yourself is extremely easy and all you need is a jack and a torque wrench. I do it myself in under an hour...usually takes me longer to deep clean the wheels before I put them away in storage. Given how bad Boston got hit last year, I would consider leaning more towards a dedicated snow tire rather than a high performance snow. Dedicated snow tires will be better in the nasty stuff but sacrifice more during the dry. In my case, I don't have to work on days that it snows and also have my wife's SUV when needed, so I only need snow tires for short local trips, or the occasional chance of getting stuck driving through a blizzard.
Current: '20 X5, '18 M3 ZCP
07-27-2015, 01:06 PM | #4 |
Rep 6,026
I'm using my iPhone so search for a thread titled "Winter Boots!"
EDIT: Got home and had a chance to find it..... http://www.2addicts.com/forums/showt...inter+boots%21 Last edited by Sportstick; 07-27-2015 at 08:03 PM.. |
07-28-2015, 05:36 AM | #5 |
Rep 321
I'm in RI. I bought a cheap pair of sport edition wheels 17"x7.5 AS7s I think and General Altimax Arctics. I went the cheapest route possible so I didn't give a crap about keeping the wheels clean in the winter. Also people swear by the blizzacks but these cheap general tires have been great. PLUS theyre so cheap cheap I don't mind doing a ton of rwd shenanigans. I dd my rwd 228 straight through the winter. Haven't gotten stuck yet and climbs hills great where my wife's jetta can't.
You'll want 17" in the winter here..as you know the roads are garbage. The extra sidewall is welcomewelcome in the winter. If you've got the track package I think the larger brakes further limit your 17" wheel choices. I have an m sport no track pack and there isn't a whole lot of clearance. Barely enough for me to force my wheel brush through. Where are you located? http://www.2addicts.com/forums/showthread.php?t=1089665 Last edited by mfourn20; 07-28-2015 at 05:44 AM.. |
07-28-2015, 11:19 AM | #6 | |
Rep 148
07-28-2015, 12:12 PM | #7 | |
Rep 3,331
I've had no issues with any of my wheels on either of my BMW's. Unscrew, take the wheel off, stick the new wheel in place and line up the holes, and stick the bolts in.
07-28-2015, 12:39 PM | #9 | |
Rep 5,262
you can always use a wheel pin if you can't align them... |
07-28-2015, 12:52 PM | #11 |
Rep 6,026
Some of Tire Rack's approved local installers will do the pit stop for you and store the off-season tires, so it's quick, clean, and easy! Storage fees are usually quite low.
07-28-2015, 12:54 PM | #12 |
Rep 6,026
07-28-2015, 12:57 PM | #13 |
Rep 557
From my past experiences, most aftermaket wheels have a large center bore to fit variety of vehicles, and that always ends up causing all sorts of vibration issues, not to mention extra stress on the lug bolts.
07-28-2015, 12:58 PM | #14 |
Rep 6,026
Understood. Never had that problem with wheels I bought from them over many years/cars.
07-28-2015, 01:05 PM | #15 | |
Rep 557
http://tires.about.com/od/understand...ric-wheels.htm |
07-28-2015, 02:08 PM | #16 |
Rep 1,115
07-28-2015, 04:38 PM | #17 |
Rep 557
Interesting, I will have to try it when the winter season comes. I have a set of e90 17's with winter tires that I use on my daughters X1 during winter - if they fit I may get another set for the 235.
07-28-2015, 05:11 PM | #18 |
Rep 3,331
Check the offset. Depending on the side the offset may make them poke out too much.
07-28-2015, 07:25 PM | #19 |
Rep 148
07-28-2015, 07:53 PM | #20 |
Rep 53
A wheel pin hanger makes life so much easier.
To the OP... I bought a set of Pirelli Sottozero 3 tires last winter and was very pleased with them. Tire Rack will tell you what wheel/tire combos will fit your vehicle. |
07-28-2015, 10:09 PM | #21 |
Rep 49
I live in Calgary Alberta. I have a 228 and run 215/50/17 Blizzacks. I like the extra sidewall for the winter and these tires are unreal (WS 80). No need for X Drive.
07-29-2015, 05:24 AM | #22 | ||
Rep 281
I didn't know about wheel pins, but I found it easy to sit under the wheel, put the wheel in between my legs and then use my legs to lift it up to get one bolt in. |
