2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack fitment help
      07-12-2023, 01:07 PM   #1
n55david
n55david's Avatar
Drives: 2017 m240i, 2015 X3 x35i
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
fitment help
Stock m suspension 17 240 Coupe.
Looking at wheels that are 18x8.5" +32mm
Will this work with 225/40 front and 255/35 rear using extremecontact dws 06 plus tires?
Will it need a spacer or any where alignment changes?
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      07-24-2023, 10:39 AM   #2
SpencerC_6MT
SpencerC_6MT's Avatar
Drives: '17 M240i 6MT
2017 BMW M240I  [0.00]
FWIW, I just installed 18x8.5 ET35 on 245/40/18 Continentals. Camber plates adjusted to -2.3f, -1.7r. The top of the rear tire pokes a few mm from the fender, and the front barely fits. Not sure if the rear is scraping, but I'm assuming under high enough load it will. The front scrapes occasionally under high load with the wheels turned.
Point here is that I'm on similar wheels to you, and they rub with reasonably high camber. Your fronts will likely be alright, but the rears are going to poke out considerably. This car clearly prefers higher offset, I'd suggest looking for an ET40 set if possible. Camber plates are mandatory, and you might need to make compromises on treadlife to fit.
2017 BMW M240i 6MT Slicktop | Wavetrac 3.46:1 Limited-Slip Diff - DinanTRONICS Sport Boost Controller - H&R Sport Springs - Millway Street Camber Plates - Agency Power Intake w/ Paradigm Engineering Turbo Inlet
      09-07-2023, 12:10 PM   #3
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
I don't care about it poking out at all tbh.. id rather is poke put and fit than to run a bunch of camber to make it work..
      09-17-2023, 02:44 AM   #4
SpencerC_6MT
The +32 offset will make yours poke 3mm more than mine, which although marginal, might require a -0.1 more camber to fit comfortably. More problematic are the 255's. That extra width may be killer. Your saving grace might be that they're smaller diameter, so the extra suspension travel before the tires are level with the fender might move them inward enough to clear. Personally I'd look for alternatives with an ET40 offset instead, but if you're willing to take a risk, there's a chance you'll clear.
