2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics The "Official" F22 OBD2 wireless adapter / Android+Torque / iPhone+DashCommand thread
      03-18-2015, 09:01 PM   #89
Nutballa
Nutballa's Avatar
Drives: BMW F13 M6 // BMW F22 M235i
M235i came in and took delivery! Ordered wifi geek!
BMW FTW!
"Power is nothing without Control" - Pirelli.
      03-22-2015, 02:13 PM   #90
Nutballa
Nutballa's Avatar
Great news everyone!
Wifi OBD2 work on 2015 F22 M235 and my F13 2014 M6 Cabrio!
I tested it on both cars and the Wifi OBD and Dashcam app worked for both.
BMW FTW!
      03-23-2015, 04:58 AM   #91
Zooks527
Are you reading Oil Temp?
      03-23-2015, 04:48 PM   #92
scottomfg
scottomfg's Avatar
287
Drives: '14 Cayman S 6MT, '21 X5 45E
Had a chance to use my set-up on my new M235i today, and it worked great. Read both Oil and Coolant temp. My OBD Wifi adapter is the old version of this one (LYL brand), and looks almost exactly like this one. I use the OBD Fusion app.
Once set-up, which consists solely of connecting to the wi-fi network the adapter creates, it auto-connects on start up, and all you have to do is launch the app and tap connect and in a few seconds you are good to go.
2014 981 Cayman S 6MT, X73 Suspension, SES
2021 X5 45e MSport, Manhattan Green, Coffee Merino, Review & Photos
Previous: '18 340 GT, '15 M235i 6MT, '15 i3 REx, '15 x1 xDrive28i
      03-23-2015, 11:37 PM   #93
Nutballa
Nutballa's Avatar
I'm still learning how to use the DashCommand app. I'm not sure where to find oil temp.
BMW FTW!
      03-23-2015, 11:38 PM   #94
Nutballa
Nutballa's Avatar
This one looks simple and nice. I will have to get this app also.
BMW FTW!
      03-26-2015, 12:16 PM   #95
nike001
Drives: 2018 718 Cayman
Same here. If you find it let me know because I feel like oil temp should be on the main screen - I don't care as much what intake temp or even boost is compared to oil temp
      03-30-2015, 11:15 PM   #96
M2-BM35i
Drives: M2Comp
I just got my obd2 adaptor yesterday!
Going to plug it in today & really hoping all gauges going to fire up nicely
Now I know you can't / mustn't use this in conjunction with jb4...
But how about in conjunction with the piggy back tunes?
Such as racechip, and BMS s1?
      03-30-2015, 11:17 PM   #97
M2-BM35i
Drives: M2Comp
Would love to hear from the more technical guys on this and who have installed these already with the tunes?
      04-01-2015, 11:09 PM   #98
Nutballa
Nutballa's Avatar
I couldn't find oil temp on DashCommand. OBD fusion app has oil temp so I will download that.
BMW FTW!
      04-15-2015, 09:46 PM   #99
Milkee_0923
Drives: 2014 BMW M235i
Can this app clear codes for running catless downpipe?
      04-19-2015, 07:45 AM   #100
Dog Face Pony Soldier
2006 TIME Person Of The Year
Dog Face Pony Soldier's Avatar
Drives: M Sport 335i
2014 335i  [9.74]
Don't you have oil temp in your gauge cluster?
      04-19-2015, 08:44 AM   #101
Zooks527
Nope. There isn't one one the 2-series.
We do get multiple versions of gas economy, though.
      04-19-2015, 12:48 PM   #102
scottomfg
scottomfg's Avatar
287
A quick update on this set-up. I'd been using this off and on for a few weeks, works great. However, I didn't drive me car for three days while it was plugged in, and when I started the car again, while it started fine, it did give me a warning about how something in the car was drawing power while it was shut off and that it could potentially be a problem. Based on this, I won't be leaving it plugged in all the time, since I now know it's drawing a decent amount of power all the time.
YMMV.
      04-25-2015, 10:32 PM   #103
Supernaut
Little Deuce Coupe
Supernaut's Avatar
Drives: SO M2C
Originally Posted by Mattgfx View Post
I use this adapter:
BAFX Products - Bluetooth OBD2 scan tool
http://amzn.com/B005NLQAHS
Works great with Torque and i will test it with BMWhat soon. This thread seems a bit uncompleted and some of the adapters you listed are very limited..
I've had the same adapter from BAFX working with Torque on my RX-8 and now on the M235 on an older Samsung/Android. It does read both coolant temp and oil temp in addition to a range of other parameters. I have it set in the ashtray area with the power cable running under the center console from the rear console power socket.
It's pretty easy to tweak fonts and colors in Torque, just using a text editor.
Now I just have to figure out the alarm points for temp as they are much higher than my RX-8.
ex: 2004 Thermonuclear Yellow RX-8|6MT
ex: 2015 Estoril Blue M235i |6MT|slicktop|MP exhaust - PCD
2020 Sunset Orange M2C|6MT|Black 788s
      04-26-2015, 06:29 AM   #104
Zooks527
"Normal" oil temp in an N55 is ~240degF. IIRC, this is the point where the thermostat on the oil filter housing opens and sends oil to the secondary cooler. Limp mode will kick in at ~280-300degF if the E90 series is any indication.
      04-26-2015, 01:31 PM   #105
Supernaut
Little Deuce Coupe
Supernaut's Avatar
Drives: SO M2C
It's good to get some correlation from others. I've been seeing 240 F coolant and oil temps with regular driving, while in my RX-8, 220 F (no oil temp) was considered pushing your luck. I have to recalibrate my brain.
This morning, I did find a few years old N55 reference (pre N55B30o0) that listed temps for system protection:
Component protection
-coolant temp between 117C and 124C (243F to 255F)
-engine oil temp between 150C and 157C (302F to 315F)
-result: output of the air conditioning system (up to 100%) and of the engine is reduced.
Emergency
-coolant temp between 125C and 129C (257F and 264F)
-engine oil temp between 158C and 163C (316F and 325F)
-result: the power output of the engine is reduced (up to approx 90%)
I'm trying get Torque's display to match the car's somewhat. I'm going on a compromise between day and night modes. The cabling tucks under the front tray mat without popping it up, but I couldn't run it through the ashtray hole on the passenger side because there's some plastic under it. A smaller right angle cable would be less intrusive, but this one's thickness keeps the phone from sliding. The oil gauge is blinking due to "low temp" so it looks like the needle or reading is missing in some pics. The 240 "red zone" for coolant will probably get tweaked some as well.
      04-26-2015, 03:49 PM   #106
Zooks527
What's your build date?
It's outstanding that Torque is showing you oil temp. It was unsupported on my E92, and I've seen some people get it / some not on an M235i. I'm wondering if there's a build date where the ability to read it with Torque turns on / off.
      04-26-2015, 03:52 PM   #107
Supernaut
Little Deuce Coupe
Supernaut's Avatar
Drives: SO M2C
It's a 2/2/15 car. I had read where some people couldn't read oil temp, but wasn't sure if it was just the adapter or something not encoded. The lack of temp gauges was a sore point with me, so I'm quite happy about this.
      04-26-2015, 07:03 PM   #108
Zooks527
Well, wait 4 weeks and we'll get a datapoint for a 4/7/15 build car with a BMWhat OBD adapter.
      04-29-2015, 11:05 AM   #109
///Mobbin
///Mobbin's Avatar
1478
Drives: m3
Has anyone confirmed that coolant and oil temp display in Harry's LapTimer?
I'm sure it will work but curious if someone has tried it already.
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
      05-11-2015, 10:30 PM   #110
Blackcross
Blackcross's Avatar
Drives: Estoril Blue 2014 335i xdrive
ELM327 + Torque Pro and no oil temp
Anyone used it other than me?
Using Torque Pro on a Galaxy S2 over BT with the ELM327, and I do not get Oil Temp. Other than that, works great: instant setup and easy connect with Android/Torque Pro.
My car is Nov 2013.
Cheers,
2014 Estoril 335i xdrive 6sp: M Sport, m perf power/brakes/sound kit, AA8 400 hp/ 420 ft-lbs. 10/15mm spacers. Dinan 3/4" spring kit, Misc coding. Mud flaps.
Racing/tuning/teaching since 1997. Long list of clubs as Chief, classroom and in-car instructor.
