2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum What did you do to your 2 series today?
      04-08-2019, 10:24 AM   #2245
BEM-S4
BEM-S4's Avatar
Originally Posted by bmtespar View Post
Originally Posted by happyjack View Post
Originally Posted by BEM-S4 View Post
It just looks out of place being out of scale, if you want to go down that rabbit hole I'd suggest getting a stock one and painting it black. IND can help you if you don't want to DIY. That said...
I think you're infinitely better off debadging entirely and getting a black spoiler. GF has a red 3-series with the OEM CF spoiler, debadged, and it looks great. Black grilles and mirrors.
could also add the black gloss sportline bumper trim
https://www.ecstuning.com/b-genuine-...xoCpJQQAvD_BwE
My car is an m sport (with m badges all over it) I don't think this will fit.
Check on eBay Sun BMW has an authentic black M3 badge for $35. You could just use the M and it will undoubtedly be the best quality solution for you.
      04-08-2019, 11:18 AM   #2246
bmtespar
bmtespar's Avatar
Drives: 19 X3 30i, 18 230iX Vert
I need to measure the height of my stock digits. The one I ordered was actually for an M2 so I assumed would be the right scale. I did resist the urge to use the black "2" so I should at least get points for that. 😉
Current: 20 M340i
Sold: 19 x3 30i X drive, 18 230i X drive Convertible
18 x3, 30i X drive 16 428i Convertible, 16 X1 X drive, 14 i3 Rex, 14 328i, 14 x1 28i X drive, 08 328i, 03 M5, 99 323i Convertible, 00 z3 M Roadster, 99 328i, 00 323i
      04-08-2019, 11:24 AM   #2247
BEM-S4
BEM-S4's Avatar
Call Brian and ask him, you can always return it if he tells you it'll fit and it doesn't. Since it's an OEM part I'd be more optimistic vs who knows what source.
      04-08-2019, 11:49 AM   #2248
bmtespar
bmtespar's Avatar
I have Apple Car Play activated, unlocked and working beautifully now. Adding the WiFi antenna makes it so much smoother.
Current: 20 M340i
      04-08-2019, 10:24 PM   #2249
bmtespar
bmtespar's Avatar
[/QUOTE]
Call Brian and ask him, you can always return it if he tells you it'll fit and it doesn't. Since it's an OEM part I'd be more optimistic vs who knows what source.[/QUOTE]
I measured today. The oem digits are 3/4" or 19.5 mm. The badge I ordered was supposed to be 20mm but instead was 27mm. I've reached out to the vendor for a replacement.
Current: 20 M340i
      04-09-2019, 02:09 PM   #2250
Udayan
Udayan's Avatar
France
11
Drives: m240i vert
hi,
Bimmercode session :
- ASD deactivated
- Auto Start Stop function Memory activated
      04-09-2019, 04:37 PM   #2251
putthatthinginsport
putthatthinginsport's Avatar
Drives: 2020 BMW M2 Competition
Put some new shoe's on her this past weekend....666M Wheels.
Current: 2020 BMW M2 Competition (Black Sapphire Metallic w/ Black Dakota Orange Stitching)
Previous:
2018 BMW M240i XDrive (Alpine White w/ Coral Red)
2003 BMW M3 (Steel Gray Metallic w/ Cinnamon Nappa)
shadowfax1289.00
Poochie9104.50
      04-10-2019, 11:46 AM   #2252
Joaco135
Joaco135's Avatar
Drives: 2020 M2C LBB
Nice, can you share the wheel/tire set up?
      04-10-2019, 01:57 PM   #2253
gravy983
Look great! Those CSLs?
      04-12-2019, 10:22 AM   #2254
putthatthinginsport
Front Tires are MPSS, 225/35/19 on 8.5 Wheels, the Rears are 255/30/19 on 9.5
Previous:
      04-12-2019, 11:10 AM   #2255
Just bought my plane ticket!
This will get me back to BC to pick up my car from storage and drive is cross-country to Ontario.
That's about all I've done to show love to my 2er in the last 6 months
Poochie9104.50
      04-13-2019, 10:40 AM   #2256
Bassking511
Drives: 2016 M235i
Remus Exhaust for my 235 came today, feeling a bit under the weather but hoping to get it installed later after work.
      04-13-2019, 12:43 PM   #2257
Conte_81
Conte_81's Avatar
Drives: 2015 M235i X-Drive
I did a few things to the M235i recently!!
Performance: Upgraded the turbo to the Pure Stage 2 and GFB diverter valve. Car is now FBO with a custom tune through Cary Jordan/ Maximum PSI and Bootmod3.
The Maximum PSI/ Bimmer Clinic Guys are amazing to work with and we're local to me in NJ. They even provided lunch! Come on... Dynos and sandwiches, how can you go wrong!
I'm really happy with the power considering I'm on a stock fuel system and 93 pump.
[IMG][/IMG]
Dylan861330.00
      04-14-2019, 11:29 AM   #2258
nixeighty6
Drives: 2021 M2c
Put on some VMR 710's and they really make the car!
setup is:
VMR 710's - stock suspension
Front: 8.5 x19 et 40 with Michelin pilot 4S 235/35 R19
Rear: 9.5x19 et 45 with Michelin pilot 4S 265/30 R19
As a note: I did a ton of research before buying and did see a couple guys running these sizes but kept seeing other posts saying it might rub. there was no rub at Speed, and i flogged her.. for research sake of course. the amount of extra grip coming from the factory staggered M pss 18's is really amazing!
if i would do it again i would personally do a rear et 50, there is plenty of room and my setup pokes the tire in the rear about 2-3mil.
hope this helps, Cheers!
write up with more pics https://www.2addicts.com/forums/show....php?t=1603999
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Dylan861330.00
      04-14-2019, 06:57 PM   #2259
Marmugmotleocay
Marmugmotleocay's Avatar
Drives: 2021 BMW X3M Competition
[IMG][/IMG]
I installed these today. I really need to start using anti seize on my hubs. The wheels were extremely hard to remove. I only have 5000 miles on my car.
      04-14-2019, 07:46 PM   #2260
bmtespar
bmtespar's Avatar
Originally Posted by Marmugmotleocay View Post
[IMG][/IMG]
I have them on both of my vehicles. Btw, you don't need to remove your wheels to install or uninstall theses. You can use a thin trim removal tool or a flat blade screw driver with tape on the end to pop them out.
Current: 20 M340i
      04-14-2019, 07:50 PM   #2261
Marmugmotleocay
I initially tried it with nylon trim tools with no luck.
      04-14-2019, 09:09 PM   #2262
paposalsa
Drives: 2015 BMW 228i
Replaced the Front Bumper Reflector Lights with Crystal Smoke instead on the body color ones.
These smoke ones look real nice with the MG and Black. Found them in Amazon for a quarter of the price than the ones from IND
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      04-15-2019, 11:35 PM   #2263
MiamiM235iEstorilBlue
Drives: 2016 m235i
Are these the VMR version or real 666M? Would you mind sharing your wheels specs?
      04-16-2019, 01:31 PM   #2264
putthatthinginsport
These are 666M Reps, fronts are 8.5 x 19 on 225/35/19 and the rears are 9.5 x 19 on 255/30/19 MPSS.
Previous:
      04-16-2019, 08:16 PM   #2265
paposalsa
Finally replaced the RFTs ... however found out I have two bend rims
      04-17-2019, 04:05 PM   #2266
mb67
In search of the perfect cup of coffee
mb67's Avatar
Drives: 2015 228i Conv
Got it wrapped in 3M's Gloss Wicked:
Appreciate 4
