2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Oil Temp Display
      06-30-2015, 12:36 AM   #1
BBMMWW333
Drives: C32 AMG, E63 AMG, M235i
Question Oil Temp Display
Where on earth can I check my Oil Temp in our car?
      06-30-2015, 02:17 AM   #2
Ramos
Ramos's Avatar
Drives: G20 2020 M340
Search is your friend. Topic has been beaten to death. Hint; secret menu
      06-30-2015, 02:21 AM   #3
BBMMWW333
No luck in Search. Can you point me the link?
      06-30-2015, 06:46 AM   #4
BMWZ4
BMWZ4's Avatar
1910
Secret menu link:
http://www.2addicts.com/forums/showt...oil+temp+gauge
Or, pick-up an OBD reader and an app for your smartphone and you can pick-up oil, water temps among other things
WillOs7.00
      06-30-2015, 08:33 AM   #5
SDKevin
Cone Killer
85
Drives: 2024 M240i, Ducati 1299S
Or OBDII bluetooth sender and smart 'phone.
      06-30-2015, 08:48 AM   #6
Luminous
Luminous's Avatar
743
Drives: 2019 M5 Competition
I just installed the awron gauge and I absolutely love it.
      06-30-2015, 10:25 AM   #7
Béhème
Originally Posted by Béhème View Post
Actually, you don't even have to do the ignition thing. You just press the miles reset button when the car is running until the menu comes on and enter the code.
      06-30-2015, 12:14 PM   #8
BarryJI
BarryJI's Avatar
Drives: 2015 BMW 228i M Sport
I got an OBD2 scanner and paired it successfully with my iPhone 5. So far, however, the only available temp output reading appears to be coolant temp. Does anyone know how to get oil and water temps with the above combo?
      06-30-2015, 12:36 PM   #9
augerpro
Drives: 2015 BMW M235i, Nissan 370Z
What app are you using? I use Torque Pro and oil temp is in there.
Brandon
      07-01-2015, 11:55 AM   #10
SDKevin
Cone Killer
85
Torque Pro definitely shows oil temp...
      07-01-2015, 12:11 PM   #11
ocN55
ocN55's Avatar
Drives: '15 M235i 6MT/ '16 M3
Is it safe to use a wifi or bluetooth obd II reader if we have a jb4 in our cars?
      07-01-2015, 12:15 PM   #12
BarryJI
BarryJI's Avatar
I don't think Torque Pro Works with iPhone but I will check.
EDIT: Yes, Torque Pro is for Android only. I am using DashCommand. I have a feeling that the output options in all apps is somewhat limited by the automobile manufacturer settings.
      07-01-2015, 04:10 PM   #13
tencazzo
Drives: BMW 220i M Sport
Try OEBD-Facile, in premium version should work, but I didn't tested it.
      07-01-2015, 09:15 PM   #14
BBMMWW333
I give up.. way too much work for oil temp.
      07-02-2015, 08:42 AM   #15
SDKevin
Cone Killer
85
Dump the iphone and get an android?
      07-02-2015, 06:52 PM   #16
2msport
Drives: '14 228 MT
using the secret menu is not hard. takes about 45 seconds once you memorize the 5 steps. yeah you're probably not going to use it for every drive but its quick and easy enough to do when you know you're going to be pushing it. or want to monitor warm up times.
      07-03-2015, 12:30 PM   #17
Tpeterson
Tpeterson's Avatar
Drives: 228i MSport/THP/MT/
How difficult was the Awron gauge to install? It's very pricey,but it does have the oil temp on it unlike p3cars vent gauge which only has coolant temp.and just plugs into the OBDII port.
      07-03-2015, 12:58 PM   #18
Luminous
Luminous's Avatar
743
yes it is pricey, i was lucky and got it used though...
install was pretty straight forward, at first i was overwhelmed but i managed it in about an hour. honestly the hardest part for me was reattaching the door sill. it depends how DIY you are, it involves removing a lot of trim, routing cables and playing with the fembody modules. that being said i found a great DIY thread for the M3 awron and that was very helpful.
honestly i love it. i do a lot of 0-60 times and this makes it so much easier than using the cumbersome lap timer app. it includes oil temp, oil pressure, rail press, intake temp, exhaust temp, coolant temp, transmission temp, boost pressure, hp and torque, plus a few more features.
      07-03-2015, 01:08 PM   #19
nachob
Drives: 2004 330i ZHP, 2022 Cayman T
Sad, BMW puts glowing ///M235i logo on dash, pictures of drivetrain on ipad screen, tells you what band is playing your music but can't give car enthusiasts a temp gauge. You have to look for the nested secret menu since the glowing M235i badge is more important than oil temp.
      07-03-2015, 03:45 PM   #20
MrBucket
Drives: '17 AW M2 6MT Exec Pack
What are you talking about? Mine certainly displays oil temps and it has since I got it last October.
      07-03-2015, 04:54 PM   #21
Canaletto
Drives: 4 Wheels
Another option is the electronic steering wheel.
      07-03-2015, 06:26 PM   #22
Tpeterson
Tpeterson's Avatar
According to the Turner Motor Sports web site there is no oil temp.If that is wrong I'm glad. I'll buy one. New info. P3cars.com says oil temp is displayed as you say.Checked wrong supplier.
