12-07-2017, 04:42 PM | #1 |
M-OCD
17
Rep 38
Pre-Lci M2 tacho in M235 speedometer wrong
I managed to get a used pre lci M2 tacho. I installed it into my M235, everything is working except the km/h reading. The M2 tacho reads approx 10km/h lower than actual speed.
Is there some coding or calibration I forgot?
2015 F22 M235i N55 EWG | M Performance | 18" VMR710 | Pure Stage 2 Turbo | Pure High Flow Inlet | MHD Tune | XHP Tune | GFB DV+ T9356 | NGK SILZKBR8D8S 0,5mm | Wagner DownP | Wagner EVO2 Performance Intercooler | VRSF Chargepipe | M Performance Exhaust |
12-10-2017, 03:37 PM | #4 |
M-OCD
17
Rep 38
It's not the tire size that causes the issue. M2 has 265/35/19 on the rear, my M235 has 255/35/18 on the rear. When driving 50km the difference should only be around 2,5km, on mine it is +10. There should be some coding or something possible.
12-10-2017, 07:13 PM | #5 |
3624
Rep 3,592
I would look at the pulse rings on the hubs. The M2 and M235i use different hubs, so the number of teeth on the pulse generator ring may be different.
