12-16-2016, 12:57 PM | #1 |
Rep 864
Wheels or springs?
Which one should I do first??
-Dinan springs and bump stops Or -VMR V710 18" matte black (car is alpine) Car definitely needs to be lowered some, but yet the stock wheels are pretty ugly! So I'm torn on what to do first. I don't drive to hard and don't auto-x or track the car so better handling is a nice to have in my case. Thoughts?
Current: 2023 M2
PAST: 2022 Audi E-tron GT, 2021 Lexus LC 500, 2020 Maserati Ghibli S, 2015 M235i, 2014 Audi TTS, 2012 Lexus IS-F, 2009 BMW 135i, 2004 VW GTI |
12-16-2016, 05:08 PM | #3 | |
Rep 2,942
But an LSD will do much more for the enjoyability of the car's handling and power delivery than lower/stiffer springs. In fact, the latter may make things worse in some cases, depending on what your setup goals and driving habits/skills are.
J-Sud128.50 |
12-16-2016, 07:59 PM | #4 |
Rep 2,214
Dinan's spring setup is pretty good, very close to stock ride but tighter (more "M" like). Honestly, if you like the OEM+ look, I'd go with springs first, just don't do any sway bar work until you've got an LSD out back
Otherwise the stock suspension from a handling perspective is still pretty good. You're either doing it for looks, or for driving pleasure. Each will result in a different outcome. Can't go wrong with either, really. Priorities.... lol
Viffermike1753.00 J-Sud128.50 |
12-17-2016, 08:52 AM | #5 |
Rep 864
I do have the LSD on my todo list....didnt know if i wanted to spend the money...but it looks like ill need to
I really wanted 19" wheels, but given the roads in Houston 18" is a must. I have blown 2 tires and 2 bent/cracked wheels in the last 5 years. (4 separate occasions)
Current: 2023 M2
12-17-2016, 11:27 AM | #6 |
Rep 1,017
I have the set up that you're considering . Dinan springs & bumpstops, with vmr 710 wheels on mpss staggered tires. It looks real nice, and I like the Dinan springs. Right now I have my stock orbit gray wheels on with the 225 run flats. The Dinan springs even make the thin stock tires look nice when you add spacers.
I got the wheels first and did a HPDE (track day) and they performed well. I agree that getting the wheels first would be a good choice, but either way you can't go wrong. If you decide to get the Dinan springs first , I would recommend some spacers for the stock wheel/tire setup. |
12-17-2016, 06:58 PM | #8 | |
Rep 1,017
http://www.2addicts.com/forums/showthread.php?t=1125726 |
12-18-2016, 10:41 AM | #9 |
Rep 19
It really depends on what impact you want to make - form or function. I just had Dinan springs installed and can say that the handling is vastly improved. Wheels are pretty, but won't add much to the experience from a handling perspective. Some would say that 19" wheels can make the ride harsher, but I am running stock setup so can't say with certainty. Springs aren't as glamorous, but the car feels much more planted and and corners much better.
Tpeterson156.50 |
12-18-2016, 11:31 AM | #10 | |
Rep 1,255
12-19-2016, 12:08 PM | #11 |
Rep 2,873
12-19-2016, 05:31 PM | #12 |
Rep 1,541
Springs and spacers.
12-19-2016, 11:50 PM | #14 |
Rep 356
Drives: 2014 m235i
VMR 710s and dinan springs/bump stops here...
I vote springs/bump stops/alignment I did springs/bump stops first, I could deal with the stock wheels, couldn't deal with wheel gap and bounciness of stock suspension at higher speeds. After debating 18s vs 19s I went 19s... I just think 19s fit the car better, Milwaukee roads aren't great and I'm doing fine. |
12-20-2016, 09:10 AM | #15 |
Rep 91
I agree with N55guy. Springs and bumpstops first. Stock the suspension is good, but I still found the gap especially in the rear of mine to be a bit too much and could look even more so with new rims n tires. I had my rims, tires n springs put on the same day, but If i had to do one at a time I would have opted to go with the Dinan setup first. The Dinan springs tightened up the gap n took away alot of the roll n bounce that's present stock. I do have the LSD, so the entire combo of new rims n tires, Dinan setup, and LSD has the car feeling great n performing very well.
12-20-2016, 10:34 PM | #16 | |
Rep 864
That being said....I am due for tires shortly - maybe end of Jan - I will but buying wheels with the new tires. However, i am torn between 18s or 19s. Houston is REALLY full of pot holes and uneven/bumpy streets
Current: 2023 M2
PAST: 2022 Audi E-tron GT, 2021 Lexus LC 500, 2020 Maserati Ghibli S, 2015 M235i, 2014 Audi TTS, 2012 Lexus IS-F, 2009 BMW 135i, 2004 VW GTI Last edited by J-Sud; 12-20-2016 at 10:44 PM.. |
12-21-2016, 11:49 AM | #17 | |
Rep 2,942
I would personally only consider forged wheels at that diameter on any BMW -- especially with a stiffer/lower suspension, which will do even less than the OEM suspension to absorb shock. They will cost considerably more than a typical cast wheel -- even one made from flow casting.
12-21-2016, 01:48 PM | #18 | |
Rep 864
Considering what you are saying tho - i think its best i stick with 18s for the VMRs?
Current: 2023 M2
12-21-2016, 02:23 PM | #19 | |
Rep 2,942
I think 18s look great on this car, but I understand that's subjective. Another thing to consider: 19s will be heavier than equivalent 18s, both in terms of the wheels and the tires. That's another advantage: Less rolling unsprung weight = better feel, quicker responsiveness, and a slight gain in acceleration and (possibly) braking distance. All are reasons why many race cars, from weekend AutoX cars to F1 cars, fit the lightest and smallest-diameter wheels possible.
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> Last edited by Viffermike; 12-21-2016 at 02:29 PM.. |
J-Sud128.50 |
12-21-2016, 03:09 PM | #20 |
Rep 5,372
Keep in mind reducing roll does not necessarily mean that handling is improved. Often times lowering without changing camber and upgrading to stickier tires can often result in worse at the limit handling (i.e., snap oversteer, more understeer) and reduced grip limits. Lastly, the ONLY mode that the OEM electronic LSD operates is in DSC Off and the eLSD is actually pretty good. In all other modes, your diff is wide open (even in Sport+). You will not reap the benefits of a mechanical LSD in the non DSC Off modes simply because the nannies are hyper active and will kill the fun before the mechanical LSD can work much of it's magic. Before deciding to get that mechanical LSD, make sure that your driving style and skill really can use it. If you track the car often, get the LSD.
12-22-2016, 04:41 PM | #21 |
Rep 864
I've decided to skip the LSD, i never drive in Sport+ or track the car.
Also, i will be going with the VMR V710s in matte black 18x8.5 et35 - 225f and 18x9.5 et45 - 255r (PSS tires) I will more than likely be ordering the wheels within the next week or so. Like i said car is currently in the body shop getting M Perf goodies. The plan is to get the car back next Thursday - then Friday all day in the shop again to upgrade to Dinan stg 2, Dinan springs and resonator delete.....I will be so happy to get my car back! ONCE all of that is complete then i can get the wheels and tires put on! ...and may the M Perf steering wheel
Current: 2023 M2
Viffermike1753.00 |
12-23-2016, 02:55 PM | #22 |
Rep 864
These just got delivered!
Current: 2023 M2
