11-19-2016, 01:57 AM | #1 |
Rep 2,897
Clutch going bad at 37k miles
The clutch on my stock 14 M235 is starting to go. From a stop in 1st gear, there is a shudder and a vibration right at the bite point and the car vibrates and hesitates to get moving.
Anyone else have this issue? I'm usually good on my clutches, I shift fast but never abuse the clutch or do any hard high rpm launches and always rev match when down shifting. I've never had to replace a clutch on any car before 90-100k miles. Will this be covered under warranty or the maintenance plan? If not what's the damage going to be? It seems to be worse when it's warm out. I have 8 months left on my lease, any hope it can survive this long? |
11-19-2016, 08:05 AM | #2 |
Rep 1,154
8 months would be a stretch. I would get it taken care of now as they will nail you when you return the car after your lease expires. 37K seems premature to me. Does a lease give you any protection for this.
11-19-2016, 08:33 AM | #3 |
Rep 1,117
Drives: 2015 BMW M235i
This isn't really an indicator of the clutch going bad. Sounds like you might have a hot spot on the flywheel or diaphragm springs might be wearing pre maturely. I had this issue on my Lexus which I drove on for years, the flywheel had a hot spot from the previous owner so engagement was kinda wonky. That might explain why it seems worse when it gets hot. Also, keep in the mind the friction material on these clutches is super grippy so if you release at too low of rpm you might get some chatter. I notice this too but I get mine moving at around 1k rpm. A worn clutch itself will usually slip under load or wont engage/disengage the gears at all. Are you having this happen.
Ramos862.50 |
11-19-2016, 10:11 AM | #5 |
Rep 310
In the US BMW will cover 1 clutch under maintenance or warranty, can't remember which. Of course that is if they don't find any indication of abuse. I would definitely talk to your SA about it while the maintenance/warranty is still active.
rich8566608.50 |
11-19-2016, 12:43 PM | #6 | |
Rep 1,117
11-19-2016, 01:56 PM | #7 | |
Rep 2,897
Is this cheaper or more expensive than a clutch then? And could it be covered under warranty? |
11-19-2016, 03:10 PM | #8 |
Rep 351
I recently had something like this happen. I attributed it to my tires driving and lazy left foot control. it seems to have went away. hope it doesn't come back!
I also noticed it was more prominent when it sport mode. I was having trouble with the sensitivity of the throttle while at tired I guess. will monitor. ml |
11-19-2016, 05:32 PM | #9 |
Resident BMW Fanboy
259
Rep 866
Mine has been doing this since it was a year old. Does it to this day. Just engage the clutch without looking at the tach, you'll naturally slip the clutch closer to the floor and you won't notice it as much. Might have to change your seating position too. I can tell the clutch springs are wearing in, and I'm sure I have some hot spots, though I never abuse the car EVER. I think it's just from stop and go traffic. Maybe next time I'll go for the 8 speed....
Current: '20 F82 M4cs SMB / '13 640i M-Sport Carbon Black
Past: F30 330xi Luxury Line / F22 M235i 6MT / E92 335i / E46 330ci / E36 328i 5MT |
11-19-2016, 05:55 PM | #10 |
Rep 818
Rev it a little more on engagement. My every stick Ive ever driven did that when I didn't rev it. These newer cars/clutches seem to like to slip just a litttttle bit more than years past.
11-19-2016, 08:14 PM | #11 | ||
Rep 1,117
I would bet you're experiencing cdv issues in your car as I get the same thing in mine if I don't slip the throttle enough. Funny as this may sound, when my car starts doing this - I'll switch between sport + and DSC off mode for a few minutes and it goes away. Google failing dual mass flywheel and I'm sure ull feel better haha |
11-20-2016, 02:19 AM | #12 | |
Rep 3,395
Given that this is a rotating mass, when it breaks its like a grenade going off in the bell housing of the transmission That simple clutch/flywheel job now includes a much more expensive transmission replacements as well Roll the dice.....repair or ignore...... Been there, done that, got the merit badge Replace the clutch/flywheel at first signs of issues IMHO and replace that DMF with a solid flywheel when you do it |
11-20-2016, 04:29 AM | #13 | ||
Rep 2,897
11-20-2016, 08:36 AM | #14 | ||
Rep 1,117
11-20-2016, 08:54 AM | #15 | |
Rep 3,395
BMW uses DMF/Clutch packs from made by the same people VW and most European manufacturers do....LUK and Sachs. I've owned multiple vehicles with bad DMF's which dealers have tried to replace only to create juddering result..... And yes....I've seen DMF's explode catastrophically with no sign of issues other than moderate judder in 1st/reverse In every case I've replaced the the DMF with a solid flywheel and gone on to log hundreds of thousands of issue free miles on the clutch/flywheel combo |
11-20-2016, 09:13 AM | #16 | ||
Rep 1,117
11-20-2016, 09:19 AM | #17 | |
Rep 3,395
The simple fact of the matter is that DMF's fail at a MUCH higher rate than solid flywheels......EVEN IF you over engineer the DMF The point is....dont ignore the symptoms of a bad DMF.....doing so can result in a much more expensive repair than a simple clutch/flywheel replacement |
11-20-2016, 09:27 AM | #18 | ||
Rep 1,117
11-20-2016, 09:35 AM | #19 | |
Rep 3,395
Any way you slice it the problem exists between the main of the engine and the input shaft of the transmission......and the tranny needs to come out to diagnose further DMF's are also not servicable OR resurfaceable so the overwhelming majority of clutch jobs also include replacement of the DMF DMF's are just a "Bad Idea TM"....sooooo little benefit for soooo much cost |
11-20-2016, 09:55 AM | #20 | ||
Rep 1,117
Im not vouching for them as I also prefer single mass flywheels also but it is what it is and I can see why manufacturers went this way. All I'm saying is they are a lot more durable than you are making them seem. |
11-20-2016, 10:03 AM | #21 | |
Rep 3,395
Your own story is a perfect example of why DMF's suck They're designed to reduce vibration and noise and they do the exact opposite when they are failing And if yours was making a pile of noise then it was failing This is why people replace DMF's with solid flywheels |
11-20-2016, 10:07 AM | #22 | ||
Rep 1,117
