2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Installed Lowering Springs, Upgraded Shocks, Camber Plates
      09-22-2022, 01:58 AM   #23
Smitty_Schmitz
Drives: 2022 BMW X3m40i
Thanks for the response!! Yeah I’ve seen hit and miss on the LSD for X-Drive F22/F30 cars. But I’ll end up heading down the Wavetrac route with HP Autosport. Good to see the X cars on the track. Hopefully the end of this year I can make it out to a track day at Willow Springs once mine is done and semi dialed in lol
Should have the Ohlins coilovers and Vorshlags installed end of October hopefully and then wavetrac shortly after.
And I’ll follow you 👍
LanceM26115.50
      03-27-2023, 10:43 PM   #24
LanceM26
LanceM26's Avatar
Drives: BMW M235i, BMW M240iX
UPDATE
Alignment Specs:
Crazy difference tires make. Running Hankook Ventus RS4 245/40/18 squared and I shaved 9 seconds off from my PB, and there's still more time I can shave off:
aerobod3625.50
MLJR235116.50
      04-03-2023, 06:57 AM   #25
LanceM26
LanceM26's Avatar
Maybe I'll keep this thread as a build update thread LOL
      04-12-2023, 03:41 PM   #26
designatedposter
Drives: m235i
how are the koni yellow with dinan springs for DAILY driver? i was about to get the bilstein b14, but this seems a good option too since i already have the dinan springs (and stock EDC dampers)
M235i rwd 6mt
LanceM26115.50
      04-12-2023, 03:43 PM   #27
LanceM26
LanceM26's Avatar
They’re great, just set them up with more rebounding.
      04-12-2023, 04:06 PM   #28
designatedposter
Drives: m235i
do the koni change ride height. i heard that is the case with bilstein b6
M235i rwd 6mt
      04-14-2023, 03:03 PM   #29
LanceM26
LanceM26's Avatar
I measured before and after, it didn't change the height. You need to make sure that all the components are installed properly
      04-24-2023, 02:04 PM   #30
LanceM26
LanceM26's Avatar
Build Update:
MSS Track HAS Kit
Looking more and more like a proper coilover
      05-05-2023, 11:57 AM   #31
AmuroRay
AmuroRay's Avatar
2283
Did deleting the EDC cause the active steering and throttle to stop working? I like the stiffer steering and sharper throttle.
Mods: Yes.
LanceM26115.50
      05-05-2023, 12:09 PM   #32
LanceM26
LanceM26's Avatar
No, only the active suspension was changed. I was not a fan of sport + throttle as it is basically an on and off switch. It’s hard to modulate during turns on track
AmuroRay2282.50
      10-26-2023, 06:27 AM   #33
freakystyly
Drives: F22 B58 6MT
Hey, I was just looking to see how you were getting along with the yellows on the 2 series after a year (or anyone else with experience with the yellows).
