03-15-2017, 12:07 AM | #1 |
Moderator
4097
Rep 1,973
VIDEO: S65 V8 powered E46 M3 on the "Smoking Tire"
Featured on BIMMERPOST.com Enjoy the video and sound!!
1981 323i, 143 Kashmir-Metallic, 0094 Pergament, Sports M5, LSD.
03-15-2017, 09:36 AM | #2 |
4972
Rep 10,200
Drives: 2024 Golf R / 2022 718 Spyder
Sounds and looks awesome.
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
03-15-2017, 09:39 AM | #3 |
1658
Rep 1,536
But 50k to build it? That's not including the car or the engine...smh
03-15-2017, 09:41 AM | #4 |
244
Rep 409
I'm gonna go ahead and give an A for effort but an F on sound financial decision making.
11
Portadown9557.00 matt@supremepower264.00 RABAUKE4658.00 QLAbot87.00 filet.M2c784.00 raysspl991.50 Inablur163.00 SDPLV493.00 ItsAllFairGame18.00 Twin_Snails23.50 SportySpice204.00 |
03-15-2017, 09:58 AM | #5 |
Rep 1,689
Nobody builds a car like this trying to save money.
It's most likely disposable income used for a toy. |
03-15-2017, 09:58 AM | #6 |
Rep 4,660
Drives: BMW
Doesn't this completely mess up the chassis in terms weight distribution?
03-15-2017, 10:01 AM | #7 | |
Ya ya ya, I am Lorde, ya ya!
266
Rep 2,772
Drives: E90 M3, 2015 SQ5
"There was one small issue with the build, though. Fitting the E46?s steering rack around the much larger V8?s headers required some extra flex joints. This causes a bit more a dead spot on center and sort of takes a bit away from the E46?s brilliant steering. Technica Motorsports thinks that an E92 steering rack would work but hasn?t tried it yet, as this isn?t a cheap build." LS3 would have been perfect. |
03-15-2017, 10:12 AM | #8 | |
PAZUZU
545
Rep 2,058
Drives: '15 M4
news flash: cars are rarely investments.
2009 M3 DCT ESS625+ SOLD 2015 M4 BSM/Silverstone F4LCON @texasMclub IG @jagemoets |
raysspl991.50 |
03-15-2017, 10:13 AM | #9 |
PAZUZU
545
Rep 2,058
Drives: '15 M4
s65 doesn't weigh much more than the iron block s54.
03-15-2017, 10:16 AM | #10 |
Rep 4,983
This car looks and sounds goddamned fantastic. But yeah, $50k plus an S65 and an E46 M3. That's bonkers money even if the final product is a beast. Kudos to the shop for their work!
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
03-15-2017, 10:32 AM | #11 |
Rep 671
The concept is incredible.
The steering changes seems to take away the main draw of why you would do this however. If it could retain the stock steering (not the e92 steering which pales in comparison) then it would be worth the 50k and then some. You simply cannot buy a car that's as fun and balanced as the e46 with a v8 under the hood.
Nice cars
03-15-2017, 10:35 AM | #12 |
Save the manuals!
6016
Rep 6,747
Amazing build but that $50k number is absolutely absurd. If an E36 can be swapped with an S54 with 100% integration for less than half that, I just can't see it being double for an S65 for just labor alone! Insane.
Most of the time is in the CanBus system integration and that's come a long way since those S54 swapped E36 days as well, which was the biggest challenge. And yet they're running Motec and a non-ideal steering setup?! That number is way overpriced. For $50k and two M3s I better have 100% integration and a new coat of paint
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
03-15-2017, 10:38 AM | #13 |
Rep 1,660
I actually thought it weighted slightly less than the S54. But no, it wouldn't mess up the handling characterics with that engine swap.
Always thought this would be a great swap for the E46. Easier swap than the S62 from the E39 M5.
Current: '13 E92 M3 Euro Delivery Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3 |
bradleyland1503.50 Bolos21.00 |
03-15-2017, 10:55 AM | #16 |
266
Rep 2,772
Exactly. And with the swap they did, they now have all of the S65's flaws that E9x owners complain about.
03-15-2017, 11:04 AM | #19 |
Rep 686
03-15-2017, 11:32 AM | #20 | ||
Know's a guy that know's a guy...
5637
Rep 1,905
Sadly - also true.... |
M3 Adjuster7905.50 |
03-15-2017, 11:43 AM | #21 |
Rep 647
The other possibility is to drop everything into a 330i body. You'd have to add some reinforcement, and swap in components like brakes, but you'd have a hell of a sleeper sedan.
03-15-2017, 11:56 AM | #22 | |
#buildnotbought
10859
Rep 4,893
Labour, custom coding, custom wiring loom (plus ecu), custom propshaft, loads of other custom parts.
Weight distribution might even improve. (v8 is a shorter engine, so can sit further in the back)
