2Addicts | BMW 2-Series forum Classifieds Commercial Classifieds Suspension / Brakes / Chassis / Spacers BMW F2x HD adjustable anti roll bar end links
      12-04-2022, 08:30 PM   #89
HP Autosport
Supreme Allied Commander
Drives: F80 M3
When you lower your F2x 2 series with coilovers, the swaybar is moved from the ideal factory geometry to an offset that decreases the ability of the swaybar to perform. The swaybar frame mount and the end of the bar should be on the same horizontal plane. The factory end links are a solid piece. When the car is lowered, the OEM links cannot compensate for the longer length needed to keep the swaybar in its ideal location. Get immediate response from your sway bar and precise control over your suspension. What this means to you is tighter, more responsive handling.
HP Autosport is happy to introduce these HD adjustable end links. With adjustable end links you can return the bar to its ideal leverage point while lowered. They also afford the peace of mind that the links or shock link mount will not fail as is common in factory units, as they will now be adjusted properly. The links are adjustable in length up to an additional 1.25" over stock. HP Autosport end links are adjustable while on the vehicle.
These end links will fit the following vehicles:
F2x 2 series RWD and X-drive
      01-08-2023, 06:48 PM   #90
HP Autosport
Drives: F80 M3
bump
      02-23-2023, 12:37 PM   #91
HP Autosport
Drives: F80 M3
bump
      05-04-2023, 04:21 PM   #92
HP Autosport
Drives: F80 M3
bump
      07-02-2023, 01:22 PM   #93
HP Autosport
Drives: F80 M3
https://hpautosport.com/product/hp-a...ybar-endlinks/
      08-02-2023, 04:06 PM   #94
HP Autosport
Drives: F80 M3
bump
      09-08-2023, 02:51 PM   #95
HP Autosport
Drives: F80 M3
bump
      10-04-2023, 12:22 PM   #96
HP Autosport
Drives: F80 M3
bump
      11-09-2023, 04:37 PM   #97
HP Autosport
Drives: F80 M3
bump
      01-26-2024, 09:38 PM   #98
HP Autosport
Drives: F80 M3
bump
      04-18-2024, 02:01 PM   #99
HP Autosport
Drives: F80 M3
bump
