11-04-2018, 08:47 PM | #795 |
Rep 9,004
11-05-2018, 07:18 AM | #797 | |
Rep 3,497
I wanted the same, but the unusual offset in the rear (read: good luck finding a wide choice of wheels) put paid to that unless I was willing to make modifications I either didn't want made or didn't want to pay for. Since the 255s were the main priority, I ended up with the wheels in my signature: 18X9½ ET58 & 17X9 ET42. The whole exercise was a PITA. It's as though BMW doesn't know that it has buyers who modify their cars for looks or performance. Instead, they leave little room for wider tires in the rear and cap it off with a rear offset that's a total outlier.
11-05-2018, 04:53 PM | #798 | |
Rep 2,214
Taskmaster2465.00 |
11-06-2018, 07:40 AM | #799 |
Rep 520
The modification thing is not a culture, it's a sub-culture. The number of people who modify their 2s with very big wheels is very small in context, and the car is ultimately quite small so there is simply no room. Why would they make the car uncomfortably large for everyone? It's like asking why the 2 series isn't available with a line lock and drag radials from the factory.
11-06-2018, 08:42 AM | #800 | |
Rep 9,004
11-06-2018, 09:26 AM | #801 | |
Rep 598
the most common 18x8.5 et35 and 18x9.5 et45 from companies like VMR are terrible. the best you will do on stock suspension is 225 on the front and the back will poke so much it is actually comical. i had those exact sizes of m359 wheels on my f22 and went back to stock because the wheel poke in the rear was so bad. shame, because the wheels themselves were gorgeous. |
11-06-2018, 10:43 AM | #802 |
Rep 5,372
I'm running Alutec Drive 18X8 et 43 at all four corners. The wheel offset allows for me to run 245/35R18 at all four corners with absolutely no need for spacers, camber mods, or fender mods. IMO, what the 2 series needs the most is more grip up front and the wider 1.5" wider 245s should help a lot plus the sidewalls are stiffer. Traction in the rear is helped significantly by the addition of a mechanical LSD. In an ideal world, I'd run 255s in the back, but the MP LSD has done wonders for rear axle grip so I'm fine with it. If I were to track the car, I'd buy a set of 17X9 rims and proper track tires. For the street, a 245 square setup is fine for a car like the M235.
To make the more common 8.5" and 9.5" wide VMR rims work on the 2 series requires you to run very stretched 225s in the front which looks silly. I don't like how stretched my OEM MPSS 225/40R18 tires look on my 8" wide Alutecs so I can't imagine how much worse they look on a .5" wider rim. Plus the stretch causes the tires to become quite a bit more darty.
11-06-2018, 01:00 PM | #803 | ||
Rep 3,497
When I was looking, and square 17X9 is what I wanted, the only choice I could find was custom Forgestars. Rather than pay for those, I settled for the opposite of what I wanted: each tire has a dedicated corner. It's workable, just not ideal.
11-08-2018, 10:48 AM | #804 |
Rep 21
Coming from a 2015 228 to a 2019 m240...
The storage bin under the steering wheel was changed to a button panel so that storage is gone. The glasses storage in front of the cupholders is also gone so now all that stuff has to go in the tiny armrest storage. The cupholders are actually smaller in diameter and most tall skinny mugs that fit will rub against the dashboard jutting out. Mirror turn signals are blinding, the parking sensors are slow to respond, you can put the top down with the key fob but you have to literally be standing next to the car, but other than that I'm happy.
Gone - 2015 228ix Convertible / Sport Line / Glacier Silver / Coral Red / Aluminum / Cold Weather / Lighting / HK
2019 m240ix Convertible / Grey / Coral Red / Premium / HK |
11-08-2018, 09:18 PM | #805 |
Rep 243
Now the XM that doesn't allow to go beyond channel 184 ... supposedly it needs a software update. A 3year old car needs a radio module software update? Really?
11-09-2018, 08:22 PM | #806 | |
Gamertag: Boardwalk
35
Rep 82
Drives: 2019 M240i xDrive Convertible
• 2019 BMW M240i xDrive Convertible Estoril/Cognac/Hexagon ZPP, 20Z, 3YA, 674, 552
• 2015 BMW X5 xDrive35d Mineral White/Terra/Hexagon ZMM, ZPP, ZCW, 2VF, 417, 3AG, 688 × 2008 BMW 135i TiAg/Coral/AgAl ZSP, ZPP, 205, 322, 494, 4MG, 677, 6FL |
11-10-2018, 05:40 AM | #807 |
Rep 1,219
Drives: 2015 M235ix
Parking sensors have never worked going forward in this model unless you either reverse first or push the magic button. I have no idea why, since they work in our X3 without the button. However, on the X3, there is no indication on the dash that the steering wheel heater has been activated, which I have never understood and which drives me nuts. What one hand giveth, the other hand taketh away. Crazy Germans!!
stevenvillatoro734.50 tiwahu34.50 |
11-10-2018, 10:27 AM | #808 |
Rep 3,497
This 17-page PDF by ECS Tuning does a very good job explaining wheel offsets and backspacing: http://bd8ba3c866c8cbc330ab-7b26c6f3...l_OffsetR1.pdf
11-10-2018, 04:11 PM | #809 | |
Rep 520
The bin in front of the cup holders was changes for the sliding cover from the 3 series, as everyone complained that the bin was too downmarket |
11-10-2018, 04:13 PM | #810 | |
Rep 520
11-10-2018, 04:55 PM | #811 |
Rep 1,219
Drives: 2015 M235ix
But they don't go off in traffic on the X3!
11-11-2018, 02:58 PM | #812 | |
Thaumaturge
181
Rep 211
Then they got a better tech who said that you only get to 184 with the Select package and if I wanted to upgrade to All Access it was $85 for the rest of the year. I told them NO as it's not worth it to me as I never would use streaming. But I don't get 133 NY Weather and News either. That was strange but they said I needed all access for that too. Sirius is already close to not worth it for me so I guess up to 184 and no NY Weather is all I am in for. At least it has NASCAR for my trips home from Summit Point on Sunday summer afternoons. ///Rich |
11-11-2018, 05:21 PM | #813 |
Rep 520
Just a point of logic - if pressing the button is too arduous whilst parking in a forward direction, how does the car know it's about to be parked? Since it hasn't yet come to a stop and been put into reverse. What is the dynamic difference between pulling into a parking space and inching forward into the range of a parked car in front, and pulling up in a queue of traffic, and inching forward into the range of a stationary car in front? Just wondering how the X3 does this. Super-intelligent, if so. Does the car have other driver aid capability such as radar?
11-11-2018, 10:23 PM | #814 | |
Rep 243
No Sirus Tech could figure that out for almost an hour. I just canceled mine since is not worth .... BTW, I checked my other cars with XM and they go from 1 to 258 so this must be a BMW thing ... Thanks for the info! Last edited by paposalsa; 11-13-2018 at 09:50 PM.. |
