10-07-2017, 06:10 PM | #1 |
Rep 232
Jb4 map zero broken dealer visit
Well long story short my outer tie went,
Can?t drive it so it being towed to dealer currently waiting I put in map 0 so it?s undetectable. Question is should I leave the obd connect still plugged in or no? Please help Thanks in advance !!
2015 BLK/BLK X5 35i - M sport
997.1 GT3 |
10-07-2017, 06:15 PM | #2 |
Rep 2,214
Unplug the obd cable, just in case, only takes a minute.. My $.02, GL with the repairs!
D
10-08-2017, 05:24 PM | #3 |
Rep 129
Drives: 2016 MW M235xi
Even if it's on map 0 and OBDII unplugged it's still pretty detectable. All they have to do is open the hood (or wherever you installed it). Best thing to do is just take it out, especially if they're doing any work on it because a dealer will usually run a full check on the vehicle while it's there (at least that's what the did to mine).
I have heard than do oil samples to check for a tune even if you completely uninstall it but who knows. |
JP's M2xx20.00 |
10-08-2017, 05:58 PM | #4 |
Rep 232
Thanks guys , we?ll find out tomorrow. I unplugged the obd and put in on map zero .
It?s literally under body work so not that concerned
997.1 GT3 |
10-09-2017, 08:31 AM | #5 |
Rep 1,184
Correct me if I am wrong, but won't unplugging it from the obd mess things up?
I don't think the harness will just " passthrough" the sensors when it is not on? Won't it basically be running the car with none of those sensors plugged in? |
Anthony235715.00 |
10-09-2017, 12:09 PM | #6 | |
Rep 2,214
And tune detection typically happens when they dealership plugs in their scan tool. Provided you're on the stock map, you'll be fine. Never heard of oil samples to detect tunes, I mean, that's pretty far fetched, IMO..
FSociety3812.50 |
10-09-2017, 02:54 PM | #8 | ||
Rep 129
10-09-2017, 03:03 PM | #9 | |
Rep 2,214
I take my car to the dealer with FBO mods on it, meth lines and all, and they're cool. Just get the occasional warning, that "if you come in for software updates, or pricey warranty repairs, remove everything we can see. Otherwise, we love what you've done to the car!" They are a Dinan dealer, they get the whole JB4 thing, so they just advise to remove mods when coming in for warranty work. If you get scanned while on Map2, you may be F'd pretty quick, or at least "flagged". At this point, there's no going back, at a cheap cost. If you can afford to mod it, you can afford to fix it. That's the philosophy I take with modding cars when under warranty. If I blow my turbo being FBO, etc, I wouldn't try to have the dealer replace it. I'd do it myself and save the grief of arguing with SA's or regional Reps. If I threw a rod through the block, well, I'd put it back to full stock setup and tow it to the dealer, lol..
Taunto281.50 |
10-10-2017, 10:44 PM | #10 |
Car Enthusiast
282
Rep 501
This has come up again and again and again. Remove it, Keep it in, its not going to make a difference. Dont matter if you have JB4, BootMod3, Active autoworks tune, Dinan, w/e.. BMW can still detect a tune even after its been un-plugged. BMW has been cracking down on picking up tunes alot over the past few years. Even remove the JB4 and put the vehicle back to Stock, if the vehicle is scanned and FASTA data is sent back to BMW HQ from the dealer in regards to a repair then bmw can see the data sent..if they choose to look it up.
You want me personal Opinion.. Talk to the service advisor or if u can, talk with the tech working on the vehicle and explain to them that you have a tune in your vehicle. To be honest 90% of us techs dont really care if the vehicle has a tune in it or not. The only time it comes to be a problem is when We need to scan the vehicle to run test plans...and the scanner can not connect to any of the modules in the vehicle..then it becomes and issue. Put it back on the Stock map and like i said.. if possible talk to the tech. From your original post it seems like the outer tie rod end went - If they are just replacing the tie rod assy - they shouldnt have to scan it - unless you have a drivetrain malfunction control message on for w/e reason. Just put the part in and do a wheel alignment. if they are replacing the entire Steering gear - you need to remove the JB4 from the vehicle completely because with installation of the new Steering gear - Programing/complete encoding is required. If the JB4 is installed when this goes on - it can damage the JB4 (so i've Read) Hope things work out for ya
2016 M235 - Melbourne Red
10-11-2017, 10:03 AM | #11 |
Rep 2,214
^^^ Right from the horses mouth, thanks Taunto!
10-11-2017, 10:08 AM | #12 |
Rep 232
Taunto, very well put . I?m sure it won?t be a problem only thing was if they would be able to read my Ecu for updates etc if they had too plug in there scanner need to be .
Thanks a lot , cleared a lot of doubts !
997.1 GT3 |
10-11-2017, 11:54 AM | #13 |
Rep 1,541
You can't just unplug the OBDII port if you still have the harnesses connected. It will throw other codes when they start it up. Then they have even more reason to take a closer look. The harnesses are not passive; they are active and need the JB4 to work as a pass through.
Better to leave it on map 0 with the port still plugged in. You should have completely removed it from the car. It takes like 15 minutes.
10-11-2017, 12:00 PM | #14 |
Rep 232
What do you mean I put it on map zero and then unplugged the obd , no codes . Even drove straight up onto the flat bed
997.1 GT3 |
10-11-2017, 12:04 PM | #15 | |
Rep 1,541
Makes it a pain to try and get the free maintenance done on my car. Don't want them taking a closer look at the ECU if the CEL pops up while at the dealer because I have the JB4 disabled. So I just go to one of the many shops in my area for maintenance.
Dylan861330.00 |
10-19-2017, 12:43 PM | #16 |
Rep 4,203
If the JB4 is put to map 0, allowed to go to sleep (locked for 15 min or so) then unplug the OBD2 and hide it up under the dash you should be fine. If you don't have a down pipe then you will not get errors logged. If you have a DP then your gonna already have codes
10-25-2017, 10:07 AM | #17 | |
Rep 181
10-25-2017, 01:00 PM | #18 | |
Rep 55
10-25-2017, 04:36 PM | #19 | |
Rep 5,262
10-25-2017, 06:34 PM | #20 | |
Car Enthusiast
282
Rep 501
Like i said, the data that is sent back to BMW is usually filled with much more information than what we can generally see. For me, when i scan a vehicle and if the vehicle has a JB4 connected and say its on Map 2 or or w/e...Almost all the modules in the vehicle will not connect to the scan tool and have very limited data to read, from here, i just take a quick look to see if there is in fact a JB4 installed, Close the session, Cycle the ignition and Set the vehicle to MAP 0, and re-scan the vehicle. Like i said, me and alot of techs dont really care if the vehicle is tunned and has stuff on it, me personally i enjoy it and find it good to see. You will come across some techs that are very against those sort of things and will find any way possible to turn the repair from Warranty claim to Customer pay - so they can make more money. If your up front about it and even have a chance to speak with the tech on the vehicle about it even better. If bmw wants to deny warranty due to a third party accessory installed - they must prove that the part did infact cause the component to fail - I.E. Vehicle has a tune and the engine blows up... BMW can see increased Cam timing, increase boost levels, fuel pressure w/e it may be...
10-26-2017, 03:32 PM | #21 | |
Rep 181
I would like to understand how they can know - eg. what in the car records these readings to makes them CERTAIN, hard facts, and I am talking courtroom certain not "that bracket is missing so there was a JB4 here probably". Thats if you remove the JB4 and car is standard in every other way.(and even then they cant be sure unless they record fueltrims and timings over time and not when the car is in) I am curious. Thats all. |
10-26-2017, 06:59 PM | #22 | |
Car Enthusiast
282
Rep 501
DME's do record data for the most part. It's how we aqquire freeze frame data along with knowing how many times a fault has occurred.
2005 BMW M3 - Sold Licensed Automotive technician for BMW Regina Last edited by Taunto; 10-27-2017 at 07:59 PM.. |
beMtroubleYou66.50 |
