02-15-2015, 02:57 PM | #45 | |
7513
Rep 12,312
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
02-15-2015, 05:35 PM | #46 | |
Rep 1,077
i think most people guess the b58 will have 320 ish. which is realistically what the n55 has. (in m235, 640i / 740i and z4 sdrive 35is versions more or less right?) i could see bmw sticking with the n55 in the m2 just because it has a more square cylinder design. it can rev higher. it will have sportier character. the b58 isn't really design so much to be a higher power engine i'd guess. it doesn't have some new breakthrough in internal combustion tech that would give it a big leap in performance. it is not variable valve timing, adding a turbo or direct injection. its just a new revision. its looks like its designed for commonality of engine family parts for cost savings and different injectors for emmisions. has a longer stroke smaller bore too (less peak rpm, better efficiency at low revs for torque) now, sure cost savings for parts , less carbon emissions production and a torque down low are great for BMW the company (torque down low would help a lot on say a X5 or X7 or 7 series right, and they are all using the same engines). but if you are an enthusiast, well its possible the less efficient, more polluting , shorter stroke n55 while be more fun and produce basically the same power. |
02-15-2015, 08:13 PM | #47 | |
Rep 2,362
BSM ///M2cs, 6spd
02-23-2015, 07:17 AM | #48 |
Rep 823
People have been tuneing the N55 for years. It is clear that you can run it at a higher output reliably. I'm sure with a few tweaks, we will be seeing close to 350-360 rwhp out of the M2. Whatever crank HP they say is besides the point, BMW always underrates their engines.
Curb weight really should be coming in below the M3 (3530 with a manual). I hope to see as close to 3400 pounds as possible. I don't think that is asking too much. Unfortunately the M2 will most likely be competing with the new camaro. That will be an interesting comparison... |
03-27-2019, 01:31 AM | #49 |
Rep 50
would one be able to replace the M2 motor with a m135i engine or even 2012 BMW 535i, my understanding is they all are n55b30 motors? reason I ask is I have a M2 and the engine is blown and it will cost way too much to replace the motor or rebuild , and I have found a motor of a 2012 535i which my i hope can get my car back on the road at least
03-27-2019, 04:06 AM | #50 | |
Rep 415
AFAIK the M2 is the only N55 with its internals. |
03-27-2019, 06:06 AM | #51 |
Rep 50
03-27-2019, 06:24 AM | #52 | |
Rep 363
Anyway, what he means is only the M2 has "this" N55 engine. Think of it as a special edition N55 engine. The name designation and the bulk of the engine are the same sure, but BMW changed some components on it for the increased performance of the M2. Surely you didn't think the M2 has the same engine as the regular 2 series just because it's based on the same platform. If you were to swap a regular N55 motor into the M2 it would not be the same as the N55 made for the M2, if that makes sense. |
tranck500.50 |
03-27-2019, 06:27 AM | #53 | |
Rep 415
It is the same engine block with partially different components. It won't work unfortunately. |
03-27-2019, 10:33 AM | #54 | |
Rep 50
03-27-2019, 10:36 AM | #55 | |
Rep 50
I cant see why it wouldn't work If it is the same motor just forged internal parts made stronger to take more tuning power and pushing the car harder. Yes what im doing might be "wrong", but try finding a "M2" motor in Australia for sale, and then try getting it rebuilt it isn't going to be something cheap at all, and the parts are 4 weeks away according to BMW , not sure which mechanic is going to want to have a motor apart for 4 weeks in there garage too |
03-27-2019, 10:57 AM | #56 | |
The deuce gets loose
290
Rep 499
03-27-2019, 11:05 AM | #57 |
Rep 254
The other two were just saying it's not the true og m2 engine. Parts are different. The "regular n55" will fit just fine and work fine with a competent shop installing it. I imagine some ecu stuff will have to be tweaked and you still might have some lights going off, but you'll have a running car.
I saw a thread about someone putting a s55 engine in there, perhaps you do that instead? Lol |
03-27-2019, 01:07 PM | #58 | ||
Rep 415
Oh and of course you need a tune since the engine is running on different components which may require particular attention. I'm in no way an expert there to go any deeper. Different pistons, camshaft, bearings?, etc etc, it's more than a couple of things different. There is a reason they're different. And I promise that reason isn't M2 being just nice when cutting costs is a #1 priority everywhere. |
03-27-2019, 01:29 PM | #59 |
Rep 2,956
I can't imagine why the swap can't be done seeing physically everything should be the same when it comes to mounting and connections. The question is whether it's going to run properly and how reliable it's going to be as there's likely several ECU parameters that are set up different on the M2 such as timing, overboost, etc.
03-27-2019, 03:12 PM | #60 | ||
Rep 363
qnet683.00 |
03-27-2019, 05:38 PM | #61 |
Rep 1,017
He's not speculating. You can read up on it. The N55 in the M2 share the crankshaft bearings & piston rings from the S55. I'm not sure about the pistons. The oil pan is different, as well as the intake system. There are other differences that I can't remember, but someone just posted a break down of it in one of the threads. I had a M235i and it was quick, but I can tell the M2 is a little more powerful, but not by much IMHO.
I'm probably in the minority, but have always liked what BMW did with the N55 to make it for the M2, and prefer it over the S55 in the M2C. I'm a geek for that type of stuff, and fell in love with the original idea of the M2, in taking a 2 series and tweaking it to make it an M car. |
03-27-2019, 07:00 PM | #62 |
Rep 390
If you can find a salvaged x4 M40i....
That'll have the exact same engine as the M2. N series not B of course. Unsure if a direct transplant would be possible due to intake, engine mount, harness differences. |
ZeroEmissionZ17.50 krizze928.00 |
03-27-2019, 07:04 PM | #63 |
Rep 2,577
I made a list for you guys.
No, you can't put a PWG N55 into M2, DMEs are different.
Lemania 2320
ZeroEmissionZ17.50 termigni1081.00 |
03-27-2019, 08:02 PM | #65 |
Rep 2,149
M2 engine has cast iron cylinder sleeves and different exhaust manifold too.
ZeroEmissionZ17.50 |
03-27-2019, 08:29 PM | #66 |
Rep 50
My understanding was the internals on the M2 are identical just forged , someone else also said if you removed the intake, turbo, and oil pan swapping them over it would work. I just got quoted on the crankshaft $3700 AUD not including labour or any other part :'( how do I get myself out of this mess :'(
