2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning High Pitched Whistle Under WOT
      03-07-2018, 06:00 PM   #1
CJ_M240
Drives: M240i Coupe Xdrive
I’ve had my M235 for a couple months now and I have been noticing a high pitched whistle/rattle during hard acceleration. It’s not normal turbo sounds but almost like an intake leak or something. It sounds like it’s originating from the driver side and I cannot hear it during normal acceleration.
Question is is the whistle/rattle normal? If it’s not has anyone had it diagnosed and repaired?
      03-08-2018, 03:45 PM   #2
frenchfry675
Drives: M235i xdrive
Maybe charge pipe is cracked? Stock intake?
      03-08-2018, 03:53 PM   #3
Ft_LaudM235i
Ft_LaudM235i's Avatar
36
Drives: M2 Competition
2014 M235i  [0.00]
I was also thinking you should examine the charge pipe carefully....
      03-08-2018, 07:03 PM   #4
CJ_M240
Yes, stock intake. The car only has 15k miles so I’d be surprised if the charge pipe is cracked but I will take a look.
If it is cracked it looks like the charge pipe install is a big PITA, right?
      03-08-2018, 07:45 PM   #5
frenchfry675
I haven’t installed my Er charge pipe yet but I don’t think it’s that bad. Your car is out of warranty I’m assuming?
      03-09-2018, 07:07 AM   #6
FSociety
IG @bmwF9xG80
FSociety's Avatar
3812
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Grab FTP Charge-pipe if you planning to keep the car for another 15k miles you'll save yourself the WHAT ifs
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      03-09-2018, 05:21 PM   #7
CJ_M240
It’s still under warranty but if it’s the charge pipe then I will likely upgrade it.
I am not completely sold that it’s the pipe though because it’s only makes the noise for a second and then it’s gone.
      03-09-2018, 06:04 PM   #8
frenchfry675
If it does it all the time take to the dealer and have them ride with you. Is your car stock?
      03-13-2018, 09:36 AM   #9
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
It's a boost leak for sure. If you have any aftermarket parts such as an intercooler or charge pipe I would check and tighten those connections first as they are likely the culprit.
If you're bone stock under warranty, let the dealer figure it out haha.
      03-13-2018, 11:24 AM   #10
XutvJet
Do you have the M Performance exhaust? I've got it and the rest of my car is stock. The MPE can make a pretty loud high pitch whistle under hard acceleration, especially in more humid temps. It's the sound of the wastegate managing boost and the air going supersonic around the wastegate.
I have the stock intake and occasionally can hear a fairly pronounced intake whistle under certain acceleration. No rattles though. I've got the Torque app and can monitor boost. Nothing wonky is going on. It shows expected boost of 9 to 11 psi depending on gear, density altitude, load, rpm, etc.
      03-14-2018, 06:07 PM   #11
CJ_M240
I do indeed have the MPE exhaust with the stock intake. I think you are onto something with the air whistling past the wastegate.
      03-15-2018, 08:20 AM   #12
mahyarv14
Drives: X3 M40i
  [0.00]
I have a MPE and it does the same... Pretty sure it's normal.
      09-03-2019, 03:26 AM   #13
sqorpius
sqorpius's Avatar
Drives: BMW F82 M4
Hi all, just came across this post. I know it has been a bit outdated, but I am experiencing the same with my BMW F36 435i with MPE exhaust.
Just to verify, i've added a soundclip:
https://gofile.io/?c=LwqiHw
Is this the noise we are talking about? Many thanks for the help
      09-03-2019, 03:16 PM   #14
NateDog07V
Drives: 15' M235i BSM Auto
Dealership trip may be in order
https://www.2addicts.com/forums/show....php?t=1630733
      09-07-2019, 10:59 AM   #15
sqorpius
sqorpius's Avatar
Drives: BMW F82 M4
It's hard to believe this is from the transmission to be honest. It's not always present, not even always under full throttle. It seems to go more into the area of the turbo/cats or exhaust system. What do the other guys had as an outcome with this noise?
      02-05-2020, 03:36 AM   #16
oooseun
Drives: M235i '15
I coincidentally started noticing this 2 weeks after getting the MPE. So this is ... normal right?
Search this Thread:
