02-27-2018, 10:24 AM | #1 |
Rep 410
Quick question before buying my Bootmod3 tune
I have in my cart the flash tune and the addition stage 2 93oct OTS map. When I receive my tune, does the stage 2 tune already come with it or do I have to download it when I get it?
Thank you! |
02-28-2018, 10:03 AM | #2 |
Rep 225
When I had BM3 installed the DME had to be taken out and SSR put in the flash tune. So stage 2 came with it. Last night I flashed a tune and noticed the screen said 'unlocking and flashing ... tune '. BM3 comes with 1 OTS tune - not sure if you are unlocking for the first time if it will flash this or keep the stock map in the ECU. Even if not from the BM3 UI you can select an OTS tune and flash it after unlock.
Note that the feedback on the UI during this unlock / flash wasn't great. Before they had a countdown timer. It took about 4 minutes, usually took about 90 seconds for a map change. Kind of unnerving the first time with all the alarms. Just FYI I have had flashes fail but re-flashing fixed.
18 340i F30 mostly stock |
03-06-2018, 07:41 PM | #3 |
Rep 190,687
You dont receive any hardware with the tune,just the map (software)
03-09-2018, 07:04 AM | #4 | |
IG @bmwF9xG80
3813
Rep 7,593
If you read the FAQ https://f87.bimmerpost.com/forums/sh....php?t=1474469 You also go into OTS map section and choose your map of choice. If you ever want another map then you do buy an additional OTS map $50 for N55 on their page and the map credit is automatically added to your account and you go grab another one.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 03-10-2018 at 04:32 PM.. |
NO_USER_537.50 |
