05-28-2015, 12:24 PM | #23 |
Rep 190,802
If you already have the Jb4 installed prior to the DP, you will not get any lights.
01-30-2018, 08:22 PM | #24 | |
Rep 233
I may have accidentally turned off the auto cel clear function on my jb4, how do I check or turn it back on? I have a m235i with a high flow cat and jb4. Currently on map 2 and there's a cel. I cleared it at a shop but it came back on after a while. TIA |
01-30-2018, 08:37 PM | #25 | |
Rep 190,802
02-14-2018, 11:05 AM | #27 |
3441
Rep 79,211
A few months ago BMS changed over all their JB4's to not auto clear on downpipes anymore to be within regulation of emissions guidelines. If you have updated your firmware recently or purchased a JB4 post 10/2017 auto clear for downpipes have been turned off.
02-21-2018, 01:57 AM | #28 | |
Rep 233
TIA |
02-23-2018, 10:41 AM | #29 |
3441
Rep 79,211
You want to turn on auto clear, is that what you're asking?
03-05-2018, 10:48 PM | #30 |
Rep 15
I've been running the JB4 on my FBO N55 2014 m235i for the last month or so. I've been on map1 just getting used to everything and it keeps throwing a "catless downpipe detected" code on the JB4 app although I have a catted ER downpipe installed. Anyone have any ideas? Should I just be running map5 or something similar?
03-05-2018, 11:23 PM | #31 |
Rep 225
Aftermarket catted downpipes often throw codes. I have a Wagner catted DP and it threw a code yesterday. My BM3 normally clears this but I just flashed a stage 1 OTS map which must not disable this code. If you don't have a flash tune you need to have the JB4 auto clear. If your JB4 has recent firmware the auto clear switch has been disabled in the UI, but there are workarounds.
18 340i F30 mostly stock |
