10-12-2022, 07:11 AM | #1 |
Rep 32
powering a Dashcam using rear-view mirror/rain sensor
Looking to get a dashcam for my m240i but would rather not run wires all the way down the pillars.
Anyone know of a way to tap into the rear-view mirror assembly to draw power to a dashcam? It appears to be the shortest possible wire length for such a setup. After researching around for a bit I'm leaning towards this: https://fitcamx.com/collections/bmw/...eries-dash-cam basically zero wiring. Last edited by ehosca; 10-13-2022 at 01:45 PM.. Reason: found a possible solution |
10-12-2022, 08:23 AM | #2 |
Rep 1,798
I have that set up right now. As far as I remember, the mirror's power is 12V and the cam would be 5V so a step down regulator is needed. I bought an amazon regulator, stripped off the plastic outer casing so it takes up less space, shoved it in the housing. I managed to solder pins to the ends of the wires so I could share the same plug as the mirror. I believe it was brown = ground, red = 12v. My old cam is a mini USB, not even micro, so I also soldered that up to an angled plug.
There's other posts either here or on the f30post side regarding this with more detail and pictures. |
10-12-2022, 08:31 AM | #3 |
Rep 1,264
I thought about using the mirror/rain sensor power for the front camera, but decided against that. So, I ran the wire up the right side of the car to the camera mounted to the right of the mirror/rain sensor. I install two of these cameras: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
10-12-2022, 11:40 AM | #4 | |
Rep 32
this is fantastic. do you have any schematics or wiring diagrams?
I came across: https://dongar.tech/collections/adapters but they do not offer a BMW compatible adapter... Quote:
10-12-2022, 12:40 PM | #5 |
Rep 1,798
This thread had a bit more detail with a pic. Power looks to be green w/ brown stripe not red. https://f30.bimmerpost.com/forums/sh....php?t=1610959
ehosca16.00 |
10-13-2022, 08:11 AM | #6 |
Rep 1,264
I bought and installed 2 12VDC to 5VDC converters. The use a common "add a fuse" piggy back in the trunk. The converters have a usb-a connector to which I've connected long usb-a/usb-c (the cameras have a usb-c power connector) cables.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
10-13-2022, 01:45 PM | #7 | |
Rep 32
this looks to be best from an installation POV. i'm not sure about the image quality etc though ..
https://fitcamx.com/collections/bmw/...eries-dash-cam Quote:
10-13-2022, 02:01 PM | #8 | |
Rep 1,146
It's actually a POP (piece of poo) to run it that way, my DC guy did that (although the fucnked up the fuse part) but the run is easy peazey lemon sqeezy, run down the a pillar, along the floor through to the boot, and the fusetap into a fuse in the back
I'm planning on doing that when I get a chance, at the moment I have it wired to the cig lighter/12v cable, looks a "bit" manky, but it's just temporary I'd rather a tempo fix till I get it sorted out in case of an accident I would seriously suggest dont "cut" into any wires take it back to the fuse box, it really is easy to do my 12 year old could do it Quote:
10-13-2022, 02:09 PM | #10 |
Rep 1,146
just checked out the YT video, no cutting just plug and play, I'll look at that when I get home as the boss is lurking around, looks sexy as hell, and stops the idiots at BMW who work on my car from disconnecting or removing it when my car goes it, you don't know it's there ! Wowo
10-17-2022, 06:57 AM | #11 |
Rep 8
I got mine from taobao. Not sure whether u can find it in AliExpress.
https://m.tb.cn/h.UVbXUWd?tk=KpHl2zjatPf |
12-27-2022, 12:49 PM | #12 | |
Thaumaturge
181
Rep 211
///Rich |
12-27-2022, 04:30 PM | #13 |
Rep 38
I used this
https://www.amazon.com/dp/B07R7JGCL1...roduct_details Only found one that had a microUSB plug (which is what my camera used) and followed the guidance found here https://g80.bimmerpost.com/forums/sh...1811276&page=3 I did have to solder longer leads on the ends that are inserted into the harness to make it work. Works great, just need a better mount for the camera other than a suction cup. |
12-27-2022, 08:21 PM | #14 |
Thaumaturge
181
Rep 211
12-29-2022, 12:02 AM | #15 |
Rep 706
I prefer the suction cup to the Blendmount. One is it's removable... Easily that is. Two is it allows the RD to sit higher up and out of the way/view while in use. Just sayin
01-22-2023, 06:45 PM | #16 |
Rep 52
Installed the FITCAMX in my 16' M235i on Monday. Plugs right into the rain sensor with a provided plug. No issues so far, looks great and no wires. I got the 4k model but I think the quality of the image isn't actually 4k. I wish they would make one that fits so well will a GoPro quality camera.
01-22-2023, 09:56 PM | #17 | |
Thaumaturge
181
Rep 211
///Rich |
01-22-2023, 10:48 PM | #18 |
Rep 52
This is lower settings, I can pull a full 4k clipin the morning.
So far it starts every time, you can use the app or just pull the micro SD. Perfect for insurance. https://youtu.be/UXpAzUlSZyc |
01-23-2023, 09:05 PM | #19 | |
Thaumaturge
181
Rep 211
Thanks. ///Rich |
01-23-2023, 09:10 PM | #20 |
Rep 52
The USB on their site is a USB adapter, I was confused by that too . I didn't use the 64gb they provided and got a Samsung Endurance 128gb SD. Card is easy to access. I'll pull a couple clips now and post.
01-23-2023, 09:37 PM | #21 |
Rep 52
Video quality is decent for my use case, just in case I need it for Insurance. May be able to figure a polarized lens for some of the reflections. Sits back a few inches from the glass so it's to be expected. Night reflection from drive. Still works for me as I'm not trying to film the next fast and furious with this, that's what the GoPro is for
Artdnj394.00 |
01-24-2023, 09:07 PM | #22 | |
Thaumaturge
181
Rep 211
///Rich |
