2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum Regional Forums USA - NY / NJ / CT / PA Emissions
      04-04-2023, 11:25 PM   #1
f22reaper
f22reaper's Avatar
Drives: BMW 230i
Emissions
Little lost on what to do so i’m hoping this forum could help.
My 230i (f22) isn’t passing emissions in NYS.
It’s showing CAT, EVA, HTR in monitor status.
As well as the codes Catalyst System Efficiency Below Threshold (Bank 1) & Lost Communication With ECM/PCM. I’ve done the whole driving X amount of miles under 60mph, no luck.
I also have absolutely no luck finding o2 sensor spacers since that seems to be the issue, so if someone could guide me in that direction it’ll be very appreciated
Car is tuned, fbo.
Just asking if there’s another solution to have the car monitors ready for inspection rather than throwing the catted down pipe back on (car is also on stock map now).
NYS is annoying!!!
      04-06-2023, 07:07 AM   #2
LA1Z24
Drives: 2014 435i M Sport
The car IS NOT GOING TO PASS IN NY with a tune on it. It's as simple as that. Flash and convert back to stock. O2 spacers ALSO FAIL INSPECTION.
-NY Inspector
      04-06-2023, 03:25 PM   #3
Nickgom2
Drives: 2017 bmw m240i
you can also try getting spark plug anti fouler and fill it with coarse steel wool. it can trick the ecu into running normal sometimes
      04-06-2023, 03:30 PM   #4
f22reaper
f22reaper's Avatar
Drives: BMW 230i
LA1Z24 I failed to mention the codes & readiness were after i flashed the car back to stock, and after i did the whole “drive 60 miles under 60mph” thing. My question was if there’s a way to help clear these with my catless downpipe still installed or do i have to go back to my stock catted downpipe.
      04-09-2023, 12:38 AM   #5
fiveightandten
fiveightandten's Avatar
108
Drives: F22 M235, E36 M3, E30 325, E90
Yes, if you don’t have a cat, the car will throw a cat under efficiency code. The emissions system is essentially designed to prevent what you are doing.
