02-22-2017, 11:47 AM | #1 |
Rep 151
Cheaper exhaust clamp for m performance exhaust?
Hey guys,
Does anyone know of a cheaper option for exhaust clamp for m performance exhaust? I bought a used one that doesn't have the clamp and really don't want to spend $80 on a clamp. |
03-07-2017, 11:35 AM | #2 |
Rep 350
03-07-2017, 12:32 PM | #3 |
Rep 301
Here's the one I used. It's very good quality & appears very similar to the BMW clamp. $29 from Summit, super fast shipping, it arrived in two days.
https://www.summitracing.com/parts/pye-hvc66 Here it is: Here it is now worth $100: |
03-07-2017, 01:20 PM | #5 | |
Rep 301
Many of the ones available did not look like they would expand large enough due to their design. The way the Pypes is constructed, it looks very similar to the BMW clamp. With the nuts loosened it expanded enough to fit, no problem. (You can see in the picture that the nuts are actually seated pretty far down the bolts once tightened.) The other clamp on Summit that looks like it will work is the Hooker. It is cheaper and the order contains two clamps. It was out of stock when I ordered & I didn't want to wait a few days so I went with the Pypes. Last edited by ChrisFulton; 03-07-2017 at 01:21 PM.. Reason: Add info |
03-11-2017, 07:09 PM | #6 | |
Rep 350
03-13-2017, 04:10 AM | #7 |
Deserter
215
Rep 401
I found a Raggazon clamp at a shop (in Switzerland), it's 83mm and the shop sold it to me for 10$ ^^ maybe if you go to your local shops you will be lucky too !
For the moment, everything is fine ! |
