05-22-2018, 10:28 PM | #1 |
Rep 328
228i Exhaust Mods
My personal vehicle is a 2016 228i Xdrive. I am planning to modify its exhaust but right now I don't want to touch the catalytic converter yet (the smell and CEL). Here are some ideas that I came up with and I need you guys' suggestions to help me choose one.
1: Muffler delete 2: Muffler and resonator delete 3: Straight pipe after the first cat 4: Switch to M235i M Performance Muffler 5: Straight pipe after the first cat but add a M235i M Performance Muffler I am also open to suggestions! Thanks in advance |
05-23-2018, 08:39 AM | #2 | |
Rep 39
http://www.2addicts.com/forums/showthread.php?t=1475169
'15 BMW 228i xDrive Convertible M-Sport
My Other Cars: '18 Dodge Challenger Scat Pack; '78 Pontiac Trans Am 455 Future Cars: '19 RTR Mustang Ecoboost |
05-23-2018, 09:25 AM | #3 |
Rep 8,942
If you want cheap the stock 235 mufflers are easy to get folks who upgrade to MPE can't give them away. Ask me how I know...
05-23-2018, 05:32 PM | #4 | |
Rep 328
05-23-2018, 05:33 PM | #5 |
NewFinishColumbia/detailer
604
Rep 2,096
I just did the OEM exhaust mod to my N20 228 and I already had no resonator. Search for the vid.
05-23-2018, 05:33 PM | #6 |
Rep 328
05-24-2018, 07:33 AM | #7 |
Rep 39
I'm used to other terminology, it is a valve on other cars. BMW just calls it an exhaust flap, if you have the exhaust flap, you will need this. Take a look under the rear end and see if there is a black box on the side of the muffler.
https://www.ecstuning.com/b-genuine-...r/18302411427/
05-24-2018, 07:36 AM | #8 | |
Rep 39
If you want quick and easy, order the exhaust flap simulator, wait for it to arrive and then go to a muffler shop and have them hack off the old one. Then if he ever wants to sell it later, he can just put the old one back on too.
05-24-2018, 11:45 AM | #9 | ||
604
Rep 2,096
05-24-2018, 12:52 PM | #10 | |
Rep 39
Tpeterson156.50 |
05-24-2018, 04:14 PM | #11 | ||
604
Rep 2,096
The OP has his stock down pipe still installed, resonator still on his car, so a hidden code that's maybe going to show up when his car is scanned for a maybe state inspection is not really relevant in this post.
05-25-2018, 09:31 AM | #13 | |
Rep 39
I'm going to use one of your images from a previous thread as an example. Please explain how reducing the flow from one pipe to two, because that's what will happen in this case, will increase the sound. The velocity of the air and amount of pressure which causes us to perceive sound levels being louder will be decreased by opening up a second pipe. The intention of the valve is to increase back pressure in the exhaust to heat up the catalytic converter, as they do not perform efficiently until they are hot. Now if the flap was like that of my corvette and inline with two pipes that bypass the baffles in the muffler with a solid wall straight pipe, yes it would make it louder. But also, please explain why if I put it in ECO mode, wait for it to warm up, and use the bore scope in the exhaust it will be open. Doesn't make any sense, why would a flap for sound be open while in ECO mode. Makes sense in sport, but not ECO. It is 100% for creating additional back pressure in the exhaust to warm up the catalytic converter. My challenger is the same way, has two flaps in the exhaust that have a hole in the center. The Exhaust is 3" OD, the flap has a 2" hole in the center, creating additional back pressure, once the car is warm the flap is open all the time and I get all 3" to allow gases to exit. Now, I can guarantee that when I disconnected mine and I read my codes with my coder, it did show a fault code for the exhaust flap disconnected. i'm not saying the code will be picked up by emissions or a dealer, i'm only saying it is possible and better safe than sorry. Having to re-test in my state costs an additional $25. So why not spend it on the $25 plug to begin with and not worry about it. p.s. I'm an engineer for a major automaker and do quite a bit of fluid (which air is a fluid) and thermal analysis, lower air velocity and exit pressure reduces sound levels. It's why a fan is quieter when it is moving at a lower speed, or why the air coming in your window is quieter at slower speeds.
MetalMK228.50 |
05-27-2018, 06:44 PM | #14 | |
Rep 260
KB3425.00 |
05-28-2018, 11:03 AM | #15 |
604
Rep 2,096
Good explanation KB34. Makes sense. If I lived in a state where I had emissions testing then I would've gone a different route with my car. I guess when the OP chimes back in then we will know for sure.
05-29-2018, 07:38 AM | #16 | |
Rep 39
https://ecstuning.com/b-genuine-bmw-...r/18302411427/
05-29-2018, 07:46 AM | #17 |
Rep 39
I mean, will they pick it up, maybe... I don't want to take it for an emissions test and fail and have to re-test again, so I just put the plug on, cleared the code and done. Also, I don't want my wife going in for an oil change and them saying oh you have these codes we need to fix. And try to charge her hundreds of dollars to fix it. I would change the oil myself, but I got all those oil changes thrown in for free, and I know my wife won't pay for anything at the dealer without calling me first lol.
05-29-2018, 07:49 AM | #18 | |
604
Rep 2,096
05-29-2018, 08:31 AM | #19 |
Rep 39
Honestly I would do everything on it myself, but I specifically told them not to run my credit score as I already had a pre-approved loan from my bank, and I knew they couldn't beat 2.9% on a used car. But they ran it anyway some how 3 times (popped up on credit Karma "BMW Financial Services"), so needless to say I was rather mad. I suggested they give me the full service package until the CPO extended warranty ends in 2021, and an additional $1,000 off. They refused until I started to dial the phone for my personal lawyer on speaker. They still didn't think I was serious until the phone picked up "Law Offices of Webb and Taylor, How may I help you?" They jumped on board really quick at that point.
05-30-2018, 08:03 AM | #20 | |
604
Rep 2,096
06-23-2018, 12:44 AM | #21 |
Rep 823
I've been trying to find one up here in the Northwest (Portland, Seattle) area and there are none. Any leads on someone selling and shipping it out this way?
06-25-2018, 07:56 AM | #22 | |
Rep 39
I personally think swapping to the 235i muffler leaves it too quiet.
