2Addicts | BMW 2-Series forum Technical Topics N20 (228i) / B46 (230i) Engine, Transmission, Exhaust, Tuning Dinan exhaust does not stick out of M performance diffuser (m240i)
      01-31-2018, 01:56 PM   #1
TakoMako
Drives: M240i Xdrive
m240i with dinan exhaust and m performance diffuser. Fits well, but the tips won't stick out.
      01-31-2018, 05:15 PM   #2
gk09
gk09's Avatar
Drives: 1m
Can you post a pick of the rear? I?m looking st doing the same thing you did
      01-31-2018, 05:16 PM   #3
gk09
gk09's Avatar
Drives: 1m
Where in Canada are you located? I?m a fellow Canadian.
      01-31-2018, 07:12 PM   #4
TakoMako
Calgary. Too dark tonight, will take one tmr.
      01-31-2018, 08:29 PM   #5
orangeglim
Drives: 2019 M2C
2019 M2C  [0.00]
Does Dinan make two different versions, one for the normal defuser, one for the performance defuser? Yours looks exactly like the MPE for the normal defuser, but on a car with the performance defuser.
      02-01-2018, 12:09 AM   #6
TakoMako
Talked to the reps and warranty people. There is only one version. I should note that I am not extremely bothered by it.
      02-01-2018, 12:36 AM   #7
mikeyymonster
mikeyymonster's Avatar
Drives: 2021 M2C
I have an ongoing thread of exhaust tip fitment for the F22. Would appreciate if you add your findings there!
http://www.2addicts.com/forums/showthread.php?t=1441133
2021 M2C
2014 M235i
Instagram: @mikeyymonster
      02-01-2018, 05:58 AM   #8
orangeglim
Drives: 2019 M2C
2019 M2C  [0.00]
According to this page there ARE two different versions, at least there was for the M235.
https://www.dinancars.com/products/?...tegory=Exhaust
I don’t see why there wouldn’t be two different ones for the M240 also.
      02-01-2018, 10:50 AM   #9
TakoMako
If you go to m240i product page, you will see one, and only one.
      02-01-2018, 11:10 AM   #10
TakoMako
Honestly, I am fine with this. Only 1cm/half an inch from the end of diffuser. Worst case, just put a slip on onto the exhaust tips.
      02-01-2018, 12:31 PM   #11
gk09
gk09's Avatar
Drives: 1m
Looks perfect!
How does she sound??
      02-01-2018, 01:15 PM   #12
TakoMako
Looks perfect!
      02-01-2018, 06:15 PM   #13
gk09
gk09's Avatar
Drives: 1m
Looks perfect!
Awesome!
      02-04-2018, 12:49 AM   #14
BespokeM
BespokeM's Avatar
16
Drives: M2C
I'm in Calgary as well. Did you order straight from Dinan or from BMW?
      02-04-2018, 01:32 AM   #15
TakoMako
I went to RCTs Canada Inc. CalgaryBMW won't not sell it nor install for me because of BMW Canada's internal problem last year. Hour rate was $130. Installed stage 1 and exhaust for the m240i.
      02-10-2018, 07:35 PM   #16
Estoril6rod
Estoril6rod's Avatar
40
Drives: M235i X-Drive
Hi! Have you tried playing with the clamp? Sometimes you can adjust a little bit and get the tips to stick out around 1/2 inch maybe a bit more.. nothing dramatic but maybe just enough to get the tips flush with the diffuser!
Have you tried looking at the tips once the exhaust is warmed up? The metal expansion maybe just enough to get you flush
      02-11-2018, 09:15 PM   #17
TakoMako
Will probably try that when I install other mods such as mid-pipe. I am not extremely bothered by it at the moment.
