2Addicts | BMW 2-Series forum Technical Topics N20 (228i) / B46 (230i) Engine, Transmission, Exhaust, Tuning NEW RELEASE: DINANTRONICS Sport (N20/N26)
      07-21-2016, 11:10 AM   #23
Shashkastorm
Shashkastorm's Avatar
Drives: 2016 F22 228i
Very exciting new offering from Dinan - I'm definitely interested in adding this to my 228i N26!!
I may have missed this somewhere in the post, but did the quoted MAX gains for the N20 / N26 (+30 HP, +50TRQ) come from a vehicle with other mods (i.e.: downpipe, intake, turbo, etc), or was it otherwise stock?
      07-21-2016, 12:01 PM   #24
Dinan_Engineering
Dinan_Engineering's Avatar
Drives: Any BMW
Stock vehicle with 93 octane.
      07-21-2016, 12:32 PM   #25
Shashkastorm
Thanks for the clarification - Very impressive indeed!
      07-21-2016, 10:58 PM   #26
bateau
Drives: 2013 328i Sedan
Cross-posting from the F30 forum. I had an opportunity today to put BMS Stage 1 and Dinantronics Sport on a dyno. Granted, both companies say to allow for ECU "adjustment" period, but I didn't have the luxury of time. There are still measurable gains right after plugging in both products.
2013 328i, 8AT, no bolt-ons. Chevron 92 octane. Ambient temp in the shop was 92-94F during 1hr session. Humidity 15%. Dynojet 428 at Carb Connection in Kirkland, WA. The runs were performed in 5th gear (1.285 ratio) starting at about 2000 RPM. Dinah unit was set to default setting of +3PSI. Raw files are available here.
STD vs SAE
3 best runs with BMS vs 3 best runs with Dinan. They overlay pretty well, except for best Dinan run picking up a little more torque below 3k. It probably has more to do with my inexperienced dyno foot than the chips.
      07-21-2016, 11:59 PM   #27
BarryJI
BarryJI's Avatar
Drives: 2015 BMW 228i M Sport
Pretty impressive considering that the Dinan product isn't their full Stage 1.
2015 BMW 228i M Sport w/Track Handling Package
DAP | Lighting | Premium | Tech
DINANTRONICS Performance Tuner Stage 1 | DINAN Shockware | DINAN Free Flow Exhaust | DINAN Performance Spring Set + Ride Quality and Handling Kit
      07-22-2016, 05:15 PM   #28
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
I'm liking the smoothness of the DINAN maps versus the BMS.
78' Honda CB400A project
      07-22-2016, 11:03 PM   #29
jgoldstein2000
Drives: 228 Xdrive -Deep Sea Blue
Would move to see this compared to Dinans stage 1
      07-25-2016, 01:46 AM   #30
cpxchewy
Monkey
119
Drives: 2020 M2C
For daily driving does this kick in when gas pedal is < 50% depressed? (Similar to how BMS does) Or will it always be boost +3 psi.
      07-25-2016, 07:59 AM   #31
kevlac
Drives: 2016 228i Convertible
Dinan_Engineering,
According to the installation instructions, this unit is shipped in Sport + mode. Once installed, are performance gains recognized in the other settings without using the app? i.e. - if I install it right out of the box, will I notice a different in ECO, Comfort/Normal, and Sport modes or do I need to switch to Sport + for this to work?
If I do not have an Android device, is it imperative to wait for the iOS app?
Can you provide any 0-60 or 1/4 mile example times for a stock 228i VS. a 228i with the Dinan Sport?
Thanks!
      07-25-2016, 08:23 AM   #32
Dinan_Engineering
Drives: Any BMW
Originally Posted by kevlac View Post
Dinan_Engineering,
Thanks!
The driving modes still function normally. Simply with more power to each of them is all. Sport + as far as the unit is concerned is just the name of the power setting and does not correlate to those actual driving modes directly.
You do not have to wait for the iOS app. Without an android device you just won't be able to switch settings is all. Chances are you know a friend that has a Android device in the meantime if you get curious though.
We do not do any 0-60 or 1/4 mile testing. Too many variables at play that can greatly affect a measurement where 0.1 seconds is the difference between great and horrible (especially 0-60 with launch). We stick to dyno's that can be accurately repeated for performance metrics. That said in hypothetical land, given the performance gain you should be seeing reductions of ~0.2 seconds on 0-60 times given same before and after conditions.
      07-27-2016, 09:42 AM   #33
casualDIYer
Drives: 340i xDrive M Sport
This is important to me too. I had the 'simple' BMS box on my 3 series which I used in the summer but I eventually removed it. I didn't like the jumpiness.
Did you find the Dinan smoother? I'd be willing to give one of these simple boxes another try if Dinan was smoother. I pick up my new 228i this Saturday.
Thanks for any feedback you can provide.
      07-27-2016, 09:07 PM   #34
Bleeped
Drives: 2014 M235
Interesting dyno results. Dare I say it proves what myself and many have said all along about bms stage 1 killing low end power and torque in a very noticeable way?
      08-08-2016, 08:15 PM   #35
X54TH
Member
X54TH's Avatar
Drives: 2019 X5 40i M Sport
Question regarding the App. If I use the App to change the setting does it remain in that setting after turning off the car or after restarting the car does it go to the factory Sport + setting +3 PSI? Just to confirm once more the setting is applicable to all modes not just Sport or Sport +?
      08-09-2016, 07:53 AM   #36
Dinan_Engineering
Drives: Any BMW
Remains in that setting until it is changed again regardless of if the car is restarted or not. And yes, SPORT affects all driving modes.
      08-09-2016, 11:18 AM   #37
jgoldstein2000
Dinan_Engineering I have your stage 1 tune. Are there plans to enhance the phone app to allow for more control like this sport tuner?
2016 BMW Deep Sea Blue 228i xDrive | DINANTRONICS Performance Tuner Stage 1 | Bilstein B16 PSS10 Coilers | 17inch O.Z. Alleggerita HLT Wheels
      08-11-2016, 04:42 PM   #38
X-M3driver
X-M3driver's Avatar
58
Drives: 17 ///M4
Received mine today. Install was extremely difficult (sarcasm) took all of............ 30 seconds
Only drove around the block. Tomorrow will be the test
      08-11-2016, 05:06 PM   #39
Dinan_Engineering
Drives: Any BMW
Eventually yes. Its on the docket at least. A lot more back-end gymnastics have to go on with the ELITE app though. We keep trying to get the powers that be to hire a dedicated app person as we all think that would be beneficial for everyone in the building but so far that doesn't seem to be getting us very far. If any app developers are out there and want a job and can wow management with a plan you are more then welcome to do so.
      08-15-2016, 06:13 PM   #40
M235iguy
M235iguy's Avatar
Drives: 2016 M235ix
Originally Posted by simoneves View Post
Looking for recommendations for non-California Dinan dealers who will sell me one of these by mail order. PM me. Thanks.
www.getbmwparts.com contact Evan@Tischer he is a forum sponsor and will get you a good price on Dinan products, ordered mine from him today! you can PM him
http://www.2addicts.com/forums/showthread.php?t=1281249
2016 ///M235ix | MP Grilles | MP Pedals | Gloss Black M235i Badge | Dinan CAI | Dinan tune | Dinmann CF Diffuser | MP CF Spoiler | CF mirrors | M2 CF interior | M2 Steering wheel
      08-16-2016, 11:59 AM   #41
Viffermike
Viffermike's Avatar
Soooo ... report? You had a weekend to run with it ...
--Helmets are for closers.--
      08-16-2016, 04:58 PM   #42
X-M3driver
X-M3driver's Avatar
58
Drives: 17 ///M4
Sorry, been a little busy
So, as stated the install was super simple and so far no issues at all. The butt dyno says there is an increase in power throughout the rev range. I like the roll on power mid rev range, making passing even easier, nothing like my 135 but better than stock. For the price it's a great power add on. Now we just need the app for the apple crowd
Viffermike1753.00
      08-18-2016, 04:55 PM   #43
simoneves
Drives: '16 228i DSB/THP/6MT
I just got mine too. Piss-easy install compared with the AA8 I had for a while. Quick test run in the default mode (I'm an Apple guy so I can't change it yet) felt pretty good. More when I've done a few more miles.
      08-18-2016, 09:39 PM   #44
M235iguy
M235iguy's Avatar
Drives: 2016 M235ix
Got it installed today! Very easy! Noticeable gains in normal and sport. App is easy to use and only tried Sport+ so far. Sport+ in Sport is pretty satisfying! Still need more open road to really let it loose. I also have the Dinan Intake with the Dinatronics Sport.
