2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions F22 coding cheat sheet
      04-19-2018, 12:16 AM   #1981
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Originally Posted by Questofthetune View Post
Any way of doing this through the BimmerCode app or am I going to have to get esys again?
I know not. I have never use phone apps to code.
      04-22-2018, 02:25 PM   #1982
zup2sky
Drives: M235I AW
Hey Everyone. I was able to successfully add digital speedometer in the BC and M Performance logo too. In doing so, my fuel consumption gauge switched from KM/L to MPG. I own a Canadian BMW and I'd like to have KM/L instead.
Also, I noticed M2 Cluster have digital clock on the right corner of the cluster. Can we code in the M235i/ M240i cluster?
      04-24-2018, 01:50 PM   #1983
EEBreh
Drives: "M" 235i
Im installing an HK setup in my m235i that I got for a very reduced price.
Can someone with an hk setup share their audio_system_cic value and the audio_system_var option value? Is there anything else that I need to code before I swap in the amp and the speaker setup? Thanks.
      04-24-2018, 11:40 PM   #1984
Almaretto
Almaretto's Avatar
2374
You could also just VO code vehicle with change audio system SA code.
EEBreh122.50
      04-25-2018, 01:27 PM   #1985
EEBreh
Drives: "M" 235i
Thanks for the response! I changed my car from 6NH to 6NS awhile back. I assume this is the exact same procedure except I'll modify the S674A to S676A (or 674 to 676 as they show up)?
I remember the last step of the 6NS coding procedure was that I recode the HU_nbt and a cmb box after I wrote a new FA. Do you know which ones I'll have to recode when I do the swap or will it be obvious? Thanks - I definitely appreciate the help.
      04-25-2018, 01:43 PM   #1986
Almaretto
Almaretto's Avatar
2374
You are welcome.
You can use ordering guides or TM's NCD / CAFD tool to determine appropriate code.
HU_NBT has build in combox, unlike HU_CIC. Tool will also give you an idea of which to code, but it should be amp, HU, and ASD. I am not sure if kombi would also be coded. If you PM'd me your FA and SVT, I could take a look. You can attach with cloud link.
EEBreh122.50
      04-25-2018, 10:36 PM   #1987
zup2sky
Drives: M235I AW
Anyone knows about this??
      04-27-2018, 06:52 AM   #1988
EEBreh
Drives: "M" 235i
You are welcome.
Thanks man! I'll send you a PM this weekend (I should be doing the swap then).
      04-27-2018, 10:42 PM   #1989
Rommel42
Drives: M235i 2016
Turn signal change
Having done any coding for some time.Anyway,I would like to change the # of blinks for lane changes from 3 to 5 blinks.Found out by reading many posts that with new 'Firmware' this is not possible.Can anyone chime in,and let me know,that it might be possible with the versions of my car.Thank you.
I have the following installed:
Launcher Premium 2.5.3
E-Sys 3.27.1
psdzData lite 58.3
The car is an M235i 2016 with I-Step F020-16-03-503
Launcher Premium 2.8
      04-27-2018, 11:13 PM   #1990
Almaretto
Almaretto's Avatar
2374
E-Sys 3.27.1
psdzData lite 58.3
Then you should be fine.
It is 3.61 (F020-03-503) when coding was no longer possible.
      04-28-2018, 08:30 PM   #1991
Rommel42
Drives: M235i 2016
Good to hear.Thanks,Almaretto.
      05-01-2018, 05:10 PM   #1992
sea_m2c
sea_m2c's Avatar
82
Drives: 2019 M2C - 6MT
Asking my question here in case anyone has an answer.
I recently did the Alarm System retrofit (not a standard option in the US on F22s!). I've updated the FA with option 302, coded the new FZD module.....and the alarm functions because I get the red blinking light and I can set it off, causing my horn to honk.
My siren still does not function however. I've been checking all the connections but I was curious if it was possible that the siren not functioning could be related to any of the coding.....considering that the alarm system itself is in fact working? Just shooting for process of elimination at this point
Current: 2019 M2 Comp, Coilovers, Camber Plates, Rogue SSK, AA Single MP, BM3 Stg 1
Sold: 2015 M235i RWD, MHD Stage 2, FBO, MPE, XHP, HPD5Evo | IG @sea_m235i
      05-01-2018, 07:23 PM   #1993
Almaretto
Almaretto's Avatar
2374
Did you VO code any other modules like HU?
      05-01-2018, 09:43 PM   #1994
sea_m2c
sea_m2c's Avatar
82
FZD, FEM, REM, HU_NBT
      05-02-2018, 12:48 AM   #1995
Almaretto
Almaretto's Avatar
2374
FZD, FEM, and HU_NBT should have taken care of necessary coding.
      05-02-2018, 02:01 PM   #1996
sea_m2c
sea_m2c's Avatar
82
Haha ughhh...
Is there a way I can go back and check the FA/VO that was applied to those ECUs, to make sure that option 302 was written to each of them? I activated the FA, right clicked each ECU and clicked Code. This was how the DIY/Tutorial I was reading described it but should I have hit the CODE button under the SVT menu instead?
If I chose the wrong CAFD file when FDL Coding the FZD, could that cause this issue? Sorry, I'm still learning all of this.
      05-02-2018, 10:46 PM   #1997
Almaretto
Almaretto's Avatar
2374
Haha ughhh...
Coding-Verification would create files that you could compare with existing with TM NCD / CAFD Tool.
      05-03-2018, 11:42 AM   #1998
MyloFiore
Drives: 2015 228i
I've been looking at the coding docs, trying to get my bearings.
pikcachu put together an excellent cheat sheet. Reading through some subsequent posts, I was able to determine that rows in green are confirmed to work, and blue is still "undetermined".
What do the red, and yellow lines mean? Can someone (pikcachu?) please add a legend for the color codes on the bottom?
Mylo
      05-03-2018, 02:08 PM   #1999
sea_m2c
sea_m2c's Avatar
82
Thanks, I'll give that a shot!
      05-05-2018, 07:47 AM   #2000
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
Mylo
Red means it do any work. And I think yellow are active by default
      05-07-2018, 05:55 PM   #2001
Bombermon3
Is there anyway to raise the headlight driving beam?
Thanks
      05-07-2018, 06:10 PM   #2002
pikcachu
pikcachu's Avatar
1403
Thanks
Yes there is a screw on top of the headlight. One way lowers and the other raises
