07-27-2017, 09:23 AM | #1849 | |
Rep 8,364
You will likely need PSdZ update. |
tux2005234.00 |
07-27-2017, 11:37 AM | #1850 |
General
10446
Rep 40,805
Drives: 2018 Alpina B6 650ix GC
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
tux2005234.00 |
07-27-2017, 02:35 PM | #1851 | |
Rep 92
07-30-2017, 09:35 PM | #1852 | ||
Plenipotentiary
2614
Rep 3,046
Do yourself and the drivers who have to share the road with you a favor. Position your car 10-20 feet from a wall. With the light switch in auto and the HBA OFF, manually push the high beam stalk forward to the on position. If you don't see the exact same pattern as the attached image, please remove the coding for GFHB. |
Almaretto2374.00 |
10-09-2017, 08:29 PM | #1853 |
@nycarguy
Rep 19
Hey everyone,
Just got BimmerCode and did some basic coding on my car. I know it has an Expert Mode that openes it up to manually code. Wanted to know if: 1.) It works the same way as E-sys. 2.) Could I utilize what’s in the cheat sheet with the expert mode? 3.) Can anyone link me to the most updated version of the coding cheat sheet? Thanks |
10-09-2017, 08:44 PM | #1854 | |
Rep 8,364
10-25-2017, 11:31 PM | #1855 | |||
Rep 245
So I had to re-code my car because of dealer update. Got a good amount of questions if anyone can help.
Code:
GWF_SBR_WARNDAUER 00 Quote:
Code:
Blinkzyklen_anzahl_tip 04 Can you code the sunroof and windows closing at the SAME time using CA or FOB instead of the windows first THEN the sunroof? Can you code CA and FOB windows/roof open/close to open/close 100% as soon as it's activated instead of needing to hold the button the entire time? Quote:
Thanks in advance. |
10-26-2017, 12:58 AM | #1856 | |
Rep 8,364
Yes, you can both adjust initiation delay as well as timing of various windows. Mirrors are all or nothing, but there is no way to code no-hold windows. You can though disable window safety to use one-touch closing or opening when doors opened. Adjusting blinks has not worked since 3.61. With newer firmware, you are out of luck. |
10-26-2017, 10:05 PM | #1857 | |
Rep 245
Is the delay code the one for rear windows and roof? I don't see anything in the f22 cheat sheet about delay between the front windows and roof. Thanks, I have it enabled to use one touch when doors are open already. No way If I knew that I would of never got the software updated. That was by request from me because of glitches I had. Was NOT worth it. There is no possible way to downgrade I'm assuming.. Was that change done on purpose? Is there a place to see change logs so I can know for the future? Thanks for all the help! |
10-26-2017, 10:09 PM | #1858 | |
Rep 8,364
There are separate FDL's for opening and closing initiation delay as well as delay between front/rear and rear/roof. Downgrades are possible. Only BMW knows why there was the change. There are never release notes/change logs. |
10-26-2017, 10:21 PM | #1859 | |
Rep 245
Got it. I guess it's just a learn from situations like mine kind of thing. How and what exactly needs to be downgraded? Other than simple coding from the cheat sheet, I don't know much about how it works or what everything is called. I also don't know what version I had before? I guess anything where the blinks works... Do you happen to know if they also changed the auto blip downshifting? I swear it was perfect before the upgrade. Now it only works half the time and I have to hit the brakes first to activate it. I am pretty sure I used to use it from coasting without needing the brake. |
10-26-2017, 10:25 PM | #1860 | |
Rep 8,364
I do not know if anything was changed on shifting. As no release notes exists, it is all subjective reports. |
10-27-2017, 08:22 PM | #1861 |
Rep 245
Well guess it's too risky... thanks. I'll have to live with my mistake
10-29-2017, 12:24 PM | #1863 |
Rep 18
Do I need to upgrade E-Sys 3.26.1
Hi,
I have E-Sys 3.26.1 working and have coded my car, a very long time ago BUT I want to do some coding again and want to know if I need to upgrade to the latest E-Sys to get any extra features. I am interested in the built in cheats etc. etc. and not sure if I can do that with 3.26.1 Upgrading from 3.26.1 is painfull as I need to go through the whole process of uninstalling, new psdzdatafile and Token etc. as well ? ALSO : I see a few cheat sheets etc. around . The one from Picachu seems the most comprehensive for my M235i. Thanks |
10-29-2017, 12:25 PM | #1864 | |
General
10446
Rep 40,805
Djaak19748.50 |
10-29-2017, 12:26 PM | #1865 | |
Rep 8,364
If it has, upgrade to 3.27.1 and Launcher 2.7.1. Launcher provides features, not E-sys. |
Djaak19748.50 |
11-07-2017, 02:41 PM | #1866 |
Rep 215
Hi all. I previously coded my 2015 428i but it's been a while. I just purchased a 2017 F22 and definitely need to get coding! Could somebody please send me the link for the newest software with built in cheats and all? Thank you!
11-15-2017, 08:10 PM | #1868 |
Rep 8,364
11-15-2017, 08:43 PM | #1869 | |
Rep 61
Andy |
11-15-2017, 09:32 PM | #1870 |
Rep 8,364
Carplay is either provisioned through ConnectedDrive or enabled with an FSC code. The ladder can either be loaded via flash drive or E-sys. Then, you will need to do some coding.
