06-19-2015, 11:21 AM | #23 |
Rep 397
Thank you everybody for your input and help! I will definitely go back and see if anything is different with a 4th gear pull if I can! I apologize if I came off as rude or a jerk. Has anyone ever dyno'd on a dynocomp? I wonder what makes these big differences between dyno models?
06-19-2015, 02:56 PM | #25 | |
Rep 135
http://www.2addicts.com/forums/showt...php?p=17422357 What kind of gas were you running? |
06-19-2015, 03:06 PM | #26 |
Rep 942
06-19-2015, 03:52 PM | #27 | ||
Rep 5,262
06-19-2015, 04:06 PM | #28 |
Rep 415
The link below has the specs for the 8AT in our cars. At the very bottom are the ratios for the gear box.
It is 6th gear for a 1:1 ratio but I believe we may be speed limited in 6th so 5th is the best option. 1st 4.70 2nd 3.13 3rd 2.10 4th 1.67 5th 1.29 6th 1.00 7th 0.84 8th 0.67 http://www.europeantransmissions.com...ansmission.htm |
06-19-2015, 04:12 PM | #29 |
Rep 596
Yeah, wheel torque should be at around the factory claimed crank level. So around 370 actual crank torque. I think a lot of the runs are influenced by the humidity and temperature too. Cooler, denser air would be more on the ideal side for dyno pulls id have thought.
Does the 8AT suffer from greater losses than the 6 speed manual? |
06-19-2015, 04:27 PM | #30 | |
Rep 397
Also, its been known that auto transmissions tend to have about 20% powertrain loss compared to the average manual's 15% Also, I forgot to mention I had ethanol free 93 octane! Stupid me. |
06-19-2015, 04:45 PM | #31 | |
Rep 596
06-19-2015, 05:04 PM | #32 | |
Rep 397
06-19-2015, 06:34 PM | #33 | |
Rep 5,262
