11-23-2015, 10:11 PM | #23 |
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
"Over time, all cars will do well in this test, but we're in a transitional period right now where only a small number of vehicles pass," said Karl Brauer, a senior industry analyst at Kelley Blue Book, "and only if they've taken this type of crash energy into account during their latest engineering redesign or refresh."
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
11-23-2015, 10:11 PM | #24 | |
In The Rain
8170
Rep 6,258
Drives: '24 GT4RS, '24 Macan GTS
Things happen on the road you will not be able to predict or avoid. Thinking about it won't make it go away or stop. You can give all the numbers you want but when it comes down to it, so long as you are alive. That is what matters. Unless you prefer dying instead of surviving then that's on you.
'24 Porsche Cayman GT4RS Arctic Grey "Alice"
'24 Porsche Macan GTS Dolomite Silver "Gina" |
11-23-2015, 10:34 PM | #25 | |
Rep 85
Drives: 2016 M3 2017 X5 2014 535(sold)
11-23-2015, 10:38 PM | #26 |
Rep 85
11-23-2015, 11:07 PM | #27 |
Rep 2,400
Chances are you won't see an M3/M4 test for the same reason you didn't see one for the E90/92 M3, that is the cars are sufficiently structurally similar to the base cars so that regulatory testing is not necessary. If the NHTSA won't test the M3/M4, you have to ask why? If the NHTSA doesn't test it, then won't that render the IIHS even more unlikely to test it?
Assuming that the cars were structurally different enough to warrant NHTSA/IIHS testing, what would logically prevent similar footwell intrusion in comparison to the base car? the axle carrier? the front strut brace? the hood? My impression among M3 owners (and was certainly my belief as well) was that their cars would perform no differently in comparison to the E90/92 base car despite some minor differences. Agree that the F30 deficiencies should have been addressed. Suggests corporate smugness/complacency with status quo vis-a-vis BMW's competitors. |
11-23-2015, 11:25 PM | #28 | |
Rep 85
Thanks for your comment, FogCityM3 |
11-24-2015, 12:50 PM | #29 |
Bergspyder
1469
Rep 1,212
I have been there and seen a small offset and a large offset crash test personally.
Pretty amazing facility and glad they are there. So why did they come out with the small offset crash test? Because all the manufacturers was passing and they needed to raise the bar. Also because the manufacturers were designing to pass the test....and nothing more. The small offset is a brutal test since there is little structure beyond the suspension mounting points. Now you either add structure to absorb energy or set the suspension up to shear off and not intrude into the car. I wouldn't worry about it. My two favorite IIHS videos of all time.....
11-24-2015, 09:23 PM | #30 |
Rep 2,527
Apparently Volvo had been advocating this type of crash test for years, and not surprisingly, they have engineered a crash structure that would do well in this sort of collision. Their solution was to insert an angle bar at the corners of the car to let the car glide off the object, and let the wheel shear off.
11-25-2015, 10:07 AM | #31 | |
Rep 79
11-26-2015, 08:58 PM | #33 |
Rep 155
I'll take all the structural safety I can get in a car. Right foot trapped? That is poor performance. This kind of significant intrusion into the footwell is both unexpected and unwelcome. I'm surprised, I expected better from a new gen/new design bread-and-butter high volume car from BMW. It's not an end-all be-all deciding factor but it's piss poor IMO. Just piss poor.
11-29-2015, 04:15 PM | #34 | |
European Editor
10539
Rep 22,992
Having a crash, airbags deploying AND loosing a wheel and continuing on wards at almost the same speed(!) is NOT my idea of a "safe car". Seems more like a way to cheat this "test".
11-29-2015, 08:09 PM | #35 |
Bergspyder
1469
Rep 1,212
It is very cool to go see them test cars there at the IIHS in Ruckersville VA.
They pull the cars up to speed with a giant tank of compressed air that pushes a hydraulic piston that runs a cable. This allows them to use ALL the electricity in the building for lighting purposes. When they turn on the lights for the high speed cameras the conduits near where you stand to watch hum like crazy. They move the objects that they run into (which weigh many tons) using compressed air through the bottom of the fixture to float it on air. They just expanded it as well.
11-30-2015, 03:32 AM | #37 | |
Rep 10,473
Bigsurprise100.00 |
11-30-2015, 05:45 AM | #39 | |
Moon Parasite
654
Rep 1,336
Meanwhile just keep a hacksaw in the car incase this type of off center crash happens and your foot gets caught by the front tire and the need to exit the vehicle is imperative, like a fire.
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged |
11-30-2015, 12:30 PM | #41 |
Rep 79
Well then it's a good thing you aren't in charge of safety for Volvo...or for crash test ratings.
11-30-2015, 04:02 PM | #42 | |
6659
Rep 15,858
I have spent a large part of my working career in design/R&D in the fall arrest industry, with a lot of similarities to vehicle impact tests. The ability to slow the deceleration and dissipate energy away from the human body and its restraint systems, makes a massive difference to safety. The Volvo example may appear a bit strange, but I'd rather be in its safety cell, with its 'soft' stop, than in a car which puts the wheel into the foot well, due to a more aggressive impact and a mass that stops in milliseconds. HighlandPete |
11-30-2015, 06:50 PM | #43 |
Rep 85
I guess engineers in BMW knows of this fact very very well by going through designing 2 series then did not do anything for 3 series LCI is disappointment. Thanks for your comment to show what changes should have done made for 3 series/M3/4.
I agree with you totally. |
