11-19-2015, 07:48 PM | #23 |
Rep 43
You clearly don't know what the definition of "facelift" is. Even changing motors doesn't qualify as a facelift (when the M54 got it's technical update in 2001, along with a 500cc bump in displacement with the 330, the car was still pre-facelift). You don't know anywhere near as much about BMW as you think you do.
11-19-2015, 07:59 PM | #24 | |
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
Whatever makes you feel good about yourself - cheers!
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
11-19-2015, 10:40 PM | #25 |
Rep 707
I owned an e46 m3 for 4 years. First off is it a 6MT, you're in better shape, if it's the SMG, don't bother.
Maintenance is key. Basic stuff: oil changes, coolant, and inspections. The LED tails were added in 2003...there was no " facelift" the car was the same body from 2001-2006. There were "updates" but no true aesthetic changes. It's a great car. prepare to spend reasonable $$ and take care of it. Enjoy! |
11-19-2015, 10:48 PM | #26 | |
Rep 8,852
11-26-2015, 02:33 PM | #27 | |
Rep 2,714
11-26-2015, 03:33 PM | #29 |
Rep 84
Drives: E46 M3/2016 M4
FWIW I have a 2003 LSB M3. It had the rod bearing recall, I reinforced the subframe at around 50K and have followed old school maintenance. I changed the OEM radiator to a Fluidyne/Turner rad at 150K as a preventative measure, original rad was still fine. It only spent one year in NJ when new and then I moved to Socal, It now has over 152 K on the clock still on original clutch and Vanos. So german high mileage sports cars can be reliable if looked after. Now I have to make an effort to drive it a least once or twice a month as I am enjoying my frozen black F82.
