01-20-2018, 11:56 PM | #1 |
Rep 38
Help coding 6NS/6NL
Hi guys,
So I'm new to whole coding game, but I thought I'd take a stab at coding enhanced bluetooth on my 17 M240i. First I'm confused whether I should use 6NH or 6NL. I just went with 6NL because somewhere it said that if you have NBT_ENTRYNAV you should use 6NL. So I coded the FA from 6NH to 6NL, and wrote that successfully to the car. So now if I read FA, it does indeed show 6NL. Now I read that I needed to VO Code the NBT unit. So I tried that, and I keep running into the following error. Code:
cdDeploy FinishedWithError cafd_00000ded-003_015_028 NotExecutable Does anyone have any thoughts? |
03-31-2018, 03:12 PM | #4 |
Rep 4
HI, I have 2014 i3 BEV and options 609,645,655,6AC,6AP. I was trying to add 6NS,6AM,6CP,6NR. Coded it without errors but when read ECU again, nothing new was added. I did code with bimmer code to get 2 phones and receive txt message but was wondering if with VO coding it would work better. Perhaps can get a calendar? Any anybody help with advice? txt
Tags |
coding |
