2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum M235i TT Review 4 -- Now with video (again)!
      03-04-2015, 06:09 PM   #45
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
you almost lost it at 2:13
I need higher resolution so i can see temp and psi please
      03-04-2015, 06:14 PM   #46
Pparana
Drives: 2015 m235i
Originally Posted by Liquidpaper View Post
The plates are actually the F30 plates, which are almost a direct fit for our suspension.
http://www.ground-control-store.com/.../II=975/CA=182
The only modification that you will need to make is that there is a washer between the top of the strut and the bottom of the plate/hat which does not fit over this weird lip on the top of our struts. The washer will need to be machined out (with a drill or something) a bit in order to get an exact fit.
Also, please make sure the wiring for your adaptive dampers is on the side of the strut tower, and not the top. If it comes out of the top, these plates will not work. If it is on the side, it will work.
Your MPSS should last a while with proper alignment. Not necessarily as long as a Potenza, Direzza, RD08, or RS3, but a decent while.
Turner motorsports has camber plates for our cars, that's where I got mine.
      03-04-2015, 06:20 PM   #47
Liquidpaper
Liquidpaper's Avatar
Drives: '15 M235i
2015 BMW M235i  [0.00]
Huh, nice. Didn't even see that. Well, that's definitely an option too.
      03-04-2015, 06:22 PM   #48
Liquidpaper
Drives: '15 M235i
Temp was low and it was cold as hell. It was also like driving on an oil slick from all the rain.
BTW, I didn't lose it. That was wicked sick drifting bro.
      03-04-2015, 06:25 PM   #49
pikcachu
pikcachu's Avatar
1399
I said "almost" ..
Would be nice to see how temp varies during the lap... wonder what's the refresh rate...
      03-04-2015, 06:39 PM   #50
Liquidpaper
Drives: '15 M235i
I said "almost" ..
I kind of kept track of the refresh rate. Its once every few minutes I think.
